Fuel needed to go 3000nm in a 777
Old February 19th 07, 01:39 AM posted to rec.aviation.piloting
Chris W
Default Fuel needed to go 3000nm in a 777
Can someone tell me if I am doing this right. I found this pdf document...
http://www.boeing.com/commercial/air...s/7772sec3.pdf
using the chart on page 2 of the pdf file. Suppose you want to go
3000nm with a "Brake Release Gross Weight" of 480,000 lbs. Your "OEW
Plus Payload" would then be 375,000 lbs. I am guessing that OEW must
refer to the empty weight of the plane which I think is 306,000 lbs.
That leaves us with 105,000 lbs for fuel which, dividing by 7, gives us
15,000 gallons (about half a tank). Now subtracting 306,000 for 375,000
gives 69,000 lbs. So the conclusion I draw is....
15,000 gallons of fuel in a 777 will carry 69,000 lbs of people and
stuff 3,000 NM.
Sound right?
Chris W
KE5GIX
"Protect your digital freedom and privacy, eliminate DRM,
learn more at http://www.defectivebydesign.org/what_is_drm"
Gift Giving Made Easy
Get the gifts you want &
give the gifts they want
One stop wish list for any gift,
from anywhere, for any occasion!
http://thewishzone.com
fuel leak or auxiliary fuel pump malfunction? [email protected] Owning 7 December 17th 06 12:57 PM
Fuel quality control standards for aircraft rental/fuel sales... [email protected] Owning 19 January 19th 05 04:12 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Home Built 0 January 26th 04 07:48 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Aviation Marketplace 0 January 26th 04 07:48 AM
Airplane Parts on Ebay Vac Reg Valves, Fuel Floats, O-200 Spider, Fuel Injection Valve Bill Berle Owning 0 January 26th 04 07:48 AM
