How many nonradar airports?
Old November 24th 04, 01:27 AM
Andrew Sarangan
Default How many nonradar airports?
I am curious to know how many airports exist where you have to fly a non-
radar instrument approach (ie feeder routes, IAF, procedure turn etc..). I
have come across a few in Colorado and New Mexico, but I have never
encountered one in other areas I have flown.
Old November 24th 04, 04:45 AM
Brad Zeigler
Hidden in the Shenandoah valley of VA, KSHD is out of Potomac Tracon radar
coverage.
On 23 Nov 2004 19:27:59 -0600, Andrew Sarangan
I
Plenty in Vermont and New Hampshire.
Also some in Indiana that I'm aware of.
Old November 24th 04, 05:11 AM
John Clonts
"Andrew Sarangan" wrote in message
1...
Plenty in Texas. Fredericksburg and Brownwood are two that I've done full approaches in non-radar
environment...
Cheers,
John Clonts
Temple, Texas
N7NZ
Old November 24th 04, 12:01 PM
Who would be counting them?
Old November 24th 04, 01:50 PM
Brian Case
Off the top of my head, I can only think of about 4 airports in Idaho
that do have radar coverage.
Andrew Sarangan wrote in message . 61...
Old November 24th 04, 04:45 PM
Stan Gosnell
1:
There are a few thousand oil and gas production platforms in the Gulf of
Mexico that are beyond both radar and radio coverage from ATC. We fly IFR
approaches to them regularly.
Regards,
Stan
Old November 25th 04, 04:19 PM
Gene Whitt
Andrew,
There is RADAR and RaDaR. After a 40 year delay all of the S.F.
Bay Area non RADAR airports have a TV like system called BRITE. Bride does
give the towers a TV like screen that allows the tower to see the VFR
aircraft on radar with a readout of altitude.
The antenna is usually so distant from the airport that it is not certified
to provide a transponder code nor separation. I recently checked out
Concord, CA tower's situation and found that the radar is a two edged blade.
In over 40 years as a radar-less tower there has never been an ATC related
accident at CCR. Nor has there been one in the year BRITE has been in the
tower.
The problem is that some of the tower people become reliant upon
a radar screen that has inherent weaknesses and errors. The visual
skills of the past become less required and proficient. The position
reporting skills of the pilot become more important.
A week ago I was with a student in a C-172 where we made a call-up saying
that we were planning on a 45 endtry to the downwind. Immediately
afterwards a twin Commander made the same call. Neither aircraft was able
to find the other and the controller could not distinguish one from the
other since both were squawking 1200. The difficulty arose from the
perception of what constitutes a 45 entry. The Commander was closer to a
direct entry to downwind than a 45.
By making a short approach we were able to help resolve the situation.
Gene Whitt
Old November 25th 04, 05:53 PM
Roy Smith
"Gene Whitt" wrote:
Andrew,
I don't think the certification of what a controller can do with a brite
scope has much to do with where the antenna is. NY Tracon has (to the
best of my knowledge) 5 antennas, located at JFK, EWR, ISP, HPN, and
SWF. The raw signals from all of the antennas are transmitted to a
secret location in suburban Long Island where the Tracon is physically
located. The various display scopes at all the area airports (the four
Class B and C primaries plus all the dozen or so Class D satellites) are
all then fed remotely from the computers in the Tracon.
HPN, with an antenna right on the field, acts like a satellite airport.
They can't release IFR flight without coordinating with the Tracon, and
the Tracon handles sequencing inbound flights and (in the case of VFR
inbounds) assigning squawk codes before handing off to the tower. The
brite scope in the HPN tower does give altitude and squawk code readouts.
On the other hand, LGA has no antenna on the field (my understanding is
the HPN antenna sees almost to the ground at LGA), but I'm sure they
provide full radar services.
This certainly seems to be the case at HPN. I've had the tower refuse
to allow VFR pattern work because the radar was down. Or limit the
pattern to one or two aircraft. At CDW (in the pre-brite days), they
used to routinely handle 8 guys in the pattern and still work arrivals
and departures on both runways.
One of the things I try to impress on students is that the tower at a
Class D airport has no responsibility for separating VFR from VFR in the
air. Most pilots seem to think that the tower is doing more for them
than they really are.
In theory, the controller in your case could have said, "172, maintain
at or below 1000, break, Twin Commander maintain at or above 1200,
report the 172 in sight". That would have ensured you wouldn't swap
paint. But, I'm sure it would have also broken the rules the controller
operates under, so it'll never happen.
Old November 25th 04, 09:39 PM
KP
"Gene Whitt" wrote in message
.net...
Andrew,
does give the towers a TV like screen that allows the tower to see the VFR
What is displayed on a tower's BRITE depends on the equipment although I'd
be suprised if there are any not equipped with D-BRITE these days. D-BRITE
is a digital display vs the old long persistence TV version of the 70s and
80s. It has the ability to display all the info available to the TRACON.
What is actually displayed depends on what the SOP requires and what the
local controller prefers.
certified to provide a transponder code nor separation.
Distance from the antenna seldom, if ever, has anything to do with the
information available for display or operational procedures applied when
usiing a tower radar display. See FAAO 7110.65 3-1-9 for more info of what
can and cannot be done wit a tower radar display.
I recently checked out Concord, CA tower's situation and found that the
radar is a two edged blade. In over 40 years as a radar-less tower there
has never been an ATC related accident at CCR. Nor has there been one in
the year BRITE has been in the tower.
This has been at issue for the more than 40 years since the first BRITE
radar systems were placed in towers. Some say it's an aid, some say it's a
crutch, some say it's something in between.
So what? You were both VFR. Neither of you were in the pattern yet. See
and Avoid.
Not sure what needed to be "resolved?" Once the aircraft entered downwind
the controller should have issued any instructions necessary to establish
the landing sequence.
GA friendly airports near ELP & AUS ROBIN FLY Instrument Flight Rules 8 November 24th 04 08:50 PM
Flight Simulator 2004 pro 4CDs, Eurowings 2004, Sea Plane Adventures, Concorde, HONG KONG 2004, World Airlines, other Addons, Sky Ranch, Jumbo 747, Greece 2000 [include El.Venizelos], Polynesia 2000, Real Airports, Private Wings, FLITESTAR V8.5 - JEP vvcd Home Built 0 September 22nd 04 07:16 PM
Detroit: choice of IFR airports? Mike & Janet Larke Instrument Flight Rules 3 October 18th 03 02:02 PM
Getting auto gas at airports Patrick Underwood Home Built 7 September 25th 03 05:10 PM
Damn, I Love Hometown Airports Larry Smith Home Built 1 August 6th 03 08:05 AM
