WOW!
Old October 31st 06, 09:42 PM posted to rec.aviation.soaring
Default WOW!
Here is something you more experienced pilots might want to comment on.
Being a pilot of much less experience, it just looked like an
interesting thing to see comments on some of the points the pilot
makes.. I came across this 2005 article while just wandering about on
the web. Scroll down to the high speed approach article.
You'll need acrobat reader.
http://www.pugetsoundsoaring.org/new...ow_10_2005.pdf
Old October 31st 06, 10:46 PM posted to rec.aviation.soaring
Stewart Kissel
Default WOW!
Yikes....
80 knot patterns in a 2-33? I can't agree with his
comment that students are 'incompetent', thus they
are taught stabilized approaches. Also, what does
the POH state for approach speeds?
I suspect others might come up with more reasons why
99%? of us don't fly patterns like this.
Old October 31st 06, 11:38 PM posted to rec.aviation.soaring
Burt Compton - Marfa
Default WOW!
Stewart Kissel wrote:
Yikes....
Yes. TIME.
Old October 31st 06, 11:51 PM posted to rec.aviation.soaring
Mark Dickson
Default WOW!
I doubt if he makes many, if any, field landings.
If he uses that approach method into a small paddock
or even an unusual airfield, he's going to end up with
egg on his face.
want to comment on.
like an
the pilot
wandering about on
Old November 1st 06, 12:42 AM posted to rec.aviation.soaring
Default WOW!
I flew my Discus out of Bergseth a time or two. Even gave some
instruction in the club's equipment. Never did anything like that.
Hummm, let's see the Maneuvering speed on the trusty sail pig, ( too
dirty three), is 65MPH. Eighty-five knots is a mite fast.
Zulu
Old November 1st 06, 01:15 AM posted to rec.aviation.soaring
Eric Greenwell
Default WOW!
32 mph over Maneuvering speed is a mite fast? What's Vne?
"Transponders in Sailplanes" on the Soaring Safety Foundation website
www.soaringsafety.org/prevention/articles.html
"A Guide to Self-launching Sailplane Operation" at www.motorglider.org
Old November 1st 06, 05:11 PM posted to rec.aviation.soaring
KM
Default WOW!
Eric, VNE is Velocity Never Exceed.It is the max indicated speed at
which you can fly.
Fly Safe,
K Urban
(Just Yukkin it up here)
Old November 1st 06, 08:01 PM posted to rec.aviation.soaring
Eric Greenwell
Default WOW!
which you can fly.
Not a well-phrased question, apparently: I wanted to know the Vne for
the 2-33 glider.
Old November 1st 06, 03:46 AM posted to rec.aviation.soaring
Bob C
Default WOW!
Very well written article. This is a 'standard' airshow
sailplane approach. I've done it a thousand times.
Gives you exceptional glidepath control, excellent
control authority and makes a stall/spin highly unlikely
(though not impossible). One of my tricks for setting
up a perfect spot landing.
That being said; as with any new technique, don't try
it the first time without the assistance of someone
experienced in the technique. (I was taught a similar
approach by Les Horvath.) Just because it has advantages
doesn't mean there aren't ways to screw up. The higher
speeds may cause the controls to be 'twitchy', possibly
leading to a disastrous PIO situation. The spoilers
(especially Grobs) may behave very badly when deployed
at high speeds. It may be possible to overstress the
glider. Be extra cautious of this technique when switching
from a 2-33 to a higher performance glider. The extra
energy you're carrying may be more than you realize.
There are advantages in learning where the edges of
the performance envelope are, but explore carefully
with the help of an experienced pilot. Knowing the
parameters may give you the advantage you need to get
out of a sticky situation someday. Being comfortable
on a fast, low approach might come in handy when you
discover power lines while setting up an out landing.
I've seen the results of trying to go over without
enough energy...
want to comment on.
like an
the pilot
wandering about on
Old November 1st 06, 04:40 AM posted to rec.aviation.soaring
Default WOW!
Yes as Bob says, a well written article. About what I'm not too
sure... It makes me wonder if the writer really understands the
reasons behind accepted glider approach methods.
I believe that there has been a careful accounting of extra-high speed
approach methods to counter strong sink/wind gradient and insufficient
energy conditions. If I recall, the physics pretty much favor the near
best glide "accepted" approach techniques in wide use (world wide for
decades) in all conditions.
I say we thank him for operational testing of a method that I'm too
chicken to use except when I have more runway then I know what to do
with and nothing better to do. Go MAN GO!
Matt Michael
