Emergency Landing in a COZY MKIV
Old December 17th 06, 02:24 AM posted to rec.aviation.piloting
Marc J. Zeitlin
Default Emergency Landing in a COZY MKIV
Folks:
For those interested, we had an experience this weekend in our COZY
MKIV when the propeller decided to proceed along a different path than
the rest of the airplane. You can read the details at:
http://www.cozybuilders.org/Desert_Center/
comments welcome.
Marc J. Zeitlin
Copyright (c) 2006
Old December 17th 06, 02:45 AM posted to rec.aviation.piloting
Kev
comments welcome.
Congratulations for making a safe landing, and on airport ! One
question, if I could:
Even though you couldn't see behind you (?), you almost immediately
figured it was the propeller. I'm not sure many people would think of
that right away. Had you previously thought of that situation, or was
just the smoothness... and could you hear the engine still? (I'm not
sure I'd trust the gauges if they said my engine was running but I had
no thrust ;-)
Regards, Kev
Old December 17th 06, 05:08 AM posted to rec.aviation.piloting
Jack Allison[_1_]
Wow, nice writeup. Glad everything worked out so that you landed safely.
Jack Allison
PP-ASEL-Instrument Airplane
"To become a Jedi knight, you must master a single force. To become
a private pilot you must strive to master four of them"
- Rod Machado
(Remove the obvious from address to reply via e-mail)
Old December 17th 06, 06:00 AM posted to rec.aviation.piloting
Marc J. Zeitlin
no thrust ;-)
I could hear the engine, and could hear the difference as I changed
throttle settings and watched the RPM change on the tachometer. The
only thing that I could imagine that would make the engine SMOOTHER
while still running was if the prop disappeared. I don't believe that
I had ever contemplated this particular situation - the whole prop
departing. I've heard stories of prop BLADES departing (wood props,
mostly), and know that the vibration is horrendous and that shutting
down the engine as quickly as possible before it tears itself off the
firewall is paramount. So I have always thought that if vibration was
severe, shutting off the engine was task #1. But this vibration was
nowhere near this level - this was more along the lines of one spark
plug not firing, or a bit worse than that, but the whole plane was NOT
shaking.
Marc J. Zeitlin
Copyright (c) 2006
Old December 17th 06, 02:01 PM posted to rec.aviation.piloting
mike regish
Great write up. Everything sure lined up nicely for an on-airport landing
and you took full advantage of it. Nicely done.
A question I have is, were the prop bolts safety wired? Even properly
torqued bolts can come loose if they're not properly safety wired. Sounds to
me like they were under torqued or not wired and worked loose just enough to
subject them to some slight bending moment, but also to the impacts of each
cylinder firing. This was happening over a fairly long period of time. The
bolts eventually fatigued and gave up the ghost. They should be, and remain,
torqued beyond any forces they will encounter.
Just my $.02 and worth every bit of it.
mike
"Marc J. Zeitlin" wrote in message
Folks:
For those interested, we had an experience this weekend in our COZY MKIV
when the propeller decided to proceed along a different path than the rest
comments welcome.
Marc J. Zeitlin
Copyright (c) 2006
Old December 17th 06, 03:06 PM posted to rec.aviation.piloting
Bob Moore
Doesn't matter...I had this happen to me once...same outcome,
un-eventful landing on the runway.
With a wood prop, when cold, dry, winter sets in, the wood
shrinks away from the previous torque settings allowing the
bolts to fail in just a few minutes. All of the safety wire
in the world doesn't help.
Bob Moore
1/2 VW Powered MiniMax
Old December 17th 06, 03:15 PM posted to rec.aviation.piloting
Ron Lee
Congrats on a safe landing. Do keep us informed on actual cause. I
also have a Catto three blade prop on an RV-6A. The "undertorqued"
option seems unlikely since you no doubt can properly torque bolts.
Is there a chance that a change in humidity from your normal location
caused a change in torque?
Finding the prop could answer a lot of questions.
Ron Lee
Old December 17th 06, 03:23 PM posted to rec.aviation.piloting
mike regish
I was wondering about the prop composition, too. So it was wood. Safety wire
might not help, but wood props do require regular retorqueing for just the
reason you state. And the probable reason for the bolt failures was due to
the bolts becoming undertorqued due to wood shrinkage.
mike
"Bob Moore" wrote in message
46.128...
Bob Moore
Old December 17th 06, 07:28 PM posted to rec.aviation.piloting
Robert M. Gary
Folks:
I didn't see the cause of the failure (I'm sure it was there but there
was a lot to read through). Could this have been one of the Hartzell
recalled hubs?
-Robert
Plastic planes are fast but landing speed too high P S Owning 30 June 20th 06 10:30 PM
plane crashed on takeoff attempt after emergency landing Toks Desalu Piloting 33 November 1st 05 03:31 PM
"bush flying" in the suburbs? [email protected] Home Built 85 December 28th 04 11:04 PM
C-17 Emergency Landing in Baghdad--CNN Report Kevin Brooks Military Aviation 0 December 10th 03 02:35 PM
Military jet makes emergency landing at MidAmerica Otis Willie Military Aviation 0 September 1st 03 02:28 AM
