Starduster One pros and cons
Old October 29th 06, 05:49 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Default Starduster One pros and cons
Greetings,
I've been looking for an open cockpit biplane to have fun with (already
own and fly a 172) and was curious what opinions are about owning and
flying a Starduster One. Especially with an O-290G to D conversion. How
good or bad are their taildragger habits, what to expect from a
maintence standpoint (any problems to be aware of), problems with the
O-290, etc.
I just got my taildragger endorsement (in a Cub and Cessna140), so I'm
leery about getting something too hot to handle, part of the point is
to build up taildragger experience for the future (when I buy my
Nieuport or Fokker replica!)
Thanks for any opinions.
Ryan
Old October 29th 06, 07:40 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
flybynightkarmarepair
Greetings,
O-290, etc.
Ryan
The Starduster series are beautiful airplanes, but rather tedious to
build. It's not uncommmon to see 10-15 years of work in the
completions in KITPLANES and Sport Aviation. Based on what I've seen
and read, you would be finished and flying a Graham Lee Nieuport
replica by the time you finished the first wing of a Starduster if
you're a first time builder.
The O-290-G conversion was good in it's day, but that day is past.
There is not a vast supply of cheap core engines left, and if you found
one, it's been sitting now for over 40 years. Think Corvair for planes
of this size if you're trying to cheap it out. Any of the biplanes
that flew with an A-65 would fly nicely behind a Corvair.
Another planes for you to think about: Easy Eagle
http://www.greatplainsas.com/eespecs1.html
AUTOPILOT PROS & CONS STICKMONKE Instrument Flight Rules 53 May 24th 06 12:16 AM
Experimental Catagory: Pros and Cons? [email protected] Soaring 18 April 16th 06 11:56 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 03:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 04:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 07:24 AM
