PC/PDA based approach plates
Old January 24th 05, 03:40 PM
Nathan Young
Default PC/PDA based approach plates
I use a tablet PC for XM Weather in flight, and figured I should add
approach plates... What vendors are available? Seattle Avionics
appears to have a good deal (~$100) with endless free plate updates.
So, I am looking for feedback on Seattle Avionics SmartPlates. Also,
looking for generic feedback regarding the use of PC/PDA based
approach plates in lieu of paper.
Nathan
Old January 25th 05, 07:09 AM
max
If your tablet supports 1024x768 resolution then Jeppview 3.0 is
actually pretty good IMO. It gives you everything from approach plates
to enroute charts. And since pretty much all their stuff is
geo-referenced it will overlay your position on all the charts and
pretty much every approach plate(given a GPS input). Great for
situational awareness.
Where/how are you positioning and viewing your tablet during flight? I
have a tablet and am finding my biggest problem is using it under
actual IFR- no really good place to position it in the 182.
-Max
Nathan
Old January 25th 05, 03:27 PM
Nathan Young
Geo-referenced or vector based is a nice asset. The Tablet PC is
connected to my Garmin, and I already run moving map software on it,
so it would be nice to add moving map plates.
I have a Cherokee 180, and fly solo 90% of the time, so the
passenger seat typically holds the charts, and now holds the tablet
PC. To view the tablet, I occasionally sneak a glance at it. If I
really need to study it, I pick it up and look at it. In both cases,
I use the autopilot as it is not a good idea to be bouncing my focus
between the panel and the front seat.
I have a Fujitsu ST4121 and it is probably too big to yoke mount, but
I have a yoke mounted 295, so I would not want to yoke mount it
anyway. The ST4121 is also a very capable computer (933MHz Pentium
III, 512MB RAM, 50GB HDD), so it is useful outside of the cockpit as
well.
One issue is cabling. Power for the ST4121, USB for the WxWorx
receiver, PCMCIA card/dongle/cable for the serial RS232 to the GPS,
and stereo cable for playing MP3s into the intercom.
In order to reduce cabling, I have been considering adding a 2nd PC to
the cockpit (an older laptop with Wifi) to act as data server,
gathering the WxWorx info + GPS signal, and then relaying them across
Wifi to the ST4121's embedded Wifi receiver. But, who knows when I
will get the time to do the programming for that...
-Nathan
Old January 25th 05, 03:31 PM
Paul Tomblin
A friend of mine made a nice little tupperware box for everything he
needed to power his laptop, WX Works reciever, GPS and all:
http://xcski.com/gallery/wxworks
I'm not sure if this is a good or a bad thing.
Probably a bad thing; most things are bad things.
-- Nile Evil *******
Approach Plates on PDA (PIREP) Stan Prevost Instrument Flight Rules 10 December 18th 04 04:21 AM
Canadian holding procedures Derrick Early Instrument Flight Rules 24 July 22nd 04 04:03 PM
Buttonville Approach Plates Defly Instrument Flight Rules 4 May 22nd 04 07:40 PM
NACO approach plates J Haggerty Instrument Flight Rules 8 April 19th 04 04:04 AM
AVIATIONTOOLBOX: I've added your approach plates. Kyler Laird Instrument Flight Rules 20 April 19th 04 12:02 AM
