taildragger to trike
Old February 15th 07, 02:11 AM posted to rec.aviation.homebuilt
anon
Default taildragger to trike
A couple of folks have built their Himaxes and Minimaxes as trikes. On the
surface, it doesn't seem like an overwhelmingly difficult engineering
problem to overcome. How deluded might I be?
Old February 15th 07, 02:23 AM posted to rec.aviation.homebuilt
J.Kahn
Moderately to extremely depending on how design/engineering savvy you
are. If someone has a successful installation just copy that.
Old February 15th 07, 07:56 PM posted to rec.aviation.homebuilt
Be careful designing landing gear mount structure. Taxiing over rough
ground is really hard on gear, harder than bumpy landings. I've seen
some gear on ultralights that looks scary. Watched one collapse on
landing several years ago. And have heard of other gear failures on
homebuilts. We had a gear failure on a Glastar about five years ago,
when the single AN5 bolt sheared during braking after touchdown. The
gear is a round, tapered steel rod mounted in a steel tube socket
welded to the fuselage cage structure, and that AN5 bolt passed
through the tube and leg. Braking forces try to turn the rod in the
socket and landing/turning/taxiing loads try to push it inward, and
that bolt couldn't take it. After the repairs, it had a single 3/8"
NAS bolt, about three times stronger than the original AN5. Didn't
break no more.
So it ain't as simple as it looks. Worse, nosegears have to
be strong enough to take a lot more abuse than a tailwheel. The whole
weight of the airplane comes against the nosegear in a botched landing
or on touchdown on a really soft surface.
Dan
Dan
Old February 18th 07, 05:32 PM posted to rec.aviation.homebuilt
Peter Dohm
that bolt couldn't take it. (additional info snipped)
I've never looked closely at the Glastar undercarriage, but the RV-8A uses a
similar system with good success. In the case of the RV that I looked at,
there would be no torsion applied to the mounting of the gear leg with the
tire correctly inflated. However, some torsional force would exist in the
event that the tire is either over-inflated or under-inflated.
Another point that I feel compelled to make, even though I really do not
like to say it, it that the gear leg and socket should NOT be lubricated. I
am not saying that the gear on the Glastar was, but just making the point
that the bolt is mainly to align the under carriage when not in use and that
friction should greatly exceed any capacity of the bolt when the airplane's
weight is on the wheels.
Peter
(Not a mechanic, but I've seen some strange things!)
Old February 19th 07, 02:50 PM posted to rec.aviation.homebuilt
Stealth Pilot
On Sun, 18 Feb 2007 12:32:19 -0500, "Peter Dohm"
oh yeah? how did you work that out?
ever seen one flexing under load?
Stealth Pilot
Old February 20th 07, 12:52 AM posted to rec.aviation.homebuilt
Peter Dohm
that
airplane's
I haven't watched, but yes they do. And I still think that should provide a
jamming effect.
As to what, if anything should be used as an assembly coating, to prevent
rust, I really don't know.
OTOH, a similar system is used on a number of certified aircraft and
mechinics possess a wealth of knowledge. This is really the sort of thing
that should be discussed over a case of beer.
Peter
rigging brs on a trike P.D. Products 0 June 28th 06 05:20 PM
trike design book? Shin Gou Home Built 3 December 12th 04 12:56 AM
Flying trike for a living? Oli Kai Paulus Aviation Marketplace 16 September 10th 04 07:03 AM
FS Behlen Poewer Trike Oscaź Aviation Marketplace 0 June 12th 04 08:24 AM
Trike wing bolt size Aaron Smith Home Built 0 September 30th 03 03:02 AM
