Descending from MEA to land under VFR
Old March 2nd 07, 01:53 AM posted to rec.aviation.ifr
kevmor
Default Descending from MEA to land under VFR
In the regulations it says that you can land at an airport without an
IAP if you descend from the MEA and land under VFR, but if there is a
MOCA, can you use that instead?
Old March 2nd 07, 02:53 AM posted to rec.aviation.ifr
Sam Spade
Regulation or policy?
If the MOCA is within 22 miles of the VOR sure you can use it. Or, if
the center will provide the service you can use their MIA, if lowwer.
If the MOCA is not within 22 miles of the VOR but you have IFR-certified
GPS, a good case can be made you can use the MOCA regardless.
Old March 2nd 07, 02:56 AM posted to rec.aviation.ifr
Mark Hansen
Of course, if you're in VMC you can cancel IFR and proceed VFR...
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
Old March 2nd 07, 03:26 AM posted to rec.aviation.ifr
Sam Spade
That's too easy. ;-)
Old March 2nd 07, 02:19 PM posted to rec.aviation.ifr
Barry
Which regulation do you mean? The only place I see this in Part 91 is
91.169(c)(2), which sets requirements for the alternate airport. If weather
allows a descent and landing under basic VFR from the MEA, then you can use an
alternate airport that has no IAP. I don't see any provision to substitute
the MOCA for this. However, this is rarely an issue, because if the weather
is so good, you probably won't need to file an alternate in the first place.
The requirements for conducting a visual approach are not listed explicitly in
Part 91, but are in the AIM, 5-4-22. There's nothing about the MEA, just that
you must:
- be able to proceed visually and clear of clouds to the airport
- have in sight either the airport or traffic to follow
- have destination weather at least 1000 foot ceiling and 3 miles vis.
(weather reporting not required if there is "reasonable assurance" that these
are met.
So if you're at the MOCA, can see the airport, and weather is better than
1000/3, then yes, you should be able to get a visual approach. Often you'll
be at the sector's minimum vectoring altitude, below the published MEA or
MOCA.
Barry
Old March 2nd 07, 02:39 PM posted to rec.aviation.ifr
Barry
One more point on this. Some instrument-rated pilots don't realize that you
can always file IFR to an airport that has no IAP - you just have to
file an alternate, regardless of the weather (see FAR 91.167(b)(1)). If the
weather there is (and is forecast to remain) good VFR, then your alternate can
be any nearby little airport that also has no IAP.
A lot of times it's useful to file IFR if the weather's marginal and you want
to go to a place that has no IAP. Controllers might have a creative way of
getting you in. Once (before 9/11) I flew into Washington Executive (W32),
which as I remember at the time had no IAP, or at least not one for which I
was equipped. The controller asked if I wanted to do the ILS for Andrews.
Apparently it was common practice there in marginal weather for people to
descend on the ILS, get below the clouds, then scud run over to Executive,
only about 3 miles away. In my case, the weather was good enough that I
didn't have to do this.
Barry
Old March 2nd 07, 02:48 PM posted to rec.aviation.ifr
Steven P. McNicoll[_2_]
What regulation are you referring to?
Old March 2nd 07, 04:11 PM posted to rec.aviation.ifr
Jose
There's one gotcha to cancelling IFR when below the clouds - if you
don't have the proper VFR cloud clearances (500 feet in some airspaces)
then you can't legally cancel IFR.
Jose
Humans are pack animals. Above all things, they have a deep need to
follow something, be it a leader, a creed, or a mob. Whosoever fully
understands this holds the world in his hands.
Old March 3rd 07, 01:54 AM posted to rec.aviation.ifr
kevmor
I'm not sure of the regulation, I've just read it in several places
studying for the instrument oral...
Old March 4th 07, 07:07 AM posted to rec.aviation.ifr
Guillermo
Are you thinking about 91.169 (c) (2), where it states that if your
alternate airport does not have an IAP, the ceiling and visibility
have to allow from a descent from MEA approach and landing under basic
VFR in order to be a valid alternate? It is the only place in the regs
where I remember seeing a phrase like that....
US 503rd Paratroop Inf Regt & 2~4th Aust Field Regt descending on Nadzab 5 Sep '43 Dave Kearton Aviation Photos 0 January 20th 07 01:24 AM
Descending prior to the VDP? MH Piloting 8 November 5th 04 05:35 AM
Adventures in TSA land Michael Piloting 65 October 26th 04 05:07 PM
How not to land an MD-80 HECTOP Piloting 9 February 23rd 04 06:57 AM
Descending through a thin icing layer Wyatt Emmerich Instrument Flight Rules 70 December 31st 03 06:17 AM
