DIY antenna for handheld transceiver
Old November 9th 06, 10:38 PM posted to rec.aviation.homebuilt
Brad Lewandowski
Default DIY antenna for handheld transceiver
I'm going to try and make an antenna as shown in Kitplanes MAR 2006
("Rubber Duckie, Your'e the One..).
Does it matter if the copper foil is 1/4 or 1/2 inch wide?
Does the balun have to be right in the middle (if I want to put in
a PVC tube it wouldn't fit with a balun in the middle) or can it be at
the bottom of the dowel with longer leads?
Anybody make one of these successfully?
Thanks!
Brad
I Hate Radios Ron Wanttaja Home Built 9 June 6th 05 06:39 PM
Retractable Comm Antenna Ron Wanttaja Home Built 11 September 6th 04 07:59 PM
ELT antenna -- Pitts Al MacDonald Home Built 0 July 15th 04 04:27 PM
Ext antenna connection for handheld radio Ray Andraka Owning 7 March 5th 04 02:10 PM
LS-4 Transponder antenna location? Matt Herron Soaring 3 February 25th 04 04:45 PM
