Sealant for polyethylene fuel tank?
Old March 2nd 07, 06:18 PM posted to rec.aviation.homebuilt
Morgans[_2_]
Default Sealant for polyethylene fuel tank?
"Earl" wrote
Rob said his tank had developed a leak. That would mean that there had
been gasoline in the tank. I don't think anyone would suggest welding
a used metal tank, how could it be any safer with a plastic one?
Doh! I realized that, right after I hit send. I'm sure I would not have
done that if it were sitting there in front of me!
A soldering iron would be safe, and almost as effective at doing a little
plastic welding. It is kinda' fun, if you have ever done it before.
Old March 2nd 07, 07:56 PM posted to rec.aviation.homebuilt
When I said "welded" in my original reply I had.assumed thatmost would
take that as the "normal" method of welding plastic - with a plastic
welder that uses hot air.
Assumptions generaly BITE!
As for the idea of red silisone - don't. Been there done that. Gave
up the practice many years ago. No matter how small an amount you use
the gas wil eventually swell it up and leak through. A waste of time
and materials - IMHO
Old March 2nd 07, 08:51 PM posted to rec.aviation.homebuilt
Orval Fairbairn
a used metal tank, how could it be any safer with a plasic one?
Steve in Michigan
Actually, it is quite safe -- if done right. I have done this several
times.
1. Look up "Dry Ice" in your Yellow Pages.
2. Get the smallest amount they will sell you (usually about 5 lb.)
3. Put it in the tank and let sit for about 1/2 hour.
The dry ice (CO2 no thanks to Al Gore) displaces smothers the oxygen
from the tank and will not support combustion.
The nice thing about dry ice is that it leaves no residue, unlike
filling the tank with water
Old March 3rd 07, 02:38 AM posted to rec.aviation.homebuilt
clare at snyder.on.ca
On Fri, 02 Mar 2007 20:51:21 GMT, Orval Fairbairn
Steve in Michigan
times.
Welded (brazed) a patch on the oilpan of a '64 Riviera one day without
pulling it. Rinsed out all the oil I could, first with varsol, then
hot water - and filled the crankcase with a CO2 extinguisher. Had the
apprentice sitting on the fender, giving it a little shot every minute
or so untill I has the patch fully sweated on. (guy had driven into
the rebar used to spike a parking cub down and HAD to leave for
Chicago that evening - from Kitchener Ontario)
Posted via a free Usenet account from http://www.teranews.com
Old March 3rd 07, 06:04 AM posted to rec.aviation.homebuilt
cavelamb himself
Steve in Michigan
times.
I've been using dry ice for a while now to extend the ice box on my
boat. One summer and the cooler is crazed, cracked, and nearly useless.
Wouldn't recommend this aproach on a plastic fuel tank.
I'm gonna stick with this one:
http://store.leadingedgeairfoils.com...th=548_436_568
Fuel Tank Bushing
SKU: H7285
$1.00
Richard
Old March 3rd 07, 07:32 AM posted to rec.aviation.homebuilt
Rob Turk
"TerryJ" suptjudatcomcastdotnet wrote in message
Teflon tape from ACE hardware....
"Rob Turk" wrote in message
I'm looking for a sealant or kit to seal brass NPT inserts into a
polyethylene tank. This is a Kitfox header tank that has developed a leak
at one of the inserts. I'm probably going to use Mogas that has ethanol
additives. Any hints, tips, thoughts?
Rob
Tried that, but it appears to be eaten by the ethanol additives from Mogas.
Rob
Old March 3rd 07, 07:36 AM posted to rec.aviation.homebuilt
Rob Turk
"cavelamb himself" wrote in message
nk.net...
Fuel Tank Bushing
SKU: H7285
$1.00
Richard
That looks pretty convincing. Someone else suggested Dapco, which has the
same plugs. I e-mailed Dapco and they confirmed their product to be good for
this, including being Ethanol resilient. They are an OEM supplier so I don't
think they will do small quantities, but I have not asked yet.
Rob
Old March 3rd 07, 11:45 AM posted to rec.aviation.homebuilt
polyethylene tank. This is aKitfoxheader tank that has developed a leak
Rob
Rob
There is only one thing that will work that I have tried other than
plastic welding.
Get a stick of the 2 part epoxy for fuel tanks.
Knead together, and wrap around the thread then screw in the fitting.
Once in make sure you always hold a wrench on it when you are screwing
other fittings into it or it might break the seal.
Mine has not leaked in over 3 years now.
More Kitfox info and movies and GPS plotting stuff here http://www.cfisher.com
Dave
Old March 3rd 07, 09:18 PM posted to rec.aviation.homebuilt
On Sat, 3 Mar 2007 08:36:23 +0100, "Rob Turk"
ink.net...
Fuel Tank Bushing
SKU: H7285
$1.00
Richard
Rob
Can you hog it out to the next size pipe thread and put a reducer
bushing in? Make sure you use a tapered pipe thread and do not
overtighten it. Make sure you use FLEXIBLE line from the tank to the
fuselage. Rigid tubing WILL eventually take the threts out of the poly
tank.
Fuel tank balance Mxsmanic Piloting 101 October 3rd 06 07:56 AM
Anyone had fuel tank air vent icing up? Jim Macklin Instrument Flight Rules 3 February 28th 06 09:57 PM
fuel tank plumbing pwm Home Built 18 January 27th 05 04:54 AM
Fuel line thread sealant Paul Lee Home Built 7 February 26th 04 12:44 AM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
