I've flown a lot of planes, of different sizes, and I always lift off gently.
When I fly as a passenger on an airliner though, there is a "thud" or even a "bang" as the main wheels leave the runway. Sometimes this bang is so loud is frightens passengers, and once it was strong enough (on a 777 departing for Hong Kong) that I was sure we'd at least blown a tire, if not actually struck something with the mains. But in the end, it's always OK - just normal. Who knows what this is? Is it the pusher actuators on the main gear? The telescoping elements of the main gear bottoming out? Just curious. . . G Faris |
As long as you are sure it isn't the wheels completing their retraction into
the wheel well, then it is probably the struts extending to its full-extended position. Or it may be the brakes stopping the turn of the wheels before it starts its retraction. I've flown many hours around the world and the main "bang" I remember is the retraction of the main wheels. Marco Leon "G Farris" wrote in message ... I've flown a lot of planes, of different sizes, and I always lift off gently. When I fly as a passenger on an airliner though, there is a "thud" or even a "bang" as the main wheels leave the runway. Sometimes this bang is so loud is frightens passengers, and once it was strong enough (on a 777 departing for Hong Kong) that I was sure we'd at least blown a tire, if not actually struck something with the mains. But in the end, it's always OK - just normal. Who knows what this is? Is it the pusher actuators on the main gear? The telescoping elements of the main gear bottoming out? Just curious. . . G Faris |
"G Farris" wrote in message ... I've flown a lot of planes, of different sizes, and I always lift off gently. When I fly as a passenger on an airliner though, there is a "thud" or even a "bang" as the main wheels leave the runway. Sometimes this bang is so loud is frightens passengers, and once it was strong enough (on a 777 departing for Hong Kong) that I was sure we'd at least blown a tire, if not actually struck something with the mains. But in the end, it's always OK - just normal. Who knows what this is? Is it the pusher actuators on the main gear? The telescoping elements of the main gear bottoming out? Just curious. . . The latter. The gear might "bang" during retraction when it's inserted into the wells, but it's several seconds later. -- Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO |
I would suspect that it is the suspension unloading. The suspension would
have to be extremely strong to support the loads required. I would suspect that it is not the smothest (quietest) thing while in motion. It probably thumps hard when it is loaded up (upon landing) and when it is unloaded(take off). You probably don't notice it on landing because of everything stopping its downward motion when it hits the ground. It is probably lost with all of the other noises associated with impacting a runway. The suspension probably sticks a little and when it is unloaded and effected by vibrations, it falls to its full extended position on takeoff. Just and educated guess. |
Just an opinion...
If the sound is really right at lift off, maybe it's the wheels trucks dropping back. They are designed to hang back-end down. I could imagine that they thump if the lift of is quick enough. -- ------------------------------- Travis "Kevin Chandler" wrote in message ... I would suspect that it is the suspension unloading. The suspension would have to be extremely strong to support the loads required. I would suspect that it is not the smothest (quietest) thing while in motion. It probably thumps hard when it is loaded up (upon landing) and when it is unloaded(take off). You probably don't notice it on landing because of everything stopping its downward motion when it hits the ground. It is probably lost with all of the other noises associated with impacting a runway. The suspension probably sticks a little and when it is unloaded and effected by vibrations, it falls to its full extended position on takeoff. Just and educated guess. |
G Farris wrote:
I was thinking something like that too - except in some large airliners, like the 777, they do not "drop" into that position, but they are pushed by hydraulic actuators. Yes, but the first thing that happens during the 777 retract sequence is that the actuators tilt the gear. I've heard the sound you're referring to as well, I think. I'm wondering if the 777 has some kind of automatic wheel spin brake. |
| Thread Tools | |
| Display Modes | |
