I tried on rec.av.IFR and got no response, so I thought I'd try here.
Anybody know what it takes to adjust the alert volume on the King KAS 297B unit? The volume is killing my ears. TIA, - Don Farming looks mighty easy when your plow is a pencil and you are a thousand miles from the corn field. - Dwight D. Eisenhower |
The sheet I looked said that unit gives 2V p-p into 500 ohms. No wonder
it is loud. Can you add a resistor or a potentiometer into the signal line? If you use a pot, get a 500 ohm potentiometer (log response would be best type) across the output and ground and wire the wiper so as to make it the new output line -i.e. as a regular volume control. If you can only fit an inline resistor into the signal line, try several values from say 100 ohm up until you get a suitable (still loud) volume. Disclaimer: Such a modification is entirely at your own risk and I make no recommendation whatsoever as to the suitability of this mod. for inflight use. Cheers MC No Spam wrote: I tried on rec.av.IFR and got no response, so I thought I'd try here. Anybody know what it takes to adjust the alert volume on the King KAS 297B unit? The volume is killing my ears. TIA, - Don Farming looks mighty easy when your plow is a pencil and you are a thousand miles from the corn field. - Dwight D. Eisenhower |
Thanks, MC. I was hoping there was a screw on the box somewhere.
- Don Everything is funny as long as it is happening to somebody else. - Will Rogers On 11/13/06 22:38, "DR" wrote: The sheet I looked said that unit gives 2V p-p into 500 ohms. No wonder it is loud. Can you add a resistor or a potentiometer into the signal line? If you use a pot, get a 500 ohm potentiometer (log response would be best type) across the output and ground and wire the wiper so as to make it the new output line -i.e. as a regular volume control. If you can only fit an inline resistor into the signal line, try several values from say 100 ohm up until you get a suitable (still loud) volume. Disclaimer: Such a modification is entirely at your own risk and I make no recommendation whatsoever as to the suitability of this mod. for inflight use. Cheers MC No Spam wrote: I tried on rec.av.IFR and got no response, so I thought I'd try here. Anybody know what it takes to adjust the alert volume on the King KAS 297B unit? The volume is killing my ears. TIA, - Don Farming looks mighty easy when your plow is a pencil and you are a thousand miles from the corn field. - Dwight D. Eisenhower |
Metric Instruments | Roy Bourgeois | Soaring | 29 | May 27th 13 01:53 PM |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
why is intercept altitude labeled "LOC only"? | Gary Drescher | Instrument Flight Rules | 32 | September 23rd 06 09:00 PM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
