Oil Coolers
Old December 17th 06, 05:07 AM posted to rec.aviation.piloting
Default Oil Coolers
In October, after an extensive repair/restoration of my airplane, the
oil cooler split on start-up and dumped most of the oil. Long story, but
the engine seized up 6 minutes into the flight and we did an emergency
landing in the desert. We were very fortunate to walk away with minor
injuries, but the plane was totaled.
To the airplane owners out there, how often do you flush/pressure test
or replace your oil cooler? Some say it's only done at a major overhaul,
others say it should be done at every annual, others say only if there's
a problem w/oil pressure. I had never heard of an oil cooler failing
before this, but now I've heard people say it happens on occasion.
Anyone else here have experience with this?
Shirl
Old December 17th 06, 10:50 AM posted to rec.aviation.piloting
Default Oil Coolers
Mortimer Schnersd, RN wrote:
I had an oil line to the oil cooler on a Piper Lance separate after an engine
overhaul, dumping the oil and causing the engine to seize just like your
description... about 5 or 6 minutes into the flight. The resulting landing
in a cow pasture did not go well.
As far as I know, it was caused by a mechanic not tightening the line; not
failure of the cooler itself.
Right, the lines can come loose and/or fail, too, but mine was the oil
cooler itself -- you could *see* where it split, and 3 days later, at
the salvage yard, oil was still dripping out of it. I was later told,
"Oh yeah, those do that sometimes!" I also later learned that they're
supposed to be flushed and pressure-tested, but I can't seem to get a
definite answer from anyone as to when or how often this is supposed to
be done.
Thanks for your response.
Shirl
Old December 17th 06, 11:08 AM posted to rec.aviation.piloting
Jim Macklin
Default Oil Coolers
Depending on the design of the oil cooler, they should be
inspected and maintained on a regular schedule.
Common problems are oil congealing and blockage of oil flow
in cold weather, a by-pass valve should prevent oil
starvation to the engine. The oil cooler bursting problem
is often caused by the oil pressure regulator relief valve
being stuck on engine startup, oil pressure can go into the
hundreds or thousands of pounds pressure if the regulator
valve does not open at the pump.
The engine oil pump and regulator can produce more pressure
than the system can seal or contain if the regulator sticks
even momentarily.
flush/pressure test
a major overhaul,
say only if there's
cooler failing
on occasion.
was the oil
days later, at
later told,
that they're
seem to get a
is supposed to
| be done.
| Shirl
Old December 17th 06, 11:29 AM posted to rec.aviation.piloting
Neil Gould
Default Oil Coolers
Recently, Jim Macklin posted:
even momentarily.
Good info, Jim, thanks!
Now, I'll pay particular attention to the pressure on start-up to note
whether the needle is pinned for any duration.
Neil
Old December 17th 06, 01:02 PM posted to rec.aviation.piloting
Jim Macklin
Default Oil Coolers
If it happens it will be fast, faster than the gauge will
likely respond. The oil pump is a set of meshed gears that
move the oil. They move a fixed amount with each revolution
of the engine. There is a spring loaded pressure relief
valve in the pump that by-passed oil back to the pump intake
if the pressure is high.
Chapter 6 of AC 65-12
http://www.airweb.faa.gov/Regulatory...0?OpenDocument
has diagrams and explanations.
During an overhaul of an engine, a valve can become jammed,
blocked or otherwise adversely effected. The valves should
be clean and function checked. But a metal chip or other
problem can happen and can get into a pump system. Often
the relief valves are stuck open and you don't get full
pressure, but it can stick a valve closed and then the
pressure goes up until something breaks or a seal blows.
"Neil Gould" wrote in message
. net...
posted:
be
flow
problem
valve
regulator
pressure
sticks
| even momentarily.
start-up to note
| Neil
Old December 17th 06, 01:59 PM posted to rec.aviation.piloting
Jay Honeck
Default Oil Coolers
Our oil cooler failed on a flight to Missouri earlier this fall.
Luckily, it split in such a way (at a seam) that the oil was pumped out
SLOWLY, making a huge mess but not harming the engine. (We only lost
1/2 quart of oil on a 1-hour flight.)
I've never heard of anyone pressure testing an oil cooler, although I'm
sure it's done.
Glad you came out okay...
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old December 17th 06, 02:41 PM posted to rec.aviation.piloting
Jim Burns
Default Oil Coolers
In addition to JimM's great information, check out
http://www.oilcoolers.com/ , Pacific Oil Cooler Service. Lots of good info
there. If you get to OSH next summer, look them up. You'll be amazed at
how much crud can accumulate in your oil cooler.
JimB
Old December 17th 06, 04:38 PM posted to rec.aviation.piloting
Jim Macklin
Default Oil Coolers
Thanks for the link.
Merry Christmas
Have a Safe and Happy New Year
Live Long and Prosper
Jim Macklin
"Jim Burns" wrote in message
Lots of good info
You'll be amazed at
| JimB
Old December 17th 06, 07:27 PM posted to rec.aviation.piloting
Robert M. Gary
Default Oil Coolers
I had these guys O/H my Mooneys oil cooler and haven't had any
problems.
-Robert
oil coolers.... Areo classics vs Positech bd-4 flyer Home Built 1 January 29th 05 02:26 PM
Sun'n Fun Used to Be the Gathering of the Good Ol' Boys of Flying jls Home Built 29 April 7th 04 01:29 AM
Oil coolers Dan Luke Owning 14 August 13th 03 02:46 PM
Liquid to liquid coolers Paul Millner Home Built 2 July 5th 03 02:32 PM
