Mode C is reading high....
Old March 11th 07, 02:49 PM posted to rec.aviation.owning
Dico
Default Mode C is reading high....
Hello,
I've noticed during a flight the other day to Columbus that our Mode C
was reading high... by about 250 feet. The altimeter seems to be
indicating fine as on the ground, with the correct altimeter setting,
it shows the correct altitude. As well, flying the ILS, i make a habit
to check the altitude when crossing the FAF and it is correct too.
Any thoughts on what the issue is?
Dico
Old March 11th 07, 04:39 PM posted to rec.aviation.owning
Mark Hansen
On 03/11/07 07:49, Dico wrote:
Hello,
The transponder uses its own altitude encoder, not the plane's altimeter.
I think there's a regulation which states that the transponder must be
within 100 feet of actual pressure altitude, so you probably should have
it looked at.
Dico
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
Old March 11th 07, 05:23 PM posted to rec.aviation.owning
RST Engineering
Not necessarily. There are optical encoding altimeters. They are not
common, but they do exist.
"Mark Hansen" wrote in message
Old March 12th 07, 01:51 AM posted to rec.aviation.owning
Michelle P
Dico wrote:
Hello,
Dico
You could have water in the line. This usually causes strange readings.
If it is past the Altimeter then it will not affect it.
Michelle P
Old March 12th 07, 02:02 PM posted to rec.aviation.owning
Dave Butler
Dico wrote:
Hello,
The altitude your mode C reports comes from a separate pressure
transducer, not your flight instruments, so the accuracy/precision of
your mode C altitude is not related to the accuracy/precision of your
flight instrument.
The mode C reported altitude is pressure altitude, so needs to be
corrected for barometric pressure for comparison with your flight
instrument. The altitude shown on ATC's display is corrected to the
local altimeter setting, but the raw data from your transponder is not.
Mode C altitude typically has a resolution of 100 feet, which gives rise
to possible sizable rounding errors. Newer pressure transducers used
with TSO146 GPSs have a resolution of 10 feet.
Old March 12th 07, 06:16 PM posted to rec.aviation.owning
Robert M. Gary
On Mar 11, 7:49 am, "Dico" wrote:
Hello,
1) the attitude from your transponder is pressure altitude, ATC
corrects for pressure.
2) I learned long ago not to try to debug issues with transponders,
they seem to be well out of the range of non-radio,electronics people.
However, generally adjustments are very inexpensive. In fact, most
places that quote fixed price IFR certs include basic adjustments to
the transponder. Every time I bring my plane in for IFR cert they have
to do some tuning of the unit.
-Robert
Old March 12th 07, 08:00 PM posted to rec.aviation.owning
dlevy
......somebody in rec.aviation.ifr would just *love* this one.....
snip
-Robert
Old March 12th 07, 10:26 PM posted to rec.aviation.owning
Newps
Why?
snip
-Robert
Old March 12th 07, 10:38 PM posted to rec.aviation.owning
dlevy
Transponder attitude is not corrected by ATC. Never has and never will be.
I, as the pilot in command, control transponder attitude. I'll shut the
damn thing off.
"Newps" wrote in message
Why?
snip
-Robert
Old March 12th 07, 11:08 PM posted to rec.aviation.owning
Robert M. Gary
damn thing off.
How do you control the altitude the transponder puts out?
-Robert, CFII
New transponder mode S vs. mode C Tom N. Soaring 39 November 7th 06 07:40 AM
Winter mechanical vario reading high Alan Meyer Soaring 13 April 13th 06 02:38 AM
IFR reading Paul Folbrecht Instrument Flight Rules 7 February 24th 05 09:12 PM
IVO pireps wanted.. high performance/high speed... Dave S Home Built 8 June 2nd 04 04:12 PM
high copper reading in oil analysis [email protected] Owning 1 March 26th 04 03:32 PM
