ORCA lower than MEA?
Old January 22nd 07, 05:51 AM posted to rec.aviation.ifr
Dan[_1_]
Default ORCA lower than MEA?
There are some places on IFR enroute charts where the OROCA (Off-route
obstruction clearance altitude) is actually lower than MEAs on an
airway in the same quadrant. The higher MEA is NOT due to obstacles in
adjacent quadrants.
If I'm on the airway, usually they don't let folks go down to the MOCA,
however if I file direct off-airways, how likely am I to be able to get
the ORCA? The goal is trying to stay below oxygen altitudes in
mountainous terrain while remaining IFR.
--Dan
Old January 22nd 07, 01:20 PM posted to rec.aviation.ifr
Jim Macklin
MEA is established by VOR reception when distance or
obstacles require an altitude higher than terrain clearance
only requires. You may or may not be given a clearance, if
radar coverage is not available.
Buy or rent some oxygen equipment.
"Dan" wrote in message
OROCA (Off-route
MEAs on an
obstacles in
| adjacent quadrants.
to the MOCA,
be able to get
altitudes in
| --Dan
Old January 22nd 07, 01:38 PM posted to rec.aviation.ifr
Sam Spade
adjacent quadrants.
--Dan
When you go off-route the center will use is minimum instrument altitude
(MIA) chart. ATC will not use ORCAs; those are a concept that never
went anywhere other than to provide you with some information for
emergency or lost comm use.
Also, you can run into issues if you try to go direct through one of
those many chunks of Class G airspace in the western part of the country.
Old January 22nd 07, 08:51 PM posted to rec.aviation.ifr
Dan[_1_]
I don't suppose this MIA information is avaliable or published
somewhere is it? It would be useful for flight planning.
--Dan
adjacent quadrants.
--Dan
Old January 23rd 07, 12:52 AM posted to rec.aviation.ifr
Sam Spade
No, they guard that stuff like it belongs only to them.
Old January 23rd 07, 01:05 AM posted to rec.aviation.ifr
Newps
More drivel.
Old January 23rd 07, 02:04 AM posted to rec.aviation.ifr
Sam Spade
More drivel.
Rather than just making such a cavalier statement, why not be positive
and point us pions to the public source for MIA charts.
Old January 22nd 07, 04:48 PM posted to rec.aviation.ifr
Ron Natalie
adjacent quadrants.
MEA's are often higher because of the signal issues of the NAVAIDS
involved. We got an airway here with a 9000' MEA which is way higher
than the obstructions and the MVA because there's something wonky
with the VOR that defines it.
Old January 22nd 07, 08:48 PM posted to rec.aviation.ifr
Dan[_1_]
I (and just about everyone else these days) is using an IFR certified
GPS unit, but I suppose we'll be stuck with the VOR technology limits
until ATC moves into the 20th century....
--Dan
adjacent quadrants.
Old January 22nd 07, 11:12 PM posted to rec.aviation.ifr
Ron Natalie
No you're not. If you're in radar coverage you can go direct to the
other end of the airway (or anywhere else) at any appropriate
minimum IFR altitude. The MEA isn't limitting unless you are
using VOR's to fly the Victor airway.
Aztec Lower Cowl Mod STC Jim Burns Owning 3 April 16th 06 03:21 PM
Cherokee Strut Lower Strut Seal Replacement Report Mike Spera Owning 3 July 23rd 05 07:07 PM
Orca Island, WA Robert M. Gary Piloting 11 June 5th 04 04:38 PM
Flight planning at the lower flight levels Peter R. Piloting 2 March 16th 04 02:39 AM
Question about Rear Admiral, lower half Pechs1 Naval Aviation 28 October 5th 03 11:24 PM
