According to the Aerostar's specification sheet, it says "Must have
350hp engines above FL250". Is this a regulation thing, or just a limitation of the type? I tried searching through any kind of e-FAR I could find, but came up with squat. http://www.aerostaraircraft.com/specs.pdf Come to think of it, there are a bunch of altitude restrictions based on equipment, that are spread throughout the FARs, such as the Mode C rule above 10,000; oxygen starting at 12.5; and DME above FL240. I also remember a King Air pilot saying in order to fly above a certain altitude (something like in the FL3XX range) you had to have a specially certified altimeter (which costs an arm-and-a-leg) Is there one place that has all of these altitude restrictions listed? |
buttman writes:
I also remember a King Air pilot saying in order to fly above a certain altitude (something like in the FL3XX range) you had to have a specially certified altimeter (which costs an arm-and-a-leg) Perhaps he was thinking of RVSM flight? -- Transpose mxsmanic and gmail to reach me by e-mail. |
Part 23 and 25 is where you find aircraft certification.
Part 91 has requirements for flight in airspace, such as reduced vertical separation [ what the King Air pilot was talking about]. Revisions to Part 23 have included increased requirements for stability above 25,000 feet. Other requirements for pressurization and or oxygen systems have included altitude limits. The Type Certificate Data Sheet for each make, model and serial number is where the limits, such as you cited will be found. "buttman" wrote in message s.com... | According to the Aerostar's specification sheet, it says "Must have | 350hp engines above FL250". Is this a regulation thing, or just a | limitation of the type? I tried searching through any kind of e-FAR I | could find, but came up with squat. | | http://www.aerostaraircraft.com/specs.pdf | | Come to think of it, there are a bunch of altitude restrictions based | on equipment, that are spread throughout the FARs, such as the Mode C | rule above 10,000; oxygen starting at 12.5; and DME above FL240. | | I also remember a King Air pilot saying in order to fly above a certain | altitude (something like in the FL3XX range) you had to have a | specially certified altimeter (which costs an arm-and-a-leg) | | Is there one place that has all of these altitude restrictions listed? | |
In article m,
"buttman" wrote: According to the Aerostar's specification sheet, it says "Must have 350hp engines above FL250". Is this a regulation thing, or just a limitation of the type? I tried searching through any kind of e-FAR I could find, but came up with squat. At FL250, those 350hp engines will not be putting out much of their rated power. |
If they are turbo-charged using bug turbos, they may put out
nearly full power at 20,000 feet and normal high cruise power at higher altitude. It all depends on the way the system is put together. "john smith" wrote in message ... | In article m, | "buttman" wrote: | | According to the Aerostar's specification sheet, it says "Must have | 350hp engines above FL250". Is this a regulation thing, or just a | limitation of the type? I tried searching through any kind of e-FAR I | could find, but came up with squat. | | At FL250, those 350hp engines will not be putting out much of their | rated power. |
"Jim Macklin" wrote in message ... If they are turbo-charged using bug turbos, they may put out nearly full power at 20,000 feet and normal high cruise power at higher altitude. It all depends on the way the system is put together. "john smith" wrote in message ... | In article m, | "buttman" wrote: (snip) Well does anyone know what the critical altitude of the superstar 700 is?. |
| Thread Tools | |
| Display Modes | |
