Welding Regulator Leakage
Old October 31st 06, 03:57 AM posted to rec.aviation.homebuilt
J.Kahn
Default Welding Regulator Leakage
I hooked up an oxygen regulator to a tank and opening the tank valve
slowly it registered about 2200 psi. To check for the seal at the
regulator connection I then turned off the tank valve with the regulator
closed so that the gage was reading only the pressure of the few cc's of
gas trapped between the regulator and the closed tank valve. The
pressure would drop about 25-50 psi per minute. It should be zero no?
John
Aluminum welding Ernest Christley Home Built 5 April 24th 06 11:47 AM
Welding question Michael Horowitz Home Built 1 October 13th 05 09:53 PM
Practical welding? mhorowit Home Built 21 August 23rd 05 04:33 AM
AC 43.13, welding and a hip-check Michael Horowitz Owning 2 June 27th 04 07:09 PM
TIG welding video? Russell Duffy Home Built 3 October 6th 03 05:55 AM
