Fuel anti-freeze additives - do you use any?
Old October 19th 06, 02:05 AM posted to rec.aviation.ifr
John R. Copeland
Default Fuel anti-freeze additives - do you use any?
"Peter" wrote in message ...
Hi All,
I fly a TB20 (avgas). The flight manual recommends various things but
does not give any ambient temperatures below which they should be
used.
The whole subject is a bit vague anyway, with stories circulating
about avtur additives being different from (or identical to) to the
avgas ones.
What would the experienced pilots here recommend, for an OAT down to
say -20C or -25C?
Peter.
Cold avgas should be no problem, assuming no suspended ice crystals.
Take care to keep your fuel clean and dry.
I often fly in the low flight levels where temperatures can be even lower.
The cold-soaked fuel flows just fine, including using a transfer pump to
move wing-locker fuel out into the tip tanks.
I've never had any avgas problems at those temperatures,
but cranking the starter against very cold oil has defeated me too many times.
Heated hangars are my favorite choice.
Starting new C172s navghtivs Piloting 76 September 10th 05 09:33 PM
Running dry? Greg Copeland Piloting 257 August 26th 05 03:47 PM
Towing Roger Fowler Soaring 6 August 11th 05 04:25 AM
Real stats on engine failures? Captain Wubba Piloting 127 December 8th 03 04:09 PM
Hot Starting Fuel Injected Engines Peter Duniho Piloting 23 October 18th 03 02:50 AM
