Hi,
ever heared of winch launches up to 5200 ft (1590m)? in the forum of www.segelflug.de I read the following. It might be of interest for you (short form translation): During a glider acrobatic meeting in Fuerstenfeldbruck (Germany/Bavaria), pilots from Bavaria and Austria had the possibility to try a new launch method. Mostly double seaters were launched up to 5200 ft. (1590m). Acro pilots were enthusiastic after 29 launches, because they could fly their full program out of the winch after an only 90 seconds lasting start. This was made possible by the winch manufacturer Tost (Assling, Germany). They supplied a specially modified winch. Karl Hoeck from Friedberg/Germany did the technical calculations and the design of the drum of the winch. This drum had to withstand a pressure of 3 million lb (1400 metric tons) from the 9842 ft (3000m) of Dyneema rope with 0.18 inches diameter (4.5mm). Organizing clubs were Bundeswehr Sportflieger Gemeinschaft Fürstenfeldbruck e.V. and Akademische Fluggruppe München. Munich control was involved. With headwinds between aprox. 6 and 11 knots (10 - 20 km/h) following altitudes have been reached: ASK 21 and ASK 13 double seated: 5216 ft (1590m) FOX double seated: 4594 ft (1400m) Mue 28 single seated: 3937 ft (1200m) regards Walter |
How long was the runway?
Fuerstenfeldbruck is a discontinued NATO airbase. They have plenty of space
there. The runway length was 2744m, but I think they used also the safety strips close to 3000m. regards Walter |
Good show!
Dyneema/Spectra winch cable allows for launches to approximately 50% of the original cable length. Calculations show that there is really no upper limit to the amount of Dyneema that can be used. 90 seconds to 5200 feet AGL on a winch beats the hell out of 20 minutes on aero tow. That's especially true when the typical cost is $10 for the launch. Karl Hoeck, the drum designer (and really nice guy), usually has a booth at the SSA convention showing off brochures of his winch design based on a Ford diesel pickup. Bill Daniels "Walter Kronester" wrote in message ... Hi, ever heared of winch launches up to 5200 ft (1590m)? in the forum of www.segelflug.de I read the following. It might be of interest for you (short form translation): During a glider acrobatic meeting in Fuerstenfeldbruck (Germany/Bavaria), pilots from Bavaria and Austria had the possibility to try a new launch method. Mostly double seaters were launched up to 5200 ft. (1590m). Acro pilots were enthusiastic after 29 launches, because they could fly their full program out of the winch after an only 90 seconds lasting start. This was made possible by the winch manufacturer Tost (Assling, Germany). They supplied a specially modified winch. Karl Hoeck from Friedberg/Germany did the technical calculations and the design of the drum of the winch. This drum had to withstand a pressure of 3 million lb (1400 metric tons) from the 9842 ft (3000m) of Dyneema rope with 0.18 inches diameter (4.5mm). Organizing clubs were Bundeswehr Sportflieger Gemeinschaft Fürstenfeldbruck e.V. and Akademische Fluggruppe München. Munich control was involved. With headwinds between aprox. 6 and 11 knots (10 - 20 km/h) following altitudes have been reached: ASK 21 and ASK 13 double seated: 5216 ft (1590m) FOX double seated: 4594 ft (1400m) Mue 28 single seated: 3937 ft (1200m) regards Walter |
This is good news, but I have to wonder how they, or we in the US would
protect the cable from other aircraft that might stray into it at those altitudes. Next question is how far the cable would drift on the way down, assuming that the wind is not always right down the runway. Mark Bill Daniels wrote: Good show! Dyneema/Spectra winch cable allows for launches to approximately 50% of the original cable length. Calculations show that there is really no upper limit to the amount of Dyneema that can be used. 90 seconds to 5200 feet AGL on a winch beats the hell out of 20 minutes on aero tow. That's especially true when the typical cost is $10 for the launch. |
You have to clear the area of air traffic before launch. Sinch the launch
is over so quickly, that isn't too hard. The typical light plane will travel about three miles in 90 seconds so clearing out to that distance plus a safety margin avoids conflict. If you operate in an area with faster traffic, you probably had a tower to coordinate with. Bill Daniels "aviationnut" wrote in message oups.com... This is good news, but I have to wonder how they, or we in the US would protect the cable from other aircraft that might stray into it at those altitudes. Next question is how far the cable would drift on the way down, assuming that the wind is not always right down the runway. Mark Bill Daniels wrote: Good show! Dyneema/Spectra winch cable allows for launches to approximately 50% of the original cable length. Calculations show that there is really no upper limit to the amount of Dyneema that can be used. 90 seconds to 5200 feet AGL on a winch beats the hell out of 20 minutes on aero tow. That's especially true when the typical cost is $10 for the launch. |
aviationnut wrote:
This is good news, but I have to wonder how they, or we in the US would protect the cable from other aircraft that might stray into it at those altitudes. Presumably the same way we do: have your field marked as a gliding field on the sectionals with a warning about cables to x000 feet. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Bill Daniels wrote:
Good show! Dyneema/Spectra winch cable allows for launches to approximately 50% of the original cable length. Calculations show that there is really no upper limit to the amount of Dyneema that can be used. 90 seconds to 5200 feet AGL on a winch beats the hell out of 20 minutes on aero tow. That's especially true when the typical cost is $10 for the launch. That sounds a bit frightening - 3500 fpm! What are the stresses on the glider to get that kind of climb rate? How far away is disaster if the pilot twitches a bit on the controls or hits some wind shear or a thermal? -- Eric Greenwell - Washington State, USA Change "netto" to "net" to email me directly "Transponders in Sailplanes" on the Soaring Safety Foundation website www.soaringsafety.org/prevention/articles.html "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
That's a normal climb rate for winch launching. I know of no break-up on
winch launch during the last 26 years, and there are thousands of winch launches done every weekend in Europe. "Eric Greenwell" wrote in message news:AFg1h.4183$WB4.3314@trndny04... 90 seconds to 5200 feet AGL on a winch beats the hell out of 20 minutes on aero tow. That's especially true when the typical cost is $10 for the launch. That sounds a bit frightening - 3500 fpm! What are the stresses on the glider to get that kind of climb rate? How far away is disaster if the pilot twitches a bit on the controls or hits some wind shear or a thermal? -- Eric Greenwell - Washington State, USA Change "netto" to "net" to email me directly "Transponders in Sailplanes" on the Soaring Safety Foundation website www.soaringsafety.org/prevention/articles.html "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
| Thread Tools | |
| Display Modes | |
| Winch operations | Edward Winchester | Soaring | 7 | April 13th 06 12:24 PM |
| UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 07:58 PM |
| LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? | Bill Daniels | Soaring | 20 | December 27th 04 01:33 AM |
| I need winch launch videos | Bill Daniels | Soaring | 21 | December 1st 04 07:41 PM |
| Blanik Weak Link for Winch Launch??? | Gary Emerson | Soaring | 6 | February 24th 04 09:08 PM |
