How wide is an NDB approach course?
Old January 16th 07, 09:28 PM posted to rec.aviation.ifr
Jose
Default How wide is an NDB approach course?
What is the protected area under an NDB approach course? Since the
course guidance is cruder than an ILS, I'd expect it would be wider, but
how much wider? I ask also in the context of when I should consider
myself "established" on course (for purposes of descent).
Jose
He who laughs, lasts.
Old January 16th 07, 10:18 PM posted to rec.aviation.ifr
Bill Zaleski
On Tue, 16 Jan 2007 21:28:12 GMT, Jose
Jose
When within 10 degrees of the published course.
Old January 16th 07, 10:23 PM posted to rec.aviation.ifr
Jose
When within 10 degrees of the published [NDB approach] course.
Thanks. I take it the course is then 20 degrees wide, with some lesser
protected area on the outskirts.
Jose
Old March 4th 07, 09:23 PM posted to rec.aviation.ifr
Andrey Serbinenko
Just ran across this (from Instrument Procedures Handbook, FAA-H-8261-1,
page 4-6):
The International Civil Aviation Organization (ICAO) definition of
established is considered as being within half full scale deflection
for the ILS and VOR, or within +/- 5 degrees of the required bearing
for the nondirectional radio beacon (NDB).
Andrey
Jose
Old March 5th 07, 04:20 AM posted to rec.aviation.ifr
Jose
page 4-6):
Thanks. That's very intersting and helpful.
Jose
Humans are pack animals. Above all things, they have a deep need to
follow something, be it a leader, a creed, or a mob. Whosoever fully
understands this holds the world in his hands.
Old January 17th 07, 12:50 AM posted to rec.aviation.ifr
Sam Spade
Jose
There is no policy or rule to support that.
Old January 17th 07, 04:27 AM posted to rec.aviation.ifr
Bill Zaleski
On Tue, 16 Jan 2007 16:50:04 -0800, Sam Spade
Jose
He asked when he should consider himself established for the purpose
of descent. Have you got better guideline to follow when in a cockpit
looking at an instrument panel? In the absence of policy or rules, as
you say, what do you suggest a better answer would be?
Old January 21st 07, 12:44 AM posted to rec.aviation.ifr
Sam Spade
Jose
When the bearing indicates on-course. 10 degrees is way too early.
Old January 17th 07, 04:57 AM posted to rec.aviation.ifr
Jose
[You're established inbound on an NDB]
Taking Sam Spade's TERPs quote,
The primary area is longitudinally centered on the FAC, and is 10 miles long. The primary area is 2.5 miles wide at the facility, and expands uniformly to 6 miles wide at 10 miles from the facility.
I draw a little diagram, and find that the angle along the outside of
the primary area to be atan(((6/2)-(2.5/2))/10) = atan(7/40) = 10
degrees. So, ten degrees from the facility puts me 2.5 miles inside the
protected area. Sounds good to me. Start on down.
Jose
Old January 17th 07, 05:37 AM posted to rec.aviation.ifr
Jose
So, ten degrees from the facility puts me 2.5 miles inside the protected area.
Oops. 2.5/2 miles, or 1.25 miles inside the protected area. Pesky twos!
Jose
VFR position reporting Mxsmanic Piloting 154 November 26th 06 04:45 PM
Trust those intruments Trust those instruments A Lieberman Instrument Flight Rules 5 May 3rd 06 01:26 AM
Where is approach good about multiple approaches and clearances in the air? Andrew Gideon Instrument Flight Rules 29 February 14th 04 02:51 AM
Study pilot workload during approach and landing Freshfighter Piloting 5 December 7th 03 04:06 PM
IR checkride story! Guy Elden Jr. Instrument Flight Rules 16 August 1st 03 09:03 PM
