Need help with a rocket motor ID
Old February 2nd 07, 08:08 AM posted to alt.binaries.pictures.aviation
Dave Kearton
Default Need help with a rocket motor ID
I've just received a few pics of a small rocket motor, from a friend of
mine.
It's about 2Kg and about 45cm long with a 10cm wide nozzle. It's a
liquid fuel motor and doesn't look like it has any electrical connections.
We're all guessing it could be some form of reaction nozzle for (maybe) a
Gemini or Apollo capsule.
Can I buy a vowel please ?
Cheers
Dave Kearton
Name:	Contact sheet.jpg
Old February 2nd 07, 04:53 PM posted to alt.binaries.pictures.aviation
William R Thompson
mine.
It doesn't look like a Gemini or Apollo article. They had ablative
nozzle linings and assorted electrical components attached to the
top of the unit. The spiral exterior of the casing suggests that this
rocket uses a regenerative cooling system, which I don't think
appeared on Gemini or Apollo.
My best guess is that an amateur rocketeer built it. Failing that, it
*might* be a secondary propulsion motor from an Agena upper stage
or--remotely--a midcourse correction motor from a Ranger/Mariner
test article.
(I'd suggest asking Henry Spencer on sci.space.history, but
jeeze, who wants to despoil ssh with something on-topic?)
--Bill Thompson
William R Thompson
mine.
test article.
--Bill Thompson
Old February 2nd 07, 05:22 PM posted to alt.binaries.pictures.aviation
Henry_H@Q_cyber.org[_1_]
On Fri, 2 Feb 2007 18:38:32 +1030, "Dave Kearton"
mine.
Well, I have looked at my share of rocket stuff, and you sure have me
stumped.
First thing I notice is that the combustion chamber seems quite long.
That is always a compromise but usually they wind up being shorter too
much shorter than this.
Second is the helical wrap of the flow passage in the thrust chamber
wall. It is obvious what they are doing there, but I never saw one
like it, except maybe on the back of an envelope.
The nozzle looks to be maybe a 25 to one expansion ratio, so it is
designed for vacuum conditions.
The lip on the nozzle skirt looks very thick to me. Usually
spacecraft nozzles are very thin at the lip. I have been much exposed
to nozzle lips that were maybe a meter in diameter that were not that
thick.
It looks American, not Russian, but sometimes that is hard to tell.
No. xx495 has some writing in it. Looks to me like part of it says
"Sy6xx". So, it isn't Russian, I guess (they get along without those
letters). The "y", if that is what it is, is very funny shaped.
Any writing is very important for ID's.
(I remember many years ago there was a paper in some technical journal
which was written by some Australians in which they described an
object found in the "outback". They considered whether it might be a
bit of reentered space debris. Part of the description was an ink
stamp of a small circle with "CVA263" inside it. That is a "Convair
Astronautics" inspector's stamp. I was convinced already.)
The tube fittings are typical AN, American "Army/Navy" standard ones.
The propellant lines are about the same size, probably lox something
or hypergols, no hydrogen.
It might produce a thrust of a few hundred pounds, a bit large for
reaction control.
I am not familiar with all the thrusters in those spacecraft, but I
will bet that this is not one of them.
For one thing, just as a general observation, "the further up the
stack" you go, the bigger the "dollars/pound" trade factor becomes,
and the more "sophisticated" the hardware looks. Even if it saves no
weight, the designer will try to make his part look more expensive so
that it goes with the surroundings. But, sometimes, a "boat anchor"
manages to sneak onboard. This think looks to me like a piece of GSE
or a test article that may have flown on some "primitive" vehicle.
I will also say with some certainty that it doesn't belong to an
Atlas, Thor, Delta, or Saturn vehicle.
The Atlas had a Rocketdyne thruster somewhat similar in size; it
didn't look anything like this.
And, I don't think it is from Rocketdyne.
My first suggestion would be an "A".
As in "Aerojet". They built a lot of stuff I don't know about. But it
doesn't really look Aerojettish, either.
RMI? TRW?
I am very interested in what you find out.
Henry H.
mine.
stumped.
thick.
reaction control.
RMI? TRW?
Henry H.
Old February 2nd 07, 09:11 PM posted to alt.binaries.pictures.aviation
Dave Kearton
Thanks Bill & Henry,
It's sounding more interesting all the time.
Cheers
Dave Kearton
Dave Kearton
Cheers
Dave Kearton
Old February 2nd 07, 10:15 PM posted to alt.binaries.pictures.aviation
Q
mine.
Long shot - but I think that text is 'SN634' on IMGP0495 right hand
side - speck of dirt at top left of the 'N' making it look like 'iY'.
Looking for more now - and the writing looks Aussie :-)
Mooney Rocket Al Owning 7 September 1st 06 07:31 PM
FS: Harmon Rocket II Rob S. Piloting 0 March 4th 06 11:50 PM
Rocket Man.... Gary Emerson Soaring 2 November 5th 05 04:49 AM
WW-II rocket motor on E-bay - opinions ? BeepBeep Naval Aviation 32 August 11th 05 03:29 PM
TWO EXTREMELY RARE ROCKET BOOKS ON EBAY - INCREDIBLE ROCKET HISTORY! TruthReigns Military Aviation 0 July 10th 04 11:54 AM
