How do a 61-year old retired airline pilot and a flight instructor with
40 years of experience crash and die? This happened two days ago in Central Ohio. The pilot had just purchased the 1966 Mooney M20F and was getting on a check out flight with the instructor. Witnesses report the aircraft came straight down. The owner shown in the FAA database is an 84 year old who had sold the aircraft only a couple days prior to the accident. IDENTIFICATION Regis#: 9596M Make/Model: MO20 Description: M20, M20A/B/C/D/E/F/G/J/L/R/S, M20K/M (T Date: 12/27/2006 Time: 1955 Event Type: Accident Highest Injury: Fatal Mid Air: N Missing: N Damage: Substantial LOCATION City: MOUNT GILEAD State: OH Country: US DESCRIPTION ACFT CRASHED UNDER UNKNOWN CIRCUMSTANCES, THE TWO PERSONS ON BOARD WERE FATALLY INJURED, 8 MILES FROM MOUNT GILEAD AIRPORT, MOUNT GILEAD, OH INJURY DATA Total Fatal: 2 # Crew: 2 Fat: 2 Ser: 0 Min: 0 Unk: # Pass: 0 Fat: 0 Ser: 0 Min: 0 Unk: # Grnd: Fat: 0 Ser: 0 Min: 0 Unk: WEATHER: MNN 271953Z AUTO 26008KT 10SM FEW100 04/M03 A3007 OTHER DATA Activity: Unknown Phase: Unknown Operation: OTHER Departed: Dep Date: Dep. Time: Destination: Flt Plan: Wx Briefing: Last Radio Cont: Last Clearance: FAA FSDO: COLUMBUS, OH (GL07) Entry date: 12/28/2006 N9596M is Assigned Aircraft Description *Serial Number* 670173 *Type Registration* Individual *Manufacturer Name* MOONEY *Certificate Issue Date* 07/27/2004 *Model* M20F *Status* Valid *Type Aircraft* Fixed Wing Single-Engine *Type Engine* Reciprocating *Pending Number Change* None *Dealer* No *Date Change Authorized* None *Mode S Code* 53254514 *MFR Year* 1966 *Fractional Owner* NO |
"john smith" wrote: How do a 61-year old retired airline pilot and a flight instructor with 40 years of experience crash and die? This is one of those accidents where it is difficult even to guess a likely cause. Pilot had a heart attack while practicing stalls and froze on the controls? You have to use a lot of imagination to come up with a scenario that would kill these two aviators on a checkout flight. Weird. -- Dan C172RG at BFM |
john smith wrote:
How do a 61-year old retired airline pilot and a flight instructor with 40 years of experience crash and die? The same way as any other pilots. This happened two days ago in Central Ohio. The pilot had just purchased the 1966 Mooney M20F and was getting on a check out flight with the instructor. Witnesses report the aircraft came straight down. You can't trust most aircraft accident witnesses. It could have been due to any of several reasons. Hopefully, the NTSB will figure it out. Matt |
("john smith" wrote)
This happened two days ago in Central Ohio. The pilot had just purchased the 1966 Mooney M20F and was getting on a check out flight with the instructor. Witnesses report the aircraft came straight down. I read a link (in rec.aviation) a while back about a person investigating the possibility that CO poisoning might be a culprit in more crashes than people realize. Sounds like an interesting theory, except for my thought that there were toxicology tests for that. Maybe his theory is they're not catching it - forensically. Memory fails me on the details of the research in the link. I know some past exhaust issues have involved higher pressure vs. lower pressure areas - Piper's tail cone 'low pressure zone' was one problem spot for CO gas to find its way into the cabin, IIRC. I know many planes are leaky ...but if you do have a somewhat tight cockpit, would a (small) fresh air feed, slightly pressurizing the cabin (perhaps with a small computer type fan), be good insurance against CO gas intrusion? Montblack |
Montblack wrote:
("john smith" wrote) This happened two days ago in Central Ohio. The pilot had just purchased the 1966 Mooney M20F and was getting on a check out flight with the instructor. Witnesses report the aircraft came straight down. I read a link (in rec.aviation) a while back about a person investigating the possibility that CO poisoning might be a culprit in more crashes than people realize. Sounds like an interesting theory, except for my thought that there were toxicology tests for that. Maybe his theory is they're not catching it - forensically. Memory fails me on the details of the research in the link. I know some past exhaust issues have involved higher pressure vs. lower pressure areas - Piper's tail cone 'low pressure zone' was one problem spot for CO gas to find its way into the cabin, IIRC. I know many planes are leaky ...but if you do have a somewhat tight cockpit, would a (small) fresh air feed, slightly pressurizing the cabin (perhaps with a small computer type fan), be good insurance against CO gas intrusion? You mean like this, for example... CINCINNATI COUPLE Cockpit fumes knock out pair while plane taxiing Saturday, December 30, 2006 ASSOCIATED PRESS A small plane drove off a taxiway at a northeastern Indiana airport before takeoff after the pilot and passenger, both of Cincinnati, apparently were overcome by fumes. Others at the Delaware County Airport in Muncie, Ind., pulled Thomas and Marilyn Kroll from the plane Wednesday night. They were unconscious and taken to a hospital. Gene Marlin, the pilot of a nearby plane, drove his plane up to the Krolls’ aircraft. "Whenever I got there, the line-boy had the door open but the gentleman and the lady were still in the airplane and the airplane was running," Marlin told Indianapolis television station WTHR. "I just shut the engine off and pulled the people from the airplane out." Marlin said neither person regained consciousness before emergency crews took them. "The way the glass on the inside of the cockpit was all steamed up ... it was all kind of glazed over, but it wasn’t ice. And the smell," he said. "The fumes were real strong in there." The Krolls were taken by helicopter to Wishard Memorial Hospital in Indianapolis. Marilyn Kroll was listed in serious condition and Thomas Kroll was in fair condition. |
"Montblack" wrote I know many planes are leaky ...but if you do have a somewhat tight cockpit, would a (small) fresh air feed, slightly pressurizing the cabin (perhaps with a small computer type fan), be good insurance against CO gas intrusion? Somewhat tight is the key phrase. I don't think most are tight enough for a muffin fan to be able to create positive pressure. Add to that, fan blade type fans are very, very poor at creating pressure. Squirrel cage blowers are used where pressure is needed. That is why house air handlers (furnaces) have squirrel cage blowers, as do heater blowers in cars. Still, a fresh air blower will not help where the cause of the CO is a cracked heat exchanger. (muff) The other problems are fixed by sealing off the leaks, especially in low pressure areas, but you knew that. -- Jim in NC |
The pressure inside of the fuselage at speed will always be lower than the ambient outside air pressure. A ram air
source out on the wing and away from the engine compartment can provide fresh air, but a little muffin fan will not do it. Does everyone have a CO monitor on board? "Morgans" wrote in message ... : : "Montblack" wrote : : I know many planes are leaky ...but if you do have a somewhat tight : cockpit, would a (small) fresh air feed, slightly pressurizing the cabin : (perhaps with a small computer type fan), be good insurance against CO gas : intrusion? : : Somewhat tight is the key phrase. I don't think most are tight enough for a : muffin fan to be able to create positive pressure. : : Add to that, fan blade type fans are very, very poor at creating pressure. : Squirrel cage blowers are used where pressure is needed. That is why house : air handlers (furnaces) have squirrel cage blowers, as do heater blowers in : cars. : : Still, a fresh air blower will not help where the cause of the CO is a : cracked heat exchanger. (muff) : : The other problems are fixed by sealing off the leaks, especially in low : pressure areas, but you knew that. : -- : Jim in NC : : |
Blueskies writes:
The pressure inside of the fuselage at speed will always be lower than the ambient outside air pressure. Really? Why? -- Transpose mxsmanic and gmail to reach me by e-mail. |
Locally, we had two CFI's pull the wings and tail (IIRC) off of a Piper when
they were on a checkout flight. http://www.ntsb.gov/ntsb/brief.asp?e...24X01489&key=1 I'm not saying this is what happened in the Mooney - the possibilities are endless, but the point is that having two highly qualified pilots aboard doesn't prevent pilot error or any other type of accident. KB "john smith" wrote in message ... How do a 61-year old retired airline pilot and a flight instructor with 40 years of experience crash and die? This happened two days ago in Central Ohio. The pilot had just purchased the 1966 Mooney M20F and was getting on a check out flight with the instructor. Witnesses report the aircraft came straight down. The owner shown in the FAA database is an 84 year old who had sold the aircraft only a couple days prior to the accident. IDENTIFICATION Regis#: 9596M Make/Model: MO20 Description: M20, M20A/B/C/D/E/F/G/J/L/R/S, M20K/M (T Date: 12/27/2006 Time: 1955 Event Type: Accident Highest Injury: Fatal Mid Air: N Missing: N Damage: Substantial LOCATION City: MOUNT GILEAD State: OH Country: US DESCRIPTION ACFT CRASHED UNDER UNKNOWN CIRCUMSTANCES, THE TWO PERSONS ON BOARD WERE FATALLY INJURED, 8 MILES FROM MOUNT GILEAD AIRPORT, MOUNT GILEAD, OH INJURY DATA Total Fatal: 2 # Crew: 2 Fat: 2 Ser: 0 Min: 0 Unk: # Pass: 0 Fat: 0 Ser: 0 Min: 0 Unk: # Grnd: Fat: 0 Ser: 0 Min: 0 Unk: WEATHER: MNN 271953Z AUTO 26008KT 10SM FEW100 04/M03 A3007 OTHER DATA Activity: Unknown Phase: Unknown Operation: OTHER Departed: Dep Date: Dep. Time: Destination: Flt Plan: Wx Briefing: Last Radio Cont: Last Clearance: FAA FSDO: COLUMBUS, OH (GL07) Entry date: 12/28/2006 N9596M is Assigned Aircraft Description *Serial Number* 670173 *Type Registration* Individual *Manufacturer Name* MOONEY *Certificate Issue Date* 07/27/2004 *Model* M20F *Status* Valid *Type Aircraft* Fixed Wing Single-Engine *Type Engine* Reciprocating *Pending Number Change* None *Dealer* No *Date Change Authorized* None *Mode S Code* 53254514 *MFR Year* 1966 *Fractional Owner* NO |
The most probable answer is he made a mistake. And if not the case for this accident, it is probably the case for many other head scratchers. Consider how many car drivers crash and die, and how much more experienced they are driving than any of us are experienced flying. People make mistakes, and aircraft themselves can fail. Jose -- He who laughs, lasts. for Email, make the obvious change in the address. |
| Thread Tools | |
| Display Modes | |
| Former Head of 'Star Wars' Program says 9/11 an Inside Job | [email protected] | Piloting | 9 | May 5th 06 01:13 AM |
| Former Head of 'Star Wars' Program says 9/11 an Inside Job | [email protected] | Piloting | 3 | May 3rd 06 11:09 AM |
| Former Head of 'Star Wars' Program says 9/11 an Inside Job | Tank Fixer | Piloting | 1 | May 2nd 06 10:41 PM |
| Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 06:07 PM |
| Bothersome Phillips Head Screws | Larry Smith | Home Built | 48 | January 10th 04 05:26 AM |
