A-65 Oil screen thread pitch?
Old December 15th 06, 04:21 AM posted to rec.aviation.homebuilt
Scott[_1_]
Default A-65 Oil screen thread pitch?
Doe anybody know what the thread pitch for the oil screen is on a
Continental A-65? I have slightly boogered threads on the engine
threads and I want to run a set of dies through (I bought a tool with
the dies from McMaster Carr). It looks like 16 TPI is the closest.
Does that sound reasonable or does someone know for sure? I checked all
the ones that came with the tool by putting them over the threads on the
oil screen and let them drop in between the threads. Is that an
acceptable way to test for the right pitch or do I need to drop them
into the (female) threads in the rear accesory case, which would be damn
near impossible to see if they line up perfectly)? Any other ideas
(trying to avoid pulling the engine or rear case off)???
Scott
Corben Junior Ace with A-65
Old December 15th 06, 04:45 AM posted to rec.aviation.homebuilt
Tom Frey
"Scott" wrote in message
Continental A-65? I have slightly boogered threads on the engine threads
and I want to run a set of dies through (I bought a tool with the dies
from McMaster Carr). It looks like 16 TPI is the closest. Does that sound
reasonable or does someone know for sure? I checked all the ones that
came with the tool by putting them over the threads on the oil screen and
let them drop in between the threads. Is that an acceptable way to test
for the right pitch or do I need to drop them into the (female) threads in
the rear accesory case, which would be damn near impossible to see if they
line up perfectly)? Any other ideas (trying to avoid pulling the engine
Scott
What kind of tool did you get with your dies. What you need is a simple
"thread pitch gage" to be sure. Inexpensive ones can be purchased from most
any place that sells measuring tools to machine shops.
Old December 15th 06, 12:33 PM posted to rec.aviation.homebuilt
Scott[_1_]
I can't remember the exact name of the tool, but it's made to repair
internal threads that are damaged. Basically looks similar to a piston
ring expander with changeable dies that attach at the ends. Then all
you do is set the dies into the threads, squeeze the handle a bit to
give the dies some pressure to stay in the threads and spin the tool around.
Scott
Old December 16th 06, 09:43 AM posted to rec.aviation.homebuilt
joeslow
Scott,
It is called a "Therad Chaser" they make them in all sizes ... you may
find them at Enco.com or other machine catalogs.
JK
Scott
Old December 16th 06, 08:58 PM posted to rec.aviation.homebuilt
Scott[_1_]
Actually, I'm not sure they actually called it that in their catalog,
but that's essentially what it is. Anyhow...I got the threads repaired
yesterday, so I'm ready to button up and test run it. Thanks to all for
the help...
Scott
joeslow wrote:
Scott,
JK
Scott
Old December 15th 06, 08:31 AM posted to rec.aviation.homebuilt
Philippe Vessaire
Continental A-65? *I have slightly boogered threads on the engine
the dies from McMaster Carr). *It looks like 16 TPI is the closest.
I machined a plug for remote oil filter.
I confirm 16TPI.
By
Pub: http://www.slowfood.fr/france
Philippe Vessaire Ò¿Ó¬
Old December 15th 06, 12:36 PM posted to rec.aviation.homebuilt
Scott[_1_]
Thanks for the info! I think it probably would be good to get a pitch
gauge as well and triple check. Besides, I'm SURE there will be other
places I could use the gauge...But it is nice to get that fuzzy feeling
from someone else confirming what I see here. Thanks again...
Scott
I confirm 16TPI.
By
Old December 25th 06, 02:30 AM posted to rec.aviation.homebuilt
Fly
El Reno Aviation has a tap to fit wich they rent/loan it to F&M STC filter
buyers.
Maybe call them?
Kent Felkins
Scott
I machined a plug for remote oil filter. I confirm 16TPI.
By
Old December 25th 06, 12:19 PM posted to rec.aviation.homebuilt
Scott[_1_]
Thanks for the tip. I bought a tool from McMaster-Carr for repairing
internal threads and it did the trick....
Scott
buyers.
Maybe call them?
Kent Felkins
Thread chaser for oil screen housing? Scott Home Built 6 September 29th 06 12:06 PM
Prop Pitch Question Eugene Wendland Home Built 2 April 25th 04 03:22 AM
ANN: SoaringPilot 1.9.8 Mark Hawkins Soaring 0 April 21st 04 05:09 PM
Baby Bush will be Closing Airports in California to VFR Flight Again Larry Dighera Piloting 119 March 13th 04 02:56 AM
ALTRAK pitch system flight report optics student Home Built 2 September 21st 03 11:49 PM
