Why does the shuttle throttle on ascent?
Old January 7th 07, 02:36 AM posted to rec.aviation.piloting,sci.space.history,sci.space.shuttle
Danny Deger
Default Why does the shuttle throttle on ascent?
Why does the shuttle throttle to 3 Gs on ascent?
Danny Deger
Old January 7th 07, 02:43 AM posted to rec.aviation.piloting,sci.space.history,sci.space.shuttle
Mxsmanic
Danny Deger writes:
The real Shuttle throttles back during ascent at a certain point in
order to reduce aerodynamic stresses as it rises through the
atmosphere.
Ron Natalie
I don't know about G's but the shuttle adjust the engine thrust
up and down at various times in the launch based on the dynamic
pressures involved.
Old January 7th 07, 02:59 AM posted to rec.aviation.piloting,sci.space.history,sci.space.shuttle
John Doe
As the fuel is burned/jettisoned the engines have a smaller vehicle mass
to accelerate. So to maintain an acceptable acceleration level, you
throttle back engines.
Also, as you leave the atmopsphere, there is less and less air resistance,
so you also need less power to maintain the desired acceleration level.
And early in the ascent, they throttle back to ensure the shuttle's air
speed isn't too great as it travels through the still dense atmosphere
since it would create too much aerodynamic drag.
Old January 7th 07, 03:02 AM posted to rec.aviation.piloting,sci.space.history,sci.space.shuttle
John T
m
pressures involved.
"'Go' for throttle up."
My generation's equivalent of "Where were you when Kennedy got shot?"
John T
http://sage1solutions.com/blogs/TknoFlyer
Reduce spam. Use Sender Policy Framework: http://openspf.org
____________________
Old January 7th 07, 03:10 AM posted to rec.aviation.piloting,sci.space.history,sci.space.shuttle
Dudley Henriques
"Danny Deger" wrote in message
Danny Deger
As the shuttle ascends, the dynamic pressure (in slugs/sq.in) increases as
the square of the velocity. The shuttle is throttled back to 65% thrust to
avoid over stress at a speed computed under what is called critical q.
As the shuttle ascends, it is ascending into lower air density (which of
course transfers into a lowering dynamic pressure). The throttling back
takes the shuttle through a transition area during the ascent that ends as
the lowering air density meets the parameters that allow throttle up. This I
believe occurs at about 35 to 37K.
The point where lowering air density meets the ability to throttle up again
is the max q for the shuttle. (Max q meaning maximum dynamic pressure)
After reaching max q, the shuttle is go for throttle up as the increasing
velocity past max q will never exceed the structural limitations of the
shuttle due to it's entrance into lower air density that doesn't have the
ability to overstress the structure.
Hope this helps a bit.
Dudley Henriques
Old January 7th 07, 03:15 AM posted to rec.aviation.piloting,sci.space.history,sci.space.shuttle
Henry Spencer
This is partly for the benefit of the passengers -- it's thought that a
healthy adult can be expected to take about 3G without testing -- and
partly to limit structural loads. (The Saturn V first stage shut down
its center engine early for the latter reason.)
There is also an earlier bit of throttle reduction, during the SRB burn,
done to keep speed down until the shuttle is out of the thickest air.
spsystems.net is temporarily off the air; | Henry Spencer
mail to henry at zoo.utoronto.ca instead. |
Old January 7th 07, 03:55 AM posted to rec.aviation.piloting
Dudley Henriques
On the way;
DH
"Richard Riley" wrote in message
On Sat, 6 Jan 2007 22:10:34 -0500, "Dudley Henriques"
Dudley Henriques
Dudley, would you email me off list? (not on this topic)
Richard at riley dot net
Old January 7th 07, 04:05 AM posted to rec.aviation.piloting,sci.space.history,sci.space.shuttle
David Kazdan
Dudley:
Isn't dynamic pressure expressed in pressure units, pounds per
square inch (or SI, Pascals: newtons/sq. meter)? Mass density, which
you mention later, is in slugs/cu.in or cu.ft (or SI, Kg/cu.meter).
Thanks for all your good posts, I've learned a lot from them over
the years.
David
Danny Deger
Dudley Henriques
Old January 7th 07, 04:31 AM posted to rec.aviation.piloting,sci.space.history,sci.space.shuttle
Danny Deger
Default So Navy Fighter pilots can fly the shuttle
The answer is:
So Navy Fighter pilots can fly the shuttle :-)
Danny Deger
P.S. I was an Air Force figher pilot.
How to get maximum height on a winch launch? Dan G Soaring 38 December 22nd 16 12:29 AM
NASA: "The Shuttle Was a Mistake" AES Piloting 39 October 10th 05 01:10 PM
Is possible to pair a Saitek X35 throttle and a MS Sidewinder Pro? Riccardo Simulators 3 December 24th 03 06:07 PM
Boeing: Space shuttles to last into next decade JohnMcGrew Piloting 17 October 24th 03 09:31 PM
Cause of Columbia Shuttle Disaster. Mike Spera Owning 2 August 31st 03 03:11 PM
