Glass big learning curve?
Old February 15th 07, 11:39 PM posted to rec.aviation.piloting
Default Glass big learning curve?
Our CAP unit is going to be receiving a new C-182 with a glass
cockpit.
In order to give us a taste of it a Cirrus owner came to our CAP
meeting and showed us his wonderful aircraft (not the same PDF/MFD but
close). I've heard from many sources that it takes about 10 hours to
transition. In fact a local FBO has a brand new C-182 (rents for about
$200/hr) and requires 15 hours. Although I didn't fly the Cirrus, I
sat
in the aircraft while the owner spoke with someone else. He said we
could push any buttons we wanted to. So, I tried to think of all the
things I could normally do on an IFR flight. Amazingly, I had no
problems with any of the operations. The display is easy for me
because
my generation grew up flying flight simulators that use the exact same
display. The only hard part is figuring out the 430s (which I've done
before). So, I'm wondering if all this talk about a long transition
time is mostly for the generation that didn't grow up with computers.
Just thinking about the time it takes some people (not necessarily
based on age) to get familiar with their computer vs. others, I'm
wondering if its the same thing. Perhaps I'm being naive but I felt
that I could fly behind that panel today.
Has anyone on this list had experience with such a transition?
-Sammy J.
Old February 16th 07, 12:00 AM posted to rec.aviation.piloting
Jose
The hardest part, at least with the Garmins and the glass I've flown, is
undoing an error. Mostly, you can't back up. You end up in an
unfamiliar place, and have to re-dial everything in again.
Jose
Humans are pack animals. Above all things, they have a deep need to
follow something, be it a leader, a creed, or a mob. Whosoever fully
understands this holds the world in his hands.
Old February 16th 07, 12:42 AM posted to rec.aviation.piloting
Vaughn Simon
Not directly, but the place I fly has several glass rentals and those
planes seem to stay busy. All of their new planes for the last two or three
years have been glass, and they wouldn't be adding them to the flight line if
folks weren't renting them. For insurance and hourly cost reasons I don't fly
them, but I believe the transition involves an evening or two of "glass" ground
school and a couple hours in the air with an instructor. Perhaps a bit more
instruction would be in order if you were planning some hard IFR.
I just don't understand why folks fly away in $250,000 rentals when you
can't generally buy over $100,000 renter's insurance. I fly cheap planes, and
they don't have glass except for the round bits over the steam guages.
Vaughn
Old February 16th 07, 01:08 AM posted to rec.aviation.piloting
C J Campbell
On Thu, 15 Feb 2007 15:39:37 -0800, wrote
(in article . com):
Of course you could have flown it that day. The whole point of a glass panel
is to make flying easier, not harder.
I flew some of the first Cessnas with the G1000 panel. It was cool.
The thing is, the 10 hours of training are not to teach you how to use it.
The ten hours of training is to teach you to become so familiar with it that
you stop hunting around for settings and menus and whatnot. Really, the CFI
is there to show you the basic operation, answer questions, set up possible
scenarios, teach emergency procedures, and keep a lookout for other traffic
while you get to experiment. The idea is to get you past the point where the
new avionics are a barrier to what you want to do to where they are actually
helpful.
Waddling Eagle
World Famous Flight Instructor
Old February 16th 07, 01:51 AM posted to rec.aviation.piloting
BT
it does not take 15 or even 10 hours in the air.
Do the ground School first, get the Garmin $6 CD that you can put on your
computer.
Get Max Trescott's book (and I see now he has a training CD based on his
book).
Do the ground school. Learn the pages, Learn what is where.
If you are familiar with a Garmin 430/530 you are half way there.
Learn the failure and back up modes, know this from the computer before you
even step to the airplane.
Most FBOs are able to run the G1000 package with ground power back up and
not running the engine at a much reduced rate, with two pilots in the seats
and the CFI standing in the door.
BT
cockpit.
sat
because
-Sammy J.
Old February 16th 07, 03:26 AM posted to rec.aviation.piloting
Doug[_1_]
Using the altimeter in the glass cockpit is a new skill for holding
altitude in IMC or under the hood. The rest of the guages seemed to go
quickly, but they all took some getting used to.
To really KNOW that complicated panel (I mean every function and all
the idiosyncracies) would take several hundred hours. To just fly it
VFR all you need to learn new is how to tune the radios.
Old February 16th 07, 04:29 AM posted to rec.aviation.piloting
Peter Dohm
I don't currently fly, haven't in a long time, and was a student when I did;
so I had started to wonder whether it was just me, or whether others also
found the altimeters in the some of the glass panels to be non-intuitive.
I really thought that the airspeed indicators were non-intuitive as well,
but that seemed far less problematic--at least for VMC.
At the moment, I can't quite decide whether the fact that it is not-just-me
is better or worse. However, I can't quite get used to the idea that the
numbers move, instead of the needles, and that the result seems to require
the user/pilot to interpret the data a digital instead of analog.
Peter
Just my $0.02
Old February 16th 07, 04:52 AM posted to rec.aviation.piloting
Jose
I've flown glass once, and I found the gauges to be non-intuitive and
hard to use. For one thing, they are of different sizes, so one can't
at a glance see what fraction of "full" you are at, like you can with a
round airspeed gauge. I much prefer a round gauge.
Jose
Old February 16th 07, 03:55 AM posted to rec.aviation.piloting
GeorgeC[_2_]
Gramin has a Simulator for the G1000. The cost is about $10.00 for a DVD.
Warning, be sure to check the hardware requirement before you buy. Some of the
pilots could not get it to work on they old computers.
http://www.garmin.com/products/g1000/
Abacus had a Civil Air Patrol add-on for FS2004 and FSX. It has a Cessna 182
(steam gages or G1000) and Maule MT-260. It also Features "A Custom Mission
Builder" which you can make your own SAR. You can fly as either as a mission
pilot or as a scanner. The add-on cost about $30.00 plus SH. If you are a CAP
member you get a discount.
http:/abacuspub.com/catalog/s644.htm
I had a problem with the C182. There is no manifold pressure gage in FDX. In
FS2004 there is a manifold pressure gage.
cockpit.
sat
because
-Sammy J.
GeorgeC
Old February 16th 07, 04:35 AM posted to rec.aviation.piloting
Hamish Reid
In article . com,
cockpit.
sat
because
-Sammy J.
I'm a relatively old geezer and I had no trouble at all with getting
signed off at our club for the G1000 C172 after about an hour's flying
for VFR (ok, the bloody fam sheet / test thing paperwork that had to be
filled out before signoff took forever, but that's just looking things
up in the POH and trying not to die of boredom while doing so...).
IFR was a bit longer, but only because you really want to be damn sure
you know at least the basics of how to reset the GPS and start again
(urgh! don't get me started...), and because, well, it's IFR and you
want to be familliar with at least the basics (partial panel is
interesting on a G1000 172). As others have commented the vertical tape
airspeed and altimeter displays can be a little unfamiliar at first, but
really, 10 hours seems an awful long time to transition even for IFR
and a 182, especially if you already have Garmin GPS 430 or 530
experience.
Hamish
Glass big learning curve? Robert M. Gary Piloting 25 September 30th 05 04:47 AM
can't quite grasp the "power available" curve xerj Piloting 6 September 12th 04 12:33 PM
Cambridge 302 learning curve cont. Tuno Soaring 4 July 5th 04 10:10 AM
learning curve in fs 2002.. David Ciemny Simulators 5 December 30th 03 12:18 AM
18m polar curve Alan Irving Soaring 1 December 15th 03 11:45 PM
