Autopilot Porpoises when Mike Keyed
Old December 21st 06, 02:24 PM posted to rec.aviation.homebuilt
jls
Default Autopilot Porpoises when Mike Keyed
Also instrument needles go crazy.
Aircraft is a Lancair with antenna hidden in the horizontal stab. How
'bout directing us to some reading material about how to stop it.
Our local avionics guy says we may have to live with it, or install
external antennas, which will dirty up a Lancair in a hurry.
Jim Weir?
Thanks and happy holidays.
Old December 21st 06, 03:16 PM posted to rec.aviation.homebuilt
Jim Weir?
Check your com antenna connections. Sounds like a bad cable
shield ground allowing RF to escape and disturb sensitive circuitry.
Dan
Old December 21st 06, 03:59 PM posted to rec.aviation.homebuilt
RST Engineering
Google "ferrite balun". You could have saved us some time telling us a
little bit about what sort of antenna was hidden in the horizontal
stabilizer. Second question is why you put it in the HORIZONTAL stabilizer
when com antennas were meant to live their lives VERTICAL.
"jls" wrote in message
ps.com...
Jim Weir?
Old December 21st 06, 04:46 PM posted to rec.aviation.homebuilt
[email protected][_1_]
A friend of ours had this exact problem in his SX-300. I helped him
troubleshoot it ("OK, key the mike!" for hours on end...) while he
stood on his head fiddling with antenna wires.
He found that the culprit was the antenna wiring going up into the
tail. Since replacing that wiring would have required opening up the
vertical stab, he found that he could stop it from happening by
shielding it with strategically placed pieces of aluminum foil. He also
minimized it by re-routing the cable, and replacing some of the
connectors that were "leaking".
By doing this he was able to eliminate the porpoising on one of the two
frequencies it was happening on, and he minimized it dramatically on
the other.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old December 21st 06, 11:13 PM posted to rec.aviation.homebuilt
jls
the other.
Jay Honeck
Iowa City, IA
Pathfinder N56993
OK, men, very helpful info so far, and I'll find out more tomorrow.
Present owner (and hangar-mate) did not build the airplane and now he
finds out more about the antenna tomorrow when the builder sends
pictures and drawings.
With your gracious help we'll solve the problem.
Thanks to all of you.
Old December 22nd 06, 05:06 AM posted to rec.aviation.homebuilt
Mark Hickey
Jim Weir?
The easiest thing to try would be to clamp ferrite cores around the
input leads to the AP computer (even better if there's enough slack to
loop the cables through a larger core a couple times).
Next might be to use antenna cable that's more shielded (assuming that
the cable runs quite a bit closer to the autopilot cabling than the
antenna). Might be easier (and certainly cheaper) to just re-route
the antenna cable away from all other cables as much as possible.
And I'm sure Jim's gonna want to know a bit more about that horizontal
dipole (?) antenna you're running.
Mark "RF stands for Random Fluctuations" Hickey
Old December 22nd 06, 07:42 PM posted to rec.aviation.homebuilt
rpellicciotti
Jim Weir?
I'll take a completely different tack. Since your instrument needles
move when you key the mike, I suspect a ground loop. I would be
interested in knowing if you engine needles move when you turn on and
off other consumers like the strobes or nav lights.
I just finished working on a Lancair that had a similar problem. You
could turn the nav lights on and off and the CHT's would go up and
down. Keying the mic caused the trim indicators to change. We ended
up pulling out most of the wiring and redoing it for the plane's new
owner. Not cheap, but everything works now.
Rick Pellicciotti
Belle Aire Aviation
Old December 24th 06, 08:30 PM posted to rec.aviation.homebuilt
jls
Jim Weir?
Rick Pellicciotti
Belle Aire Aviation
Thanks so much and thanks to all the others who responded with help.
I'm going to advise hangarmate to rewire his airplane.*
The com antenna is in the vertical stab, at least one of them. The
airplane was built by one of those shops that the owner sends the kit
to. We're trying to get in touch with the builder to find out where
the other com antenna, if any, is.
*Just kidding. We'll try all the other avenues first, but fact is the
more troublesome of the two radios does do a number on the egt and cht
readouts, as well as the autopilot and some of the other instruments.
Top o' the season to you. It's summer here in WNC at 70 deg. F. and
warm sunshine.
Rogue's Gallery Update - Mike R's Helio & Mike G's Saratoga Jay Honeck Home Built 1 December 3rd 04 09:16 PM
Rogue's Gallery Update - Mike R's Helio & Mike G's Saratoga Jay Honeck Owning 0 December 3rd 04 08:25 PM
PA28-181 - Stuck Mike - King Silver Crown Roy Page Owning 2 October 29th 04 03:36 AM
Bendix King KMA20 - Stuck mike open. Roy Page Owning 2 October 12th 04 03:40 PM
We always used the throat mike. ArtKramr Military Aviation 9 March 30th 04 04:07 PM
