identifying an aircraft
Old December 14th 06, 05:49 PM posted to rec.aviation.piloting
timothy
Default identifying an aircraft
I wonder if someone could help me identify and aircraft I saw several
times on a reason visit to Reno? The plane is has twin pusher props,
the tail is delta shaped and the aircraft canard . . . it looked a
little like one that Beechcraft made . . . I can't remember the name
but the wing and tail wing configuration was completely different.
There were two of these planes flying out of RNO. Thank you, Tim
Old December 14th 06, 05:59 PM posted to rec.aviation.piloting
karl gruber[_1_]
Did it look like this?
http://tinyurl.com/yzh389
Karl
N185KG
"timothy" wrote in message
Old December 14th 06, 06:06 PM posted to rec.aviation.piloting
timothy
Karl
N185KG
That's it! Thanks for the help. TM
Old December 14th 06, 06:24 PM posted to rec.aviation.piloting
Jim Macklin
It needs to be painted a dark grey on top with blue
highlights, medium blue on the sides with a white bottom.
That way it can look like a beached whale. Or a catfish.
| Karl
| N185KG
I saw several
pusher props,
it looked a
remember the name
Thank you, Tim
Old December 14th 06, 06:29 PM posted to rec.aviation.piloting
[email protected][_1_]
I think that somebody already answered you, but just in case:
It's a Piaggio Avanti P.180. (http://www.piaggioaero.com/) Reno is one
of our mx bases.
12,100 lb T/O weight
395 knots at 28,000 feet.
It's the worlds fastest business turboprop.
Hope this helps.
Old December 14th 06, 09:52 PM posted to rec.aviation.piloting
karl gruber[_1_]
ps.com...
of our mx bases.
Hope this helps.
How are the wings de-iced? I've looked at one up close and can't see
anything obvious.
Karl
N185KG
Old December 14th 06, 10:08 PM posted to rec.aviation.piloting
Gig 601XL Builder
"karl gruber" wrote in message
ps.com...
of our mx bases.
Hope this helps.
anything obvious.
Karl
N185KG
From their Website
Main wing leading edge anti-ice is
accomplished by directing engine bleed air
through a diffuser duct installed in the main
wing leading edge.
The forward wing contains an electrically activated
de-icing blanket on the aluminum
alloy leading edge.
Nacelle inlets are de-iced by pneumatic boots.
To avoid ice ingestion, an inertial separator is
installed inside each nacelle. Moreover, the
cycling of the nacelle boots is automatically
controlled by the Ice Detector System in its
primary mode of operation. A timer is provided
to cycle the boots for secondary operations.
Electric heating of the windshield on both pilot
and co-pilot sides is used to guard against or
alleviate icing and fogging.
No ice protection is provided or required on the
horizontal and the vertical tail.
Old December 15th 06, 07:01 PM posted to rec.aviation.piloting
That's a sweet post; I probably should have read a little farther
before I ended up repeating everything that you said.
Old December 15th 06, 07:00 PM posted to rec.aviation.piloting
The front wing (NOT a canard) is electric heat, the engine intakes are
pneumatic boots, and the main wing is heated from engine bleed air. The
props are "always heated" from the exhaust, and the empennage is cold.
On Dec 14, 4:52 pm, "karl gruber" wrote:
wrote in glegroups.com...
of our mx bases.
Hope this helps.How are the wings de-iced? I've looked at one up close and can't see
anything obvious.
Karl
N185KG
Contact Approach -- WX reporting [email protected] Instrument Flight Rules 64 December 22nd 06 01:43 PM
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 03:04 PM
