Ok, what about the BD5
Old January 4th 07, 04:50 PM posted to rec.aviation.homebuilt
Whome?
Default Ok, what about the BD5
Ok, we have roasted the Mini 500, how about the BD5?
First things first, forget the jet. So few people could ever afford such a
thing it hardly seems viable from the get-go. But why has such a popular
design (on paper) found so little success? Thousands of people instantly fell
in love with it immediatley when it was introduced in what, the late 1060s.
So after 45 years or so, and so many parts floating around, what has so
greatly hampered this little birds sucess?
Looking back with my limited aviation experience, and yes I was there. I
visited Newton Kansas in the early 70s, met Jim Bede, and sat in one of the
completed prototypes in the show room floor. But the only thing that seems
apparent to my inexperience is the lack of a reliable piston power plant, due
to weight and power restrictions - and it's a VERY high performance aircraft,
that was gobbled up by a lot of low performance pilots.
Some time around 1980 or so, I saw and airshow demonstration by the Coor's
Silver Bullet, and the craft performed some amazing manuvers. So will this
airframe fly well if properly powered? Is there any way to make one a
workable craft if a pilot is qualified for such a high performance ship?
Let's see how many people can respond with a fair discussion, and ignore
Juan's bias of coarse, and examine the real reason this bird has never
soared.
Whome?
Old January 4th 07, 06:14 PM posted to rec.aviation.homebuilt
BobR
Probably lots of different reasons why it has not achieved the flying
success it should have but you hit on the biggest and probably most
important, no suitable engine. Yeah, I know that there are now many
good engines that could power it well but its time was then and this is
now. It was ahead of its time then and the needed engine wasn't
available. Now, its time has passed and few people are really
interested a plane with such demanding characteristics and limited
usefulness.
Yes, I was one of the many that fell in love with the BD5 the very
first time I saw it. It was then and remains a beautiful design that
seems to scream "FLY ME". It will fly well if properly powered, of
that there is no argument. I also believe there is little argument and
ample historical evidence to show that it is a high performance
aircraft with little room for error on the pilots part.
Ultimately though, I think the biggest reason it has not rebounded over
the years was Van's RV-4, RV-6, RV-7, RV-8 and RV-9 aircraft. Those
aircraft were slightly bigger, appealed to more pilots, were easier to
build, used proven available engines, offered performance galore and
were far easier for the average pilot to fly. They have literally
pushed most other kit manufacturers into the also-ran category. When
Bede first offered the BD5 as a KIT, it was a rather new concept.
Previous designs were just that, designs and you had to build them from
scratch. The idea of buying kits and assembling the parts to produce
your own plane appealed to a lot of people then and still does today.
Van's has taken that concept well beyond its origin of just a boxs full
of cut sheet metal and delivered on a true assembly kit. That was the
promise that the BD5 never really delivered.
soared.
Whome?
Old January 4th 07, 09:21 PM posted to rec.aviation.homebuilt
Morgans[_2_]
available.
I don't think that is quite true. There may be better engines now, but that
is only part of the problem with the piston engine in the BD-5.
The link escapes me now, but there were tremendous problems with torsional
harmonics, tearing apart everything, all the way along the drive train.
Beef up the driveshaft, and the clutch tore apart. Fix the clutch, and the
engine mounts cracked, beef them up, and something else broke. So on, and
so on.
Anyone happen to have the links handy that addressed all of these issues?
It was a very interesting read, although a lot of material. I think they
would answer, with great detail, why the 5 never caught on. They self
destructed.
Although I have never flown one, the experienced pilots that did said things
like; it would eat most people alive, that it scared them, and so on.
Old January 4th 07, 10:38 PM posted to rec.aviation.homebuilt
Whome?
available.
so on.
destructed.
Are you thinking about this one?
http://www.prime-mover.org/Engines/T.../contact1.html
I ran across it while doing a little research prior to this post.
I think all piston engine designs suffer too much from torsional vibration
problems. But most are just not serious enough to be destructive.
Whome?
Old January 4th 07, 10:58 PM posted to rec.aviation.homebuilt
Dale Alexander
Too many years ago to annouce publically, a friend of mine inquired with me
about sawing the gearbox off a Suzuki 750 Water-buffalo. For those of you
who are history impaired regarding two-stroke motorcycles, that engine came
from the GT750 and was a three cylinder two-stroke...or a two cylinder three
stroke...I don't remember
Anyway, with mild port work and a little boost in compression, the 750 would
probably put out 80 horsepower all day long, and Suzuki two strokes of that
time were known for being as reliable as a fire hydrant. The engine would
have weighed maybe 70-80 lbs, but required a water cooling system. And would
have been thirsty...
My friend had 900 hours in motor gliders at the time, I had maybe 20 in GA.
In retrospect, I'm glad the subject went away after a brief period of time.
Dale Alexander
"Whome?" wrote in message
available.
that
so on.
destructed.
things
Whome?
Old January 4th 07, 11:10 PM posted to rec.aviation.homebuilt
Dan[_2_]
6 cylinder one stroke?
Dan, U.S. Air Force, retired
Old January 5th 07, 05:43 AM posted to rec.aviation.homebuilt
Morgans[_2_]
Yep, that's it,
Old January 4th 07, 11:17 PM posted to rec.aviation.homebuilt
Juan Jimenez[_1_]
"Morgans" wrote in message
available.
that is only part of the problem with the piston engine in the BD-5.
No BD-5 has suffered an inflight failure involving either the airframe or
the drive train hardware.
the engine mounts cracked, beef them up, and something else broke. So on,
and so on.
destructed.
My web site includes a library of material that includes things like this.
Help yourself, that's why I put it there, the good _and_ the bad.
Posted via a free Usenet account from http://www.teranews.com
Old January 5th 07, 01:08 AM posted to rec.aviation.homebuilt
Kyle Boatright
"Juan Jimenez" wrote in message
available.
torsional harmonics, tearing apart everything, all the way along the
drive train.
Correct, but that statement avoids the issue. There are/were unsolved
torsional problems. During the so-called development period for the design
they fought a number of problems including broken drive shafts, broken
engine mounts, etc. which were results of various torsional issues which
were never completely resolved.
The only reason there were no in-flight failures of drivetrain hardware is
that the people involved with the design, both the Bede team and tinkerers
over the last 30 years have been dilligent and lucky enough to identify
failures and pending failures on the ground, rather than discovering the
failures in the very rarely demonstrated airborne mode of the design.
on, and so on.
destructed.
Old January 5th 07, 04:26 PM posted to rec.aviation.homebuilt
Juan Jimenez[_1_]
"Kyle Boatright" wrote in message
available.
drive train.
torsional problems.
No, that _is_ the issue. No "torsional problems" caused any issues with
incidents or accidents, period. To suggest that this issue is one of the
aircraft's shortcomings is completely incorrect.
During the so-called development period for the design they fought a
number of problems including broken drive shafts, broken engine mounts,
etc. which were results of various torsional issues which were never
That, Kyle, is a very old document. The drive issues were resolved a LONG
time ago and a man by the name of Jerry Kauth has made a good living over
the years selling the version of the drive system that was developed long
ago to address any issues they found.
You need to refer to the BD-5 specific documentation, not something someone
else wrote that happened to reference information about the BD-5.
Design testing. What a concept. Tell me something I don't know.
