egt cht
Old February 21st 07, 01:57 PM posted to rec.aviation.owning
dave
Default egt cht
I'd like to add an electronic six probe egt/cht to my bonanza. The
three usual candidates with similar products are
Electronics-international, JPI and Insight. Some have better features
than others but all do what I need. I don't need to save data for
future reference. Dynon and MGL electronics both make LCD monitors for
sport/experimental aircraft that accept standard probes. Neither MGL
nor Dynon have any FAA approvals. Dynon says that you could get a 337
to install one of their products. The basic MGL TC3 would be fine for
my purposes. It's $265.00 plus the probes plus installation. The
cheapest approved monitor is around $2000 with probes plus installation.
Has anyone gotten a 337 for the installation of any of these products?
Would it help if I left my existing single probe EGT and CHT and
their associated gauges?
I've read that these gauges can be installed in sport aircraft and that
these aircraft can be used for flight training. Maybe I read that
incorrectly but if that is the case, how could the these products be
used in airplanes used for hire but not for a part 91 airplane like most
of us fly.
Thanks
Dave
Old February 21st 07, 02:51 PM posted to rec.aviation.owning
Denny
Default egt cht
There is at least one other source.. Look through Trade-A-Plane....
As far as using non-tso'd forget it, ain't gonna happen...
cheers ... denny
Old February 21st 07, 03:00 PM posted to rec.aviation.owning
Jay Honeck
Default egt cht
That's what I was told, too.
We've got the JPI EDM-700 keeping an eye on our 6-cylinder O-540, and
love it. It's become an essential tool for us in the four years we've
flown with it.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old February 21st 07, 04:02 PM posted to rec.aviation.owning
Paul kgyy
Default egt cht
Some of these cheap add-ons reduce the resale value of the aircraft,
the theory being that the owner has taken other shortcuts. Get one
you can rely on; the engine you save will be your own.
Old February 21st 07, 04:29 PM posted to rec.aviation.owning
Default egt cht
Dynon makes a good product. I've installed their stuff in
experimental aircraft with excellent results. Getting field approval
to get one of these installed in a production plane will be next to
impossible. It just isn't done by the FSDOs.
I bought a nine probe EI UBG-16 (4 egt, 4cht, 1 oil temp) unit for
my Cherokee. It was just over $1200 with probes. Maybe you need to
shop around. I got mine from Spruce.
As for Light Sport Aircraft, I believe you're right. I've seen
quite a few of the non-TSO'd instrument packages in new LSAs. I know
the operate under much looser certification standards than normal
category planes.
