B767 thrust
Old January 22nd 07, 12:42 PM posted to rec.aviation.piloting
Kevin
Default B767 thrust
According to the type certificate data sheet for the Pratt and Whitney
62,000 thrust engine, the max continuous thrust should be ~52,000 and
the 62,000 for 5 minutes max. The question is, does N1 @ 100% produce
52,000 lbs of thrust or does it produce 60,200 lbs of thurst? Any
airline pilots out there that can shed light on this?
Thanks, Kevin
Old January 22nd 07, 01:28 PM posted to rec.aviation.piloting
Bob Moore
Default B767 thrust
Neither...N1 for a given thrust rating will vary with Temp/Pressure.
Airline engines are not "full throttle" engines while during my time,
military engines were. A military engine was set to produce 100% RPM
at full throttle, and they accepted either more or less thrust depending
on Temp/Pressure conditions. For commercial engines, an EPR/RPM is
computed for each takeoff and the thrust lever adjusted to obtain that
value.
Bob Moore
ATP B-727 B-707
Old January 24th 07, 02:07 PM posted to rec.aviation.piloting
Kingfish
Default B767 thrust
Thanks, Kevin
Why do you ask Kevin? Are you putting a PW4000 on a homebuilt? G
Old January 24th 07, 05:05 PM posted to rec.aviation.piloting
Kevin
Default B767 thrust
I wish...But, no. I am asking b/c we're trying to configure an
aircraft in x-plane flight simulator and we'd like for everything to be
as realistic as possible. I disguised the question to ward off those
who are critical of others that post topics in groups that aren't
directly related to that specific group...
thanks, Kevin
The Impossibility of Flying Heavy Aircraft Without Training Immanuel Goldstein Piloting 365 March 16th 06 01:15 AM
The Impossibility of Flying Heavy Aircraft Without Training Immanuel Goldstein Home Built 331 March 10th 06 01:07 AM
max altitude and Mach 1 Boomer Military Aviation 22 June 1st 04 08:04 PM
P-38 Exhaust Stephen Harding Military Aviation 10 April 19th 04 07:03 AM
