Aircraft Checkout Flights
Old December 30th 06, 08:56 PM posted to rec.aviation.piloting
john smith
Default Aircraft Checkout Flights
This is a companion posting to the one entitled Head Scratcher.
When I do an aircraft checkout, I will only fly them during the
daylight. I don't want to be fumbling around in the dark in an
unfamiliar aircraft trying to find the right thing-a-ma-jig to throw,
pull or twist.
Once I am comfortable with the aircraft during daylight, I would feel at
ease to practice night landings.
Do any of the instructors on this group perform initial aircraft
checkouts at night as a matter of normal practice?
Even with an experienced pilot, a complex aircraft will provide a
certain amount of learning curve before achieving proficiency.
Old December 30th 06, 09:06 PM posted to rec.aviation.piloting
Andrew Sarangan
If the pilot wanting the checkout has never flown that type of aircraft
before, I do the checkout during the day. Otherwise I do the checkout
any time that is convenient.
pull or twist.
Old December 30th 06, 09:19 PM posted to rec.aviation.piloting
Dan Luke
"john smith" wrote:
Even with an experienced pilot, a complex aircraft will provide a certain
The only time I ever got checked out in an unfamiliar aircraft at night, the
alternator failed.
Dan
C172RG at BFM
Old December 30th 06, 10:11 PM posted to rec.aviation.piloting
Jose[_1_]
When I do an aircraft checkout, I will only fly them during the daylight. I don't want to be fumbling around in the dark in an unfamiliar aircraft trying to find the right thing-a-ma-jig to throw, pull or twist.
I think this is a good policy when checking out in a new type, or a
significant cockpit variant. However, if I've been flying Archers
forever, and I go to a new airport where I (of course) need to get a
checkout before they will let me fly =their= archer, I see no reason to
have to do that one in the daytime. So, it depends on what you really
mean by a "checkout".
If you mean a checkout in an airplane which is significantly new to the
pilot, then yes, I agree with you.
Jose
He who laughs, lasts.
Old December 31st 06, 05:39 AM posted to rec.aviation.piloting
Morgans[_5_]
the alternator failed.
You must be living right. NOT ! ! ! g
I'll bet you are ready to jump into another one, and do it again, right?
Old December 31st 06, 06:09 AM posted to rec.aviation.piloting
NW_Pilot
"john smith" wrote in message
Do any of the instructors on this group perform initial aircraft checkouts
Check Out Flight Whats That????
Old December 31st 06, 01:24 PM posted to rec.aviation.piloting
Dan Luke
One's enough.
The CFI who checked me out knew beforehand the alt. was flakey and didn't
tell me. As we have seen recently, having a CFI aboard doesn't necessarily
confer any extra safety.
Dan
C172RG at BFM
Old December 31st 06, 01:40 PM posted to rec.aviation.piloting
Bob Noel
Having a CFI aboard doesn't necessarily confer *sufficient* extra safety.
Bob Noel
Looking for a sig the
lawyers will hate
Old December 31st 06, 02:16 PM posted to rec.aviation.piloting
Jim Macklin
Flying a known "flakey" aircraft, day or night isn't wise.
But the battery should keep plenty of juice for the time
required to get back to the airport, as long as the pilot
detects the alternator failure when it happens and takes the
proper actions promptly.
You need NAV lights and a radio is nice to have. You can
crank the gear down in a complex aircraft and turn off
landing lights, radar, autopilots, the stereo, ventilation
fans, etc.
In fact, if the alternator didn't fail, I'd be tempted to
pull the CB on it if the student had not seen what happens.
But a night checkout if carrying the proper flashlights, I
have LED headlights, penlights, full and mini Mag lights
(AA and D) and I carry the LED pen even in the daylight.
A "blindfold" cockpit check may not be a bad idea.
"Dan Luke" wrote in message
aircraft at night,
it again, right?
| One's enough.
flakey and didn't
doesn't necessarily
| Dan
| C172RG at BFM
Old December 31st 06, 03:31 PM posted to rec.aviation.piloting
Jose[_1_]
It sometimes reduces safety, especially if the pilots suffer "instructor
in command syndrome".
Jose
Contact Approach -- WX reporting [email protected] Instrument Flight Rules 64 December 22nd 06 01:43 PM
Air Force Aerial Refueling Methods: Flying Boom versus Hose-and-Drogue Mike Naval Aviation 26 July 11th 06 11:38 PM
I want to build the most EVIL plane EVER !!! Eliot Coweye Home Built 237 February 13th 06 03:55 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 07:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 03:04 PM
