Garmin 396 Reception Problems - Again
Old October 24th 06, 02:55 AM posted to rec.aviation.owning
Mike Spera
Default Garmin 396 Reception Problems - Again
Its bbbbaaaaaaacccccckkkkkkk.
I thought we had the 396 reception problems solved with the unit swap
and upgraded firmware. On climb out the thing lost its lock again and
continued to do so until I changed course. That ain't gonna be an option
on a plan in IMC (uh, center, I need to change heading 30 degrees or so
to get my VFR GPS back on line...).
I tried switching freqs. on the nav and com radios to avoid harmonic
interference. No difference. I wonder why this cropped up after 3+
months of problem free reception??? Last time this was happening, I
tried running the unit on batteries, switching the GPS antenna around,
and a host of other things. Nothing helped until I upgraded the firmware
on a new unit. It has been solid since then with 6+ sats near the top.
Now, garbage again.
Anyone else see this problem on theirs?
Old October 24th 06, 03:44 AM posted to rec.aviation.owning
Dan Luke
"Mike Spera" wrote:
Now, garbage again.
Never on my 396, but yes on my 496. It was the antenna.
What model of antenna are you using?
Old October 24th 06, 04:25 AM posted to rec.aviation.owning
Dan[_1_]
Had the same issue.
Traced it to a bad antenna. Garmin FedEx'ed me a new one. The problem
is demonstrated when in line of sight to cell phone towers on certain
frequencies. Test it out around town, and you'll see what I mean.
--Dan
Now, garbage again.
Old October 24th 06, 01:18 PM posted to rec.aviation.owning
Doug Vetter
Dan wrote:
Had the same issue.
Dan,
I've noticed that when my unit goes deaf, switching antennas from the
external "hockey puck" unit to the stubby vertical has no effect so we
may be talking about the same symptoms but a different cause.
Just curious -- did they replace your puck antenna with a new model or
just replace the one you had? Also, just so we can nail this down, what
model antenna do you have now?
-Doug
Doug Vetter, ATP/CFI
http://www.dvatp.com
Old October 24th 06, 03:46 PM posted to rec.aviation.owning
B A R R Y[_1_]
Our 196 has the same problem. Switching antennas has no effect.
Old October 25th 06, 12:20 AM posted to rec.aviation.owning
Mike Spera
I tried the stubby when the thing used to crap out and it did exactly
the same thing.
Old October 24th 06, 04:28 AM posted to rec.aviation.owning
Doug Vetter
Now, garbage again.
Hmmmm. Interesting. I was just about to send my unit in. Now I wonder
if I should.
I did pretty much every troubleshooting procedure I could think of,
including Garmin's own "hard reset" procedure, running with the master
switch off in flight for about 5 minutes to positively eliminate
aircraft radios as a problem, running on battery, swapping antennas,
power cycling it, leaving it off for 5-10 minutes, etc. etc. etc. All
to no avail.
Incidentally, I have a GNS430 in the panel and compared satellite
reception when the 396 went deaf. The 430 had 12 sats with the signal
bars maxed on 9 of them. This is not the result of localized GPS
jamming tests. It may, however, be the result of terrestrial
transmissions combined with poor shielding of the 396's receiver. It's
happened several times in my local flying area (New Jersey) but it's
also happened over the Carolinas and Virginia.
Garmin has told me I'm running the latest powered antenna (it's a 2x3"
rectangular unit...I forget the model number). The earlier square units
apparently had problems.
I'm running firmware version 3.6 and have seen this problem since
version 3.0, which was (interestingly enough) installed when it was
about 3 months old.
I have a copy of the 2.4, 2.6, and 2.8 firmware -- all of which were
trouble-free -- and as a last ditch effort I'm planning to downgrade to
one of those (likely 2.8). Garmin has said that should work. If it
doesn't it won't have far to fall into the shipping box.
Good luck.
-Doug
Old October 24th 06, 07:54 PM posted to rec.aviation.owning
Gene Seibel
Any tall TV towers in the area? Some high power UHF stations have
harmonics that fall on GPS frequencies.
Gene Seibel KB0NNN
http://pad39a.com/gene/broadcast.html
Because I fly, I envy no one.
Now, garbage again.
Garmin user waypoints Jim Macklin Piloting 1 January 5th 06 06:12 PM
Garmin user waypoints Jim Macklin Instrument Flight Rules 1 January 5th 06 06:12 PM
Garmin 430 Reception Jon Kraus Piloting 16 November 7th 04 03:17 AM
Garmin 430 VOR reception Maik Piloting 11 September 30th 04 03:49 PM
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 4th 04 11:55 PM
