October Aero'Lectric Temp Sensor Project
Old November 1st 06, 12:10 AM posted to rec.aviation.homebuilt
Paul Dow (Remove Caps in mail address)
Default October Aero'Lectric Temp Sensor Project
We're always looking to do some educational subject at our EAA chapter
meetings, so I think Jim's project in the October Kitplanes will be a
useful item to build. It looks like a small project that can be put
together in a couple of hours (although with our group, I better
allocate some overtime.)
I ordered a bunch of parts to make them, and today I got a volunteer
from the chapter to see if I could translate the schematic to a board,
and if they could follow my instructions. I used 1/2 of a Radio Shack
276-159 project board to assemble it on. It's the perfect size for the
circuit.
The good news...I didn't let the smoke out of the parts. The bad
news...I'm not getting close to the voltage output I'm supposed to.
With having the adjustment pots near the center, I get about 4.8 volts
in ice, 6.3 volts in boiling water. (The diode, not the whole circuit.)
That's about a 1.5 volt range which is close to the 1.8 volt range
desired. Therefore, it looks like the offset isn't right.
I did build another one on my own without looking at the first one, and
it puts out similar voltages.
I do get 5 volts at the first stage of the opamp, so I believe I'm OK at
that point. I get 1.2 volts (hot) .78 volts (cold) at the input to the
2nd stage.
I know it's tough to see my solder blobs to see where I screwed up, but
I was wondering if there's any other hints, or if someone could let me
know what voltages I should see at various points in the circuit.
Paul
Old November 3rd 06, 02:42 PM posted to rec.aviation.homebuilt
I downloaded a SPICE-type demo off the Texas Instruments web site.
Program is called TINA. I entered the circuit, and got output voltages
similar to what the physical device I made delivered. The demo version
only allows 2 active elements, so I removed the two voltage follower
opamp segments U1B and U1D.
I'm not an electronic engineer, and I don't even play one on TV, but I
can figure out the V=IR stuff. The basic circuit idea makes sense to me,
so I went in and did some trial and error changes on some of the
resistor values. I changed:
R8 from 180K to 270K
R7 from 18K to 10K
R4 from 560K to 510K
and R2 from 4.7K to 180K
The program shows some non-linearity from about 32 to 45 degrees, but
the output is close to the desired range now.
I'm sure I haven't chosen the optimal values for the resistors, but it
seems to work for me.
Paul
circuit.
2nd stage.
Paul
Swift Boat Veterans For Truth: Are They Going To Sink John Kerry? BUFDRVR Military Aviation 151 September 12th 04 09:59 PM
Lot of noise being made about Purple Hearts Jack Military Aviation 154 September 8th 04 07:24 PM
Archer high oil temp Mike Noel Owning 7 June 15th 04 03:38 PM
Date of effect now 1 October 2004 for revised IGC-approvals for certain legacy types of GNSS flight recorder Ian Strachan Soaring 0 March 15th 04 02:32 PM
Coalition casualties for October Michael Petukhov Military Aviation 16 November 4th 03 11:14 PM
