Dear All,
After I have installed my VP9 in the Mini Nimbus from my old glider, I had a serious problem with the VP9E. My problem is that after installing the VP9 from my old glider into Mini, the VP9 does not producing, just a very low level (you almost can not hear anything) vario sound. All cabling are the same as it was in the previous glider, all connections checked, they are good, the loudspeaker is also the same, the original Peschges in a small yellow rectangular box, this is also checked. We have tried to use another loudspeaker, 8ohms, the result was the same, only very-very quiet sound. We have also measured the resitance of the original loudspeaker, it was about 200 ohms. So everything is very strange, because nothing has cahanged, nothing happened with the VP9 during the winter, it was stored in the room. I would highly appreciate if aynbody could help, thanks in advance. |
| Thread Tools | |
| Display Modes | |
| L-Nav audio vario problem | Roy Clark, B6 | Soaring | 5 | September 8th 05 05:58 AM |
| Sony Air-8 audio problem | salmonsm | General Aviation | 0 | July 26th 05 10:57 PM |
| Old Peschges VP-3 Question | Wayne Paul | Soaring | 2 | June 27th 05 08:50 PM |
| Peschges VP9 | Istvan Csonka | Soaring | 1 | January 5th 05 09:53 AM |
| Peschges VP3 Problems | Nick Gilbert | Soaring | 7 | December 2nd 03 05:12 AM |
