Tank pressure for Speedaire compressor?
Old November 12th 06, 11:53 AM posted to rec.aviation.homebuilt
Michael Horowitz
Default Tank pressure for Speedaire compressor?
Someone gave me a Speedaire Model 3Z394 airtank.
I know nothing about its integrity or working pressure.
1. If you own such a model, could you tell me the max safe tank
pressure?
2. How can I determine if the tank (which as some rust on the outside)
still has its integrity? - Mike
Old November 12th 06, 05:24 PM posted to rec.aviation.homebuilt
vcdvsr
pressure?
Old November 12th 06, 06:24 PM posted to rec.aviation.homebuilt
Michael Horowitz
pressure?
Sorry, came out blank. Please try again - MIke
Old November 12th 06, 07:04 PM posted to rec.aviation.homebuilt
John Kunkel
"Michael Horowitz" wrote in message
pressure?
That model was originally powered by a 3/4 hp motor so I would guess it has
a shutoff pressure of 120 psi.
Only a hydrostatic test can prove the integrity.
Old November 12th 06, 08:23 PM posted to rec.aviation.homebuilt
Michael Horowitz
thanks - MIke
On Sun, 12 Nov 2006 11:04:04 -0800, "John Kunkel"
pressure?
Old November 13th 06, 03:09 AM posted to rec.aviation.homebuilt
Cy Galley
Old compressor tanks are a time bomb. Most cheap compressor tanks are not
ASME rated nor tested. Rust on the outside is not the problem. It is the
rust on the inside from condensation over the years, AND when they go, they
really go.
One of our EAA Chapter 75 members brought in a tank that had split from end
to end and I wrote about in Sport Aviation. Then I had several others relate
their stories... Like went to town and came back to a hole in the garage
roof. Or... Missed me by inches but ruined the overhead door. And then there
are those not so lucky that can't tell a story as they died.
Many compressor sales agencies can and will do a hydrostatic test. Involves
filling with water then running the pressure up to 150% of working.
Commercial places have to do this on a regular basis.
Before you use this "freebie" Have it tested for your health.
Cy Galley
EAA Safety Programs Editor
Always looking for ideas and articles for EAA Sport Pilot
thanks - MIke
pressure?
has
Old May 21st 08, 01:46 AM posted to rec.aviation.homebuilt
Morgans[_2_]
True, but if it is surface rust, it should be OK.
Ever wonder what the inside bottom of a tank looks like, especially on that
does not get drained after each use?
I have to think that there is a healthy safety margin designed into tanks.
Old May 21st 08, 11:05 PM posted to rec.aviation.homebuilt
Capt. Geoffrey Thorpe
"Morgans" wrote in message
that does not get drained after each use?
I'm sure there is, but FWIW - check the local fire extinguisher places -
they will be able to do a hydrostat (or know where to go)
Geoff
My Ercoupe is flyin' again... (long) Greg B Owning 13 August 30th 06 12:01 AM
Why are TE probes so long? Duane Eisenbeiss Soaring 36 May 9th 04 06:58 AM
Positive Tank Pressure Greg Esres Owning 6 April 29th 04 11:44 AM
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk Jehad Internet Military Aviation 0 February 7th 04 04:24 AM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
