Need help with a problem in our PA28-140
Old February 15th 07, 12:50 AM posted to rec.aviation.owning
Prime
Default Need help with a problem in our PA28-140
We have a really weird one and I'd like some help in the diagnosis.
We're in Southern California and have a 1974 Cherokee Cruiser with the
O-320E3D.
Background:
About a year ago we had our annual. During the annual our mechanic took
apart the gascolator and checked/cleaned the area.
We flew the plane home from the "annual" field to the "home" field
without problems.
In the next flight or two, we had a situation that would repeat itself a
number of times in the last year: During an attempted cold start, we
would primecrankfiredie. The primer appeared to burn off and then
nothing would get the plane started.
I noticed that when trying to start the plane I heard the aux fuel pump
continue ticking as if pressure couldn't be maintained in the system.
Additionally, there was some gas inside the plane near the fuel tank
valve. Our on-field mechanic checked the plane and removed and
reassembled the aux fuel pump, cleaned out the primer lines, and rebuilt
the mags which probably needed it anyway.
One item was that this starting problem happened after a rain.
During the summer, we had an uncharacteristic rain. My partner tried to
fly and the same primecrankfiredie sequence occurred. He pulled the
plugs and found what appeared to be water in them. He cleaned them and
put them back in, and the engine fired up and ran normally.
Forward all the way to a few days ago. The plane had been down for a
nose strut rebuild, and my partner flew the plane afterwards. The next
day we had a very small amount of rain. I went out the next day to fly,
having been grounded for the strut repair for a few weeks. Since it had
rained and I suspected rain might have something to do with the starting
problem, I made sure and sumped both tanks and the gascolator. No trace
of water.
The same sequence of primecrankfiredie occurred with me. After this
happened I then re-sumped everything and still found no water. I did
notice that once I couldn't start the plane, the aux fuel pump kept
ticking as if there was a pressure leak in the system. I looked under
the engine and saw some fresh fuel under the carburetor on the nosewheel
pant. Since I didn't have any tools with me to pull the plugs, I gave up
for the day.
A couple of days later my partner went to the plane, pullled the plugs,
and found water. He dried the plugs and the plane started right up.
Observations:
- This has only occurred after it has rained
- When it occurs it seems that the fuel pump cannot maintain pressure
- We've seen some fuel leakage but no consistency here
- We've had it occur even though we don't find obvious water in the
system
- The two times we've pulled plugs they appeared to have water on them
- When it hasn't rained the full starting sequence has been normal and
we've seen no fuel leakage
Based upon this reocurring problem, we've put some tools in the plane so
that we can always pull the plugs. Yet I don't really trust flying the
plane a long way or especially if precipitation is forecast.
Anybody have any ideas on what could be happening here?
T. Long
Old February 15th 07, 02:20 AM posted to rec.aviation.owning
Mike Spera
Let's take them in order:
* the boost pump clicking over is normal. This is not a sign that it
"cannot hold pressure". The pump rebuild was likely not necessary.
* The fuel selector valve needs new seals. I would suggest it gets done
now. Fuel leakage is rarely a good thing.
* There is no water in the FUEL system.
Now the big one. Your problem is that rain water is collecting in the
scat tubing that goes from the air filter to the carb. Upon startup, the
high vacuum when the engine revs is sucking gas in and flooding the
plugs rendering them inoperative.
I had the exact same problem AFTER replacing my ragged scat tubing with
a new piece. I suspect yours was also replaced at the annual when this
first started happening. Check your log books.
Rainwater can get in from a number of places, but the most common
appears to be from cracks in the fiberglass nose cowling on the corners
of the air filter retaining box and where the round piece intersects the
back of the box. It is dripping down the inside of the cowling, running
over and into the cracks, and collecting in the scat tube. Get some good
cowl plugs to help keep rainwater out. Also, you can fiberglass the
cracks shut or use silicone sealant on them.
Another thing that helps is to punch a tiny hole in the tube at the
lowest point in the scat tube. Also, you can open the carb heat control
half way when starting up. Then, SLOWLY return it to "off" after the
engine starts and is running at fairly high RPMs (like in the runup).
When it is cold, the water that is ingested can freeze the carb throat
in addition to coating the plugs. You can add carb heat to try to clear it.
This problem will drive you nuts when the temps hover around freezing.
The water freezes in the tube and melts as the engine warms up. The ice
ball can break loose and choke off the carb (guess how I know). Once the
engine dies out, hop out of the plane to watch a stream of water running
from under the cowling. In southern CA your problem will be limited to
killing the engine and coating the plugs with water.
Good Luck,
O-320E3D.
Background:
without problems.
of water.
for the day.
Observations:
system
T. Long
Old February 15th 07, 05:39 AM posted to rec.aviation.owning
Prime
Mike, thanks for the feedback. One comment, at previous times the boost
pump clicking would usually stop once pressure was built up in the
lines. When this problem occurs the clicking never stops. I don't think
that's normal, since it doesn't occur when we get a "normal start"?
Mike Spera wrote in
k.net:
done now. Fuel leakage is rarely a good thing.
the high vacuum when the engine revs is sucking gas in and flooding
the plugs rendering them inoperative.
with a new piece. I suspect yours was also replaced at the annual when
this first started happening. Check your log books.
corners of the air filter retaining box and where the round piece
intersects the back of the box. It is dripping down the inside of the
cowling, running over and into the cracks, and collecting in the scat
tube. Get some good cowl plugs to help keep rainwater out. Also, you
can fiberglass the cracks shut or use silicone sealant on them.
control half way when starting up. Then, SLOWLY return it to "off"
after the engine starts and is running at fairly high RPMs (like in
the runup).
clear it.
ice ball can break loose and choke off the carb (guess how I know).
Once the engine dies out, hop out of the plane to watch a stream of
water running from under the cowling. In southern CA your problem will
be limited to killing the engine and coating the plugs with water.
Good Luck,
the O-320E3D.
Background:
took apart the gascolator and checked/cleaned the area.
without problems.
itself a number of times in the last year: During an attempted cold
start, we would primecrankfiredie. The primer appeared to burn off
and then nothing would get the plane started.
pump continue ticking as if pressure couldn't be maintained in the
system. Additionally, there was some gas inside the plane near the
fuel tank valve. Our on-field mechanic checked the plane and removed
and reassembled the aux fuel pump, cleaned out the primer lines, and
rebuilt the mags which probably needed it anyway.
to fly and the same primecrankfiredie sequence occurred. He pulled
the plugs and found what appeared to be water in them. He cleaned
them and put them back in, and the engine fired up and ran normally.
next day we had a very small amount of rain. I went out the next day
to fly, having been grounded for the strut repair for a few weeks.
Since it had rained and I suspected rain might have something to do
with the starting problem, I made sure and sumped both tanks and the
gascolator. No trace of water.
this happened I then re-sumped everything and still found no water. I
did notice that once I couldn't start the plane, the aux fuel pump
kept ticking as if there was a pressure leak in the system. I looked
under the engine and saw some fresh fuel under the carburetor on the
nosewheel pant. Since I didn't have any tools with me to pull the
plugs, I gave up for the day.
plugs, and found water. He dried the plugs and the plane started
right up.
Observations:
system
them - When it hasn't rained the full starting sequence has been
normal and we've seen no fuel leakage
so that we can always pull the plugs. Yet I don't really trust flying
the plane a long way or especially if precipitation is forecast.
T. Long
Old February 15th 07, 05:45 AM posted to rec.aviation.owning
Prime
Oh and Mike, thanks for the water issue suggestions. Your explanation
would cover the symptoms we are seeing, I hadn't thought of that. We
will check it out. I do believe we replaced the tubing at that annual.
Are you suggesting that the old tubing may have leaked just enough to
trap the water, where previously it would have drained? What would be
different with new scat tubing?
Mike Spera wrote in
k.net:
the runup).
clear it.
Good Luck,
the O-320E3D.
Background:
without problems.
right up.
Observations:
system
T. Long
Old February 15th 07, 09:37 PM posted to rec.aviation.owning
RST Engineering
Prime, no, just the opposite. The water that leaked into the old scat hose
drained out through the holes in the old hose. The new hose doesn't leak,
therefore the water stays inside the hose to be sucked up into the engine.
PLEASE learn to snip. We really don't need to relive the whole thread. All
it does is waste bandwidth.
"Prime" wrote in message
5.20...
Old February 16th 07, 01:30 AM posted to rec.aviation.owning
Dave[_3_]
Hey Prime!
Are a member of the Cherokee group?
http://www.piperowner.com/
Probs like yours are discussed regularily there...
...A must for a Cherokee driver....
Dave
O-320E3D.
Background:
without problems.
of water.
for the day.
Observations:
system
T. Long
Old February 16th 07, 01:33 AM posted to rec.aviation.owning
Mike Spera
As Jim said, the opposite is likely true. The old tubing was probably
beat up and perforated in several spots, thus letting the water OUT that
was leaking in from the airbox.
If you remove the nose cowling, I can almost guaranty some cracks in the
airbox. Hold the cowling upright in its normal position, spray water at
the front from a high up angle (mimicking rain), and look to see where
it runs. I'll bet it goes into cracks and out the round tube that
connects to the scat tube. All it takes is an ounce or two.
As I said, I had the exact same problem after replacing my main
induction scat tube. A little hole punched in the bottom cured it. Until
then, start it up with the carb heat valve opened half-way to prevent
the water from being sucked in on startup.
Good Luck,
Old February 16th 07, 01:47 AM posted to rec.aviation.owning
Mike Spera
Although I believe this is unrelated to your problem, it does not sound
normal in the opposite way you are describing. I believe they should
never stop running.
It has been many years since I dismantled an electric fuel pump, but I
believe these pumps have a spring loaded internal bypass valve that
maintains pressure. They are made to run constantly. If they stop, that
indicates a problem.
Wrenches?
Good luck,
Old February 16th 07, 02:02 AM posted to rec.aviation.owning
Ray Andraka
Mike Spera wrote:
boost pump clicking would usually stop once pressure was built up in
the lines. When this problem occurs the clicking never stops. I don't
think that's normal, since it doesn't occur when we get a "normal start"?
never stop running.
Wrenches?
Good luck,
On mine, it continues to run but it gets a lot quieter once the fuel
pressure builds up.
Does your pressure build to the normal level when this happens? Could
be that the fuel pump needs new seals.
Old February 17th 07, 06:37 AM posted to rec.aviation.owning
Prime
That's what I meant and understood, thanks.
As far as bandwidth, I just figured keeping the context was a good idea.
Given broadband speeds, that amount of text is negligible on bandwidth. Now
if somebody is still on a dial up modem (heaven forbid) then you're
correct.
"RST Engineering" wrote in
hose drained out through the holes in the old hose. The new hose
doesn't leak, therefore the water stays inside the hose to be sucked
up into the engine.
thread. All it does is waste bandwidth.
FS: PA28-140 Steve Foley Aviation Marketplace 0 November 27th 06 01:06 PM
FS: 1966 PA28-140 Steve Foley Aviation Marketplace 0 July 3rd 06 12:36 PM
FS: 1966 PA28-140 Steve Foley Aviation Marketplace 0 February 4th 06 11:48 PM
Price for PA28-180 Billy Owning 12 November 5th 04 04:37 PM
PA28 gas cap Frank Van Haste Owning 19 July 24th 03 07:17 PM
