Taper pin or telephone No.
Old February 5th 07, 06:04 PM posted to rec.aviation.soaring
Fred[_1_]
Default Taper pin or telephone No.
We're looking to replace 4 taper pins for an LP-49. If I measured
right, they are an AN386-9-28A and we need 4. Aircraft Spruce says
they do not have them.
Alternatively, we need Jack Laister's phone no.
Can anyone help on this? Thanks. Fred
Old February 5th 07, 06:45 PM posted to rec.aviation.soaring
Bob Kuykendall
If I measured right, they are an AN386-9-28A and we
need 4. Aircraft Spruce says they do not have them.
Those are honkin' huge AN386s. I'm going to guess that they're the
main wing pins at the center section, and you're just going to cut off
the threaded portion at the tip.
You may be able to get them from a mil-spec hardware house; ACS is not
the only game in town.
You also may be able to have them custom made at a machine shop or
grinding shop.
Also, sometimes I find that the AN386 I need isn't available, but a
longer one of the same tip diameter is. I just buy the longer pin,
chuck it in the lathe, and cut or grind off the unneeded portion.
Unfortunately, Jack passed away a few months ago, so that's likely to
do much good.
Thanks, and best regards to all
Bob K.
http://www.hpaircraft.com
Old February 6th 07, 03:09 AM posted to rec.aviation.soaring
Ian Cant
need . Aircraft Spruce says they do not have them.
Google 'taper pin AN3864', it gives a number of suppliers
and mfgrs
Ian
Old February 6th 07, 03:10 AM posted to rec.aviation.soaring
Ian Cant
Google 'taper pin AN386', it gives a number of suppliers
and mfgrs
Ian
Old February 6th 07, 02:46 PM posted to rec.aviation.soaring
raulb
Jack Laister died last November.
Voice Activated Telephone Phone JUSTEL Ameriphone RC-200 wheel123 Aviation Marketplace 0 November 8th 06 04:31 PM
P51 airplane telephone Gene Seibel General Aviation 0 July 19th 04 04:34 PM
California Based Aircraft in Excess of 35 Years Old Exempt from Property Tax! Larry Dighera Piloting 22 March 22nd 04 08:47 PM
FS: King KT-96 Airborne Telephone System VC Aviation Marketplace 0 October 7th 03 08:34 PM
taper pins Ernest Christley Home Built 4 September 12th 03 03:15 AM
