Gasoline for jetengines on non jetairplanes
Old November 24th 06, 08:30 PM posted to rec.aviation.military.naval
Max Richter
Default Gasoline for jetengines on non jetairplanes
Hallo,
many C119/123; B36; Neputnes and several other airplanes with
reciprocating-engines were fitted jet -engines as "boosters".
Now the question:
did they use avgas for these jets or jetfuel from a special tank ?
Greetings
Max Richter
Old November 24th 06, 09:07 PM posted to rec.aviation.military.naval
Bob Moore
Now the question:
The Neptune "de-fuelers" burned 115/145 right along with the
R-3350s.
Bob Moore
VP-21 1959-1962
Old November 24th 06, 09:47 PM posted to rec.aviation.military.naval
John Weiss[_1_]
"Bob Moore" wrote...
R-3350s.
....and had a fine coating of red lead in the tailpipes to prove it!
Old November 25th 06, 06:38 AM posted to rec.aviation.military.naval
John Keeney
Max Richter wrote:
Hallo,
Now the question:
Greetings
Max Richter
The B-36 burned avgas in all engines, even when it was "six turning and
four burning."
Old November 25th 06, 02:40 PM posted to rec.aviation.military.naval
Ed Rasimus[_1_]
On 24 Nov 2006 22:38:38 -0800, "John Keeney"
Max Richter wrote:
Hallo,
Now the question:
Greetings
Max Richter
four burning."
Used to have some Army livery F-10s at Holloman--jets that burned
AvGas. Man did they stink when you had to taxi behind one!
But, the KC-97s used to carry JP-4 for offload and AvGas for their own
engines.
Ed Rasimus
Fighter Pilot (USAF-Ret)
"When Thunder Rolled"
www.thunderchief.org
www.thundertales.blogspot.com
Old November 25th 06, 03:01 PM posted to rec.aviation.military.naval
Paul[_3_]
"Ed Rasimus" wrote in message
Max Richter wrote:
Hallo,
Now the question:
Greetings
Max Richter
four burning."
engines.
Ed Rasimus
"Most" jet engines will run on anything that will burn...
Diesel, Jet A , JP-4/5/8, Avgas....even Mogas..
The old Huey -10 had pages listing which fuels you could run in it, and for
how long. There are restrictions on how long you can run the engine on
"Alternate / emergency fuels..
The -10 for the Chinook lists this restictions also....
TB 55-9150-200-24 lists the fuel types suitable for use in turbine engine
aircraft.
For years and years Jet engines ran on JP-4 which is a mixture of Kerosene
and Gasoline..
Thankfully today we are running all JP-8 / JP-5...
which has a much higher flash point.
And the Air Force is running JP-8 100+ in many aircraft.
On a further note, the Army is running almost all ground diesel engine
vehicles on JP-8 / Jet A. Which works ok for some, but other engines have a
problem with the low lubricity of Jet Fuel and have problems with early fuel
pump / injector failures.
Some vehicles with Cummins / Cat engines have specfic instructions in the
operators manual to add engine oil to the fuel to improve the lubricating
properties of JP-8 / Jet A when used as fuel for those engines.
IIRC - the mixture is like 5 percent by volume.
Helomech
Old November 26th 06, 06:36 PM posted to rec.aviation.military.naval
M. B.
Default Wild Weasel
Ed,
Any chance of talking with you off-line regarding some research I'm doing?
V/R
M.B.
Remove nospam from the address above if you wish to write me directly.
Fueling from plastic gasoline containors Michael Horowitz Home Built 33 March 2nd 05 11:06 PM
Gasoline "Snow"? Jay Honeck Piloting 18 December 27th 04 12:28 AM
Speaking of Gasoline TO THE GROUP Piloting 11 May 31st 04 06:57 PM
The answer to the gasoline problem Veeduber Home Built 4 May 22nd 04 08:58 PM
$3.00 a gallon gasoline by summer(read all of this, it just might work) Fastglasair Home Built 8 March 10th 04 12:12 AM
