Cylinders and corosion
Old February 28th 07, 10:33 AM posted to rec.aviation.homebuilt
Philippe Vessaire
Default Cylinders and corosion
Hello,
What are the best corosion resistant cylinder for O200 engine?
genuine TCM
ECI-Titan
Millennium Cylinders from Superior airparts.
any other I don't know...
Thanks
Minicab F-PRAZ
Philippe Vessaire Ò¿Ó¬
Old February 28th 07, 12:35 PM posted to rec.aviation.homebuilt
jl
On Feb 28, 5:33Â*am, Philippe Vessaire wrote:
Hello,
Â*genuine TCM
Â*ECI-Titan
Â*Millennium Cylinders from Superior airparts.
Thanks
Minicab F-PRAZ
Â* Â* Philippe Vessaire Â*Ò¿Ó¬
I don't know that there would be any difference in corrosion
resistance for steel cylinders.
You might try one of the proprietary liners like nikasil or nuchrome.
Be careful, though. Thousands of people were burned by ECI on
cermichrome cylinders.
Old February 28th 07, 02:11 PM posted to rec.aviation.homebuilt
Denny
Hello,
Â*genuine TCM
Â*ECI-Titan
Thanks
Minicab F-PRAZ
Be careful, though. Â*Thousands of people were burned by ECI on
OTOH, I put 900 hours on my Cermichromes and loved them... They were
still going strong when I sold the plane...
denny
Old February 28th 07, 04:10 PM posted to rec.aviation.homebuilt
jl
Hello,
Â*genuine TCM
Â*ECI-Titan
Thanks
Minicab F-PRAZ
denny
Lycoming cylinders, then, cause I've never heard of cylinders lasting
that long on a Continental, and every cermichrome I've ever known of
either died at 100 to 200 hours, or had to be honed to get to 300.
Old February 28th 07, 06:50 PM posted to rec.aviation.homebuilt
Denny
Hello,
Â*genuine TCM
Â*ECI-Titan
Thanks
Minicab F-PRAZ
denny
either died at 100 to 200 hours, or had to be honed to get to 300.- Hide quoted text -
- Show quoted text -
That was an IO-520D on my Super Viking...
denny
Old February 28th 07, 08:06 PM posted to rec.aviation.homebuilt
Hello,
Â*genuine TCM
Â*ECI-Titan
Thanks
Minicab F-PRAZ
denny
It'll depend some on the cylinder finish, whether it's plain steel,
chromed or otherwise. The biggest factor in corrosion is the amount of
moisture allowed to develop in the crankcase. Short flights,
especially in cooler weather, will leave water in the case that
condenses from water vapor in blowby gases, and that water will cause
rusting and will also mix with sulphur and chlorine compounds in the
oil and form acids that eat everything, not just cylinders. An
airplane needs to be flown until the oil temp reaches 180°F and held
there for 30 or 40 minutes, at least, to get rid of that moisture.
That's tough to get in some airplanes. We have a Citabria
here with an O-235 that just won't get the oil up to that temp in the
winter, even with the oil cooler blocked off, and corrosion has been a
problem. Had to hone and re-ring the rear two cylinders and oversize
the front pair at engine mid-time. The cylinders run so cool that
moisture is there all the time, getting trapped between the cylinder
wall and piston after shutdown and creating dissimilar-metal corrosion
pitting. The pitting causes worse cylinder wear and a ridge forms at
the bottom of the ring travel. The aluminum piston pin plugs ride over
the ridge and get shaved and you start finding aluminum chips in the
oil screen. A five-ring piston (three above the pin, two below) would
prevent the shaving, and maybe even some of the corrosion by
preventing access to the cylinder wall/piston interface by the
crankcase moisture.
Dan
Old February 28th 07, 11:42 PM posted to rec.aviation.homebuilt
On Feb 28, 12:06 pm, wrote:
On Feb 28, 9:10 am, "jl" wrote:
On Feb 28, 9:11 am, "Denny" wrote:
On Feb 28, 7:35 am, "jl" wrote:
On Feb 28, 5:33 am, Philippe Vessaire wrote:
Hello,
genuine TCM
ECI-Titan
Thanks
Minicab F-PRAZ
denny
oil and form acids that eat everything, not just cylinders. Anairplaneneeds to be flown until the oil temp reaches 180°F and held
crankcase moisture.
Dan
So I have no personal experience with this simple engine dryer, but I
believe a couple of members of our Seattle chapter (can you say extra
moisture in the air?) have built and/or are using Dave's plans for a "
24/7 Engine Dryer to get you engine to it's 2000 hour TBO" on his web
site at http://www.geocities.com/powertugs. I believe he'll send the
plans to you for free too.
O-470 cylinders RST Engineering General Aviation 11 March 24th 05 08:46 PM
O-470 cylinders RST Engineering Owning 11 March 24th 05 08:46 PM
Flying on 3 or 4 cylinders Robert M. Gary Piloting 8 November 16th 04 01:30 AM
0-320 cylinders Drew Dalgleish Home Built 9 December 8th 03 04:25 PM
0-235 lyc cylinders needed (3) Captain Dave Home Built 0 October 8th 03 08:00 PM
