Commencing a GPS approach from a fix other than the FAF
Old January 16th 07, 05:55 AM posted to rec.aviation.ifr
Chris Quaintance
Default Commencing a GPS approach from a fix other than the FAF
Hi Folks-
Please forgive what is probably a simple question regarding GPS
approaches. I am new the the /G world. I was out flying my 182P today
to do some practice approaches. The airplane is equipped with a GNS480
and I have a Garmin 296 on the yolk. I was buzzing around NW of the
Salinas airport on vectors and was told to expect the GPS13 approach as
I requested. So far, so good. Fight plan entered into the 480 and the
296, approach loaded on both.
Here's the approach:
http://www.naco.faa.gov/d-tpp/0701/00363G13.PDF
NorCal cleared me direct EWTOF at 3200, cleared for the approach. When
looking at the approach on both the 480 and the 296, it seemed to
commence at UBBEP rather than EWTOF. No way for me to go direct EWTOF
then on to the rest of the procedure. So, I fiddled around a bit and
was unable to come up with a graceful solution. Selecting Direct To, I
was hoping to easily find EWTOF - no joy. I had to dig up EWTOF from
the nearest list, and then the rest of the approach "disappeared." I
ended up arming VTF on the 480, then used the 296 to navigate direct to
EWTOF. By then, the VTF mode on the 480 picked me up properly and I
was in good shape. Ugly, but it worked (fortunately, it was clear and a
million). And how about that synthetic glidescope! Very cool!
So, at first I figured that there was a problem with the database
versus my Jepp chart. However, the problem repeated itself on the
GPS31 approach to KRHV:
http://www.naco.faa.gov/d-tpp/0701/05591R31R.PDF
I was cleared direct ECYON, then for the approach. Both Garmins
"wanted" me to head for OZNUM.
What is the best way to handle this situation? Clearly I am doing
something wrong, because this has to easier than I made it! Is it as
simple as amending the current flight plan and inserting a waypoint
before the destination? That is, in the first case, inserting EWTOF
before KSNS on the flight plan and then choosing Direct To? I would
think that EWTOF should be part of the procedure as it is charted on
the approach plate. It sucks to have to enter it in by hand to the
flight plan. Do all of the GPS approaches in the 480/296 database
commence only with the FAF?
Thanks for your insight.
Cheers,
--Chris Q.
Old January 16th 07, 10:59 AM posted to rec.aviation.ifr
Sam Spade
I don't know how an approach is selected in the 480 (I am a 530 user)
but the TSO specs require that all IAFs, feeder fixes and vectors be
offered when you select an approach (this is not so with the 296,
though, because it is not an IFR device).
So, in this case I would select MOVER, which would yield an approach
"flight plan" I would not activate the approach or that would yield a
course direct to MOVER.
Then I would highlight EWTOF with the cursor and go direct-to. EWTOF
would now be the active waypoint with the FAF and subsequent fixes still
in line to sequence once I pass EWTOF, etc.
MOVER
EWTOF
UBBEB
GUHWO
MARNA
Chris Quaintance wrote:
Hi Folks-
Cheers,
--Chris Q.
Old January 16th 07, 02:01 PM posted to rec.aviation.ifr
Dave Butler
Hi Folks-
This is a bum clearance from the get-go. You should be cleared either to
an IAF or given vectors to the final approach course. EWTOF is not an
IAF. So one solution would be to say 'unable' and ask for direct to an
IAF or vectors. I think there is some kind of exception, though, for /G
equipped aircraft to be cleared direct to a fix that is on the final
approach course, as EWTOF is.
When you selected the procedure from the database, it looks like the
only IAF is MOVER, so you must have selected the approach starting from
MOVER. So EWTOF should have been added to the flight plan (no?) and you
should be able to select DIRECT EWTOF from the flight plan(?), rather
from the NRST list. Then I think the 480 would have auto-sequenced you
through the rest of the approach.
Bum clearance again. ECYON is not an IAF, but as above, is on the final
approach course.
You shouldn't have to "insert" it. It should have been added to the
flight plan when you selected the approach starting from MOVER. Did you
remember to EXECUTE the flight plan change? Did you EXPAND the flight
plan to see all the waypoints? I think EWTOF/ECYON should have been there.
In the 480, they all commence with an IAF (not FAF). In the 296, I think
only the FAF is shown on approaches. The 296 is only for
situational-awareness, after all. You can have an output from the 480
that automatically copies the flight plan from the 480 to the 296. I do
that with my 396. Then the 296/396 knows about all the same waypoints
as the 480.
You might want to join the GNS480 users group at
http://groups.yahoo.com/group/gns480-users/
Dave
Old January 16th 07, 02:25 PM posted to rec.aviation.ifr
Roy N5804F
If it works anything like the 530 you would select EWTOF in the flight plan
and hit the Direct To
No ?
Roy
Piper Archer N5804F
"Dave Butler" wrote in message
Hi Folks-
IAF. So one solution would be to say 'unable' and ask for direct to an IAF
When you selected the procedure from the database, it looks like the only
IAF is MOVER, so you must have selected the approach starting from MOVER.
So EWTOF should have been added to the flight plan (no?) and you should be
able to select DIRECT EWTOF from the flight plan(?), rather from the NRST
list. Then I think the 480 would have auto-sequenced you through the rest
of the approach.
approach course.
You shouldn't have to "insert" it. It should have been added to the flight
plan when you selected the approach starting from MOVER. Did you remember
to EXECUTE the flight plan change? Did you EXPAND the flight plan to see
situational-awareness, after all. You can have an output from the 480 that
automatically copies the flight plan from the 480 to the 296. I do that
with my 396. Then the 296/396 knows about all the same waypoints as the
480.
Dave
Old January 16th 07, 02:59 PM posted to rec.aviation.ifr
Sam Spade
approach course.
ECYON is the intermediate fix. A change in ATC policy went into effect
almost one year ago to permit direct clearances to the IF on RNAV IAPs
only. It is covered in the AIM and was the subject of a thread here a
few months ago.
Old January 17th 07, 08:56 AM posted to rec.aviation.ifr
Chris Quaintance
snip
EWTOF was nowhere to be found.
Yes, I did execute the flight plan change and expand the plan to see
the waypoints. Again, UBBEP was the first waypoint of the approach. I
verified this behavior with the 480 sim.
as the 480.
Well, in my experience, the two approaches I referenced in my initial
post commence with the FAF on the 480. We'll leave the 296 on the yoke
out of it (even if there's yolk on my face!).
So, either I'm doing something incorrectly whilst loading the approach,
or there is some inconsistency or problem with these approaches and my
setup.
Interestingly enough, I was able to spend a very brief time behind a
530 today and it seemed to have "better" behavior in this regard. I
easily was able to commence the approach (to a different airport) from
a variety of fixes that were available on the plate.
I have already done so. Thanks for the lead.
Appreciate your time!
--Chris
Old January 16th 07, 08:03 PM posted to rec.aviation.ifr
.... I have a Garmin 296 on the yolk.
So, I guess you ended up with egg on your face?
Old January 17th 07, 01:34 AM posted to rec.aviation.ifr
Roy Smith
"Chris Quaintance" wrote:
Hi Folks-
Yeah, right, you got a bum clearance. I had a similar experience not long
ago and wrote about it here (http://tinyurl.com/yt8vkn). It's pretty
common.
The problem is that while from the point of view of somebody sitting in a
dark room watching blips move around a screen, it's a perfectly reasonable
thing to have you do, the software in the GPS wants you to either start the
approach from an IAF, or get vectors to final. It would be nice if
controllers gave clearances that were flyable, but the often don't, and
then you're struggling to figure out how to tell the GPS to do something it
doesn't want to do.
Old January 17th 07, 02:04 AM posted to rec.aviation.ifr
Sam Spade
Hi Folks-
common.
doesn't want to do.
Roy,
This handling is now approved and is no problem whatsoever with a Garmin
400 or 500.
Is it with the 480?
Old January 17th 07, 02:09 AM posted to rec.aviation.ifr
Mike Adams[_2_]
400 or 500.
Is it with the 480?
It works much the same on the 480. You have to put in the approach transition from the applicable IAF,
MOVER in this case, Execute it, and then do a Direct-to EWTOF as a separate action. The only
problem, mentally, is that you have to look on the chart to find the applicable transition that contains the
waypoint you're looking for, rather than being able to select it directly on the approach menu.
R172K Approach Configuration facpi Instrument Flight Rules 10 January 5th 07 03:58 PM
RNAV vectors Dan Luke Instrument Flight Rules 74 December 26th 06 10:31 PM
Trust those Instruments.... Trust those Instruments..... A Lieberman Instrument Flight Rules 1 May 2nd 06 03:54 PM
Approach Question- Published Missed Can't be flown? Brad Z Instrument Flight Rules 8 May 6th 04 04:19 AM
Why is ADF or Radar Required on MFD ILS RWY 32 Approach Plate? S. Ramirez Instrument Flight Rules 17 April 2nd 04 11:13 AM
