Contest towing with retract tow line
Old December 13th 06, 02:08 PM posted to rec.aviation.soaring
Andy[_1_]
Default Contest towing with retract tow line
In Mal's 2006 photos is a picture of Pawnee VH-CUR that appears to have
a Tost retractable tow rope.
Does anyone have experience with contest towing with the retract rope?
Is it possible to fit into the normal tug rotation with a retract rope,
or is the rope left extended for contest towing.
Andy
Old December 13th 06, 04:33 PM posted to rec.aviation.soaring
Having run many contests in the U.S., it has been my experience that
they fit in the rotation just fine. Although most of our tugs feature
the retractable rope, most contests are run with a mixture of tow rope
systems.
Andy
Old December 13th 06, 06:45 PM posted to rec.aviation.soaring
Robert Danewid
During the WGC in Sweden last summer we used 12 Pawnees with
tow rope winches. The rope is winched in after release and
such a winch is more or less standard on Swedish tugs.
/Robert
CD WGC2006
Andy
Old December 14th 06, 12:45 AM posted to rec.aviation.soaring
BT
for those that are un-intiatated..
the tow rope is retracted before landing
saves wear and tear on the rope or snagging runway lights
just taxi up closer to the glider, the line crew pulls the rope out and
hooks up
then taxi forward until the entire rope is out before take off
BT
"Andy" wrote in message
Andy
Old December 14th 06, 10:17 AM posted to rec.aviation.soaring
Mal
"BT" wrote in message
hooks up
BT
Andy
http://www.mals.net/nswcomps2006/pages/DSC01883.htm
I did have a close up of the tow hook set up but it has gone to delete land
some how it was deleted it from the camera.
During the state comps and cup week they used a normal tow rope the aircraft
has both set ups on board.
VH:CUR Experimental runs on unleaded it is a Holden commodore car engine.
http://www.mals.net/nswcomps2006/pages/DSC01885.htm
Did you spot the Jabiru J230 with a tow hook
http://www.mals.net/ncw06/pics1/
Not this aircraft but another has done tows.
Old December 14th 06, 03:06 PM posted to rec.aviation.soaring
Bill Daniels
hooks up
Please, don't taxi up close to the glider. Be courteous and don't direct
prop blast at gliders or people. I've had canopies slammed down on my
fiingers and passengers heads. I've had to go to an eye doctor twice to get
grit removed from my corneas. Towplane prop blast is absolutely the
nastiest part of this sport.
Just taxi into position 190 feet or so ahead of the glider, It's a lot
better to have someone walk a few hunderd feet to get the rope than use a
$140/hour Pawnee to position it.
Bill Daniels
Old December 15th 06, 01:49 AM posted to rec.aviation.soaring
BT
"Bill Daniels" bildan@comcast-dot-net wrote in message
hooks up
get grit removed from my corneas. Towplane prop blast is absolutely the
Bill Daniels
True Bill... I should have changed out that was stated.. when we "taxi
close" the prop wash is always directed off to the side.. never at the
glider or ground crew.. we also taxi no closer than on average about 50ft.
Bill
2006 Region 3 Soaring Contest - Glens Falls, NY Tim Hanke Soaring 0 April 7th 06 12:46 AM
PW-5 US National Contest June 19-29, 2006 Burt Compton - Marfa Soaring 0 April 6th 06 05:13 PM
US Region 7 Soaring Contest Paul Remde Soaring 0 May 11th 05 03:19 PM
31st Annual CCSC Soaring Contest USA Mario Crosina Soaring 0 April 6th 05 12:47 AM
CAD outline of Rans S6S instrument panel? Rob Turk Home Built 2 October 21st 03 09:27 PM
