Security benefit of VFR flight plan
Old January 31st 07, 11:36 PM posted to rec.aviation.piloting
Robert M. Gary
Default Security benefit of VFR flight plan
Looking at the Super Bowl restrictions I have to wonder what the value
of requiring aircraft in the outer ring be on a VFR flight plan. After
9/11 it made sense to me that the TSA didn't understand what a VFR
flight plan was, but you'd think that by now they'd have figured it
out. Will ATC verify with FSS that you opened your flight plan before
issuing your transponder code??? This isn't even a reservation system,
it doesn't say there is any pre-approval required.
-Robert, CFII
Super Bowl Flight Restrictions
Notice Number: NOTC0775
FEDERAL AVIATION DMINISTRATION
HEADQUARTERS WASHINGTON , DC
SECURITY EVENT FLIGHT ADVISORY
NOTAM Issued 12/22/06
FDC 6/9015
Super Bowl XLI
As a result of the planned National Football League Super Bowl in
Miami FL., on February 4, 2007, the FAA at the request of the
Department of Homeland Security, and the Department of Defense, as
part of the airspace security measures will be establishing a
Temporary Flight Restriction (TFR) in the vicinity of Dolphin Stadium.
The following restrictions will apply from 1600L to 2359L on February
4, 2007:
Inner ring restrictions : All aircraft flight operations are
prohibited from the surface up to but not including FL180 within 10
Nautical Miles (NM) of 255728N/0801419W or the FLL214008.4 except as
specified below
1. Only authorized DoD, and Federal/State/Local Law Enforcement/
Lifeguard or Medivac operations, squawking an assign discrete beacon
code, are permitted within the inner ring as coordinated.
2. Only authorized CFR Part 121 and CFR Part 129 regularly scheduled
commercial passenger, private charter and all-cargo flights that MEET
OR EXCEED the Transportation Security Administration approved Aircraft
Operator Standard Security Program (AOSSP), Domestic Security
Inspection Program (DSIP), Twelve-Five Standard Security Program
(TFSSP) all cargo, Private Charter Standard Security Program (PCSSP),
All-Cargo International Security Procedure (ACISP), or Model Security
Program (MSP) are authorized to land/depart within the inner ring.
3. No General Aviation arrival, departure or transit flights will be
authorized to operate within the inner ring of the TFR.
Outer ring restrictions : From the surface up to but not including
FL180 between 10NM and 30NM of the airspace described above. All
aircraft entering or exiting the TFR must be on an active IFR or VFR
flight plan.
1. All aircraft must be assigned a discrete beacon code by an Air
Traffic Control (ATC) facility and be squawking that code prior to
departing within or entering the TFR.
2. All aircraft entering or exiting the TFR must remain in two-way
radio communication with ATC.
3. Operations between 10NM and 30NM are limited to aircraft arriving
or departing local airfields. ATC may authorize transit operations.
Aircraft may not loiter.
Aircraft Entering/Operating within the ADIZ/FRZ Without Authorization
may be Intercepted.
Special Flights or Operations not authorized ANYWHERE within this TFR
-Flight Training-Gliders-Hot Air Balloons-Animal Population Control-
Utility line/pipe inspection flights-Banner Tow-Parachute-Ultralights-
Practice Approaches-Aerobatic-Hang Gliding-Crop Dusting-Seaplanes
FOR QUESTIONS OR FURTHER DETAILS, PLEASE CONTACT FAA HEADQUARTERS AIR
TRAFFIC SYSTEMS OPERATIONS SECURITY
AT 202-267-3333.
Check the FAA website: www.faa.gov for updates on this NOTAM.
You have received this notice from FAASafety.gov because you have
selected "ATC Notices" in your preferences on your FAASafety.gov
account. Click here to log in and edit your preferences on
FAASafety.gov.
Safety is a learned behavior...Learn to be safer at the Learning
Center found on FAASafety.gov
FAASafety.gov | Email Preferences | Opt Out
Do not reply to this email as it is an unmonitored alias. Contact us
for comments or questions.
Old January 31st 07, 11:50 PM posted to rec.aviation.piloting
Kyle Boatright
-Robert, CFII
It is eyewash for the masses. "See, we did something to make you safe from
the little airplanes."
Old February 1st 07, 12:08 AM posted to rec.aviation.piloting
Jim Macklin
We should all make up and file a VFR flight plan to the
Miami area, whether we have a trip or not, 25000 extra
flight plans should make the VFR plan security rule
obviously stupid.
What about Turner's cartoon network Boston event, think Ted
will serve some jail time for the "terrorist" plot?
"Kyle Boatright" wrote in message
what the value
flight plan. After
what a VFR
figured it
flight plan before
reservation system,
| -Robert, CFII
make you safe from
Old February 1st 07, 12:43 AM posted to rec.aviation.piloting
BT
He and every one of his cronies on each management level that approved the
project best be hauled before a court.
Did I say Court?.. forget the courts.. just keel haul them.
BT
Old February 1st 07, 01:48 AM posted to rec.aviation.piloting
C J Campbell
On Wed, 31 Jan 2007 16:08:22 -0800, Jim Macklin wrote
(in article ):
obviously stupid.
A fantastic idea. When they sea that the TFR does not work that way, they
will just ban air traffic completely. Good thinking.
Waddling Eagle
World Famous Flight Instructor
Old February 1st 07, 02:34 AM posted to rec.aviation.piloting
Bob Noel
Nope. His money and lawyers will buy his sorry behind out of danger.
Bob Noel
Looking for a sig the
lawyers will hate
Old February 1st 07, 05:01 AM posted to rec.aviation.piloting
Dave Stadt
"Jim Macklin" wrote in message
obviously stupid.
I don't believe he owns it anymore.
Old February 1st 07, 07:28 PM posted to rec.aviation.piloting
Ron Natalie
obviously stupid.
It's not going to make a difference other than annoy the
FSS briefer you file it with. No security person has
any clue what the plan is.
Old February 1st 07, 07:49 PM posted to rec.aviation.piloting
B A R R Y[_2_]
There's always DUATS...
Old February 1st 07, 11:44 PM posted to rec.aviation.piloting
Ron Natalie
Then it will do nothing but chew up some disk storage
temporarily. VFR plans filed in DUAT go nowhere.
Real World Specs for FS 2004 Paul H. Simulators 16 August 18th 03 09:25 AM
