Pilot controlled lighting controller
Old February 16th 07, 05:42 PM posted to rec.aviation.owning,rec.aviation.homebuilt
DL
Default Pilot controlled lighting controller
Very long shot, I know, but - does anyone have any schematic or any
documentation whatsoever on a pilot controller runway light controller,
Model BX-2, made by Subil Enterprises, Inc., Des Moine, IA 50317? Can't
find any current address or phone number for that company. Unit was likely
made in the late '70s-early '80s. Problem is very low sensitivity. Has
worked fine until recently. Obviously very difficult to troubleshoot
without any info.
Thanks in advance for any help.
DL
Old February 16th 07, 07:18 PM posted to rec.aviation.owning,rec.aviation.homebuilt
Does it have its own receiver or does it plug into the audio output of
another receiver?
How's the antenna, coax to the antenna, and any other connecting cables?
These crap out with surprising regularity. (This applies even if the
light controller is plugged into another radio.) If the antenna is also
used for transmitting, and you can get an SWR meter, you might check
the SWR to see if it's way high.
If the controller plugs into the output of another receiver, have you
tried the controller with a different receiver?
Inside the box, even without a schematic, you can check a few things.
Some you can do with a multimeter and some need an oscilloscope.
Power supply up to snuff - steady, ripple-free voltages? Depending on
the voltages, you might be able to temporarily substitute a battery,
which is almost guaranteed to give you "clean" power. In something of
that age, the filter capacitors on the power supply are likely suspects.
Get a strong light and a magnifying glass and check all the solder
joints, especially ones to massive components and off-board wires.
Especially check the input jack (antenna or audio) - these are often
subject to mechanical damage from the cables that are plugged into them.
Check the first few components immediately after the input jack (antenna
or audio). These bear the electrical brunt of goofy signals coming in
the input. See if resistors and capacitors are open, shorted, or have
changed value dramatically. See if inductors are open. You might have
to unsolder one end of the component involved for a good test.
If it has its own receiver, and is crystal-controlled (you can't program
in the frequency), check the crystal for oscillation at the proper
frequency and/or swap in another crystal. This may cost you a few bucks
and some time for the new crystal, so it's not first on the list.
Resist the temptation to adjust any internal trimpots or coils at first.
If you can't resist, mark them well so you can put them back where they
were when the adjustment doesn't help. "I will remember where it was"
is not a mark.
Google says this guy
http://fmi.typepad.com/lwyp/2006/10/..._lighting.html
was looking for information on a similar unit; you might contact him and
see if he found anything.
Disclaimer: This is based on experience with electronic equipment in
non-aviation applications. I am not an avionics technician. I don't
have an A&P; I don't even have a TG&Y. Your mileage may vary.
Matt Roberds
Old February 16th 07, 08:32 PM posted to rec.aviation.owning,rec.aviation.homebuilt
DL
Thank you very much for your detailed response. Answers to your
questions/comments, below:
another receiver?
It has its own receiver, power supply, logic to respond to unicom clicks to
turn lights on and off and power relay for runway lights.
Have checked antenna coax and connections and found no problems, including
continuity/shorts check of antenna (very short cable).
Power supply checked with voltmeter and scope; seems clean, may try with
battery or alternate power supply.
Will do. First section is FET RF amp. Will look closely in that section
Is crystal controlled. Have tried frequencies above and below the 122.9
spec. to see if I could detect a higher sensitivity off frequency. So far,
no definitive results. It works, but handheld needs to be close to the
antenna.
is not a mark.
Have successfully resisted that temptation thus far. Good advice.
Had seen that too. Good advice to try to contact him. Is a different unit.
Hamtronics sells a solution. Much more capable board, $229, plus wall wart
PS, plus solid state power relay. Such a full solution (with my packaging)
could be had for under $300 - not enormous when absorbed by a number of
folks. But I am stubborn and would like to find the culprit in this box, as
the fix, if found will be less than $5 including shipping and sales tax,
from Mouser. And I'll chalk my time off to a "learning experience" . . . .
up to a point, at least!
Matt Roberds
Thank you again. Obviously you've had some real experience with
troubleshooting. The beauty of this situation is that you don't have to be
an A&P, IA, FCC, anything that I know of. It's at a private field. No one
is guaranteed that it works every night. But it has for years, until now.
DL
Old February 20th 07, 07:55 PM posted to rec.aviation.owning,rec.aviation.homebuilt
You're welcome. It sounds like you're ahead of me anyway. On
Usenet, "I need a schematic" requests tend to fall into two categories:
either "I don't know which end of a soldering iron to hold but I think a
schematic will tell me everything" and "I already checked all the easy
stuff with no luck and need a schematic to go further". I ass-u-med
that your query was in the former category but it was actually in the
latter.
I know there will probably be some protection, tuning/filter, and
impedance matching components between the antenna input and the FET,
but to me FET usually means "easy to zap with static/overvoltage".
This is probably more true on equipment of that vintage.
Matt Roberds
(Note: This post may appear twice. Since Cox outsourced their news
servers to Highwinds Media, news doesn't work worth a damn here.)
Pilot controlled lighting controller DL Owning 3 February 20th 07 07:55 PM
Limiting use of Pilot Controlled Lighting [email protected] Instrument Flight Rules 9 June 19th 06 10:33 PM
Lighting Controller Updated [email protected] Home Built 0 January 11th 05 05:34 PM
Lighting Controller Updated [email protected] Aviation Marketplace 0 January 11th 05 05:30 PM
Cockpit Lighting Controller Richard Products 0 May 4th 04 04:51 PM
