radio squeal question - fixed
Old November 26th 06, 02:22 PM posted to rec.aviation.homebuilt
Stealth Pilot
Default radio squeal question - fixed
I asked what could be causing a loud squeal in my headset when I key
the mike.
well I fixed it. it required absolutely no modification to my
altronics headset at all and there was no problem with the wiring or
the Icom A200 radio.
the problem was corrosion on the brass components that form the base
of the antenna wire and the antenna mount. I cleaned these up with a
wire brush and brasso to remove the oxide. I took the opportunity to
give the antenna a new coat of paint, screwed the now clean faces of
the antenna mount together and viola! no squeal anymore.
thanks for the suggestion by the poster in another thread. he was on
the money. corrosion in the antenna mount was the culprit.
Stealth pilot
Radio "Hash" Kensandyeggo Owning 5 October 17th 06 05:02 AM
Why don't voice radio communications use FM? Mxsmanic Piloting 399 September 13th 06 10:58 PM
Want manual for Dittel FSG 77 M radio Eric Greenwell Soaring 7 October 21st 05 05:24 PM
1944 Aerial War Comes to Life in Radio Play Otis Willie Military Aviation 0 March 25th 04 10:57 PM
Why not use the F-22 to replace the F/A-18 and F-14? Guy Alcala Military Aviation 265 March 7th 04 09:28 AM
