It's a 'Cushion Needle,' okay? Yeah, you can call it a 'Rib Stitching
Needle' if you want to. But expect the price to double (or more). Sometimes it's called a 'Quilting Needle,' 'Button Needle' or just the generic 'Long Upholstery Needle' but whatever it's called, you need at least one and more is generally better. Usta cost about fifty cents for a 10-inch upholstery needle (about 1955). Over the years I accumulated quite a few of them, sharp end stuck in a cork. My dad had about a dozen of them in a piece of tubing in one of his tool boxes when he passed away and they fell to me, my younger brother being strictly a rotary-wing sorta guy. Although when he died a few years later I found an assortment of needles in his kit, including a couple of long ones. Some guys who write to me about Flying on the Cheap can't get real steel needles. Sometimes it's because they simply aren't available and sometimes it's because they're too expensive. Sounds silly but it's true since a lotta guys who write to me do so from foreign countries. They've got the same yen to fly as anybody else but Lord, the troubles they run into. Ali went so far as to heat a bed spring, straighten it out and forge an eye on one end. After doing so he asked if a needle having a diameter of 1.5mm and a length of 23cm would be suitable, to which I replied: "Oh my yes!" although forging a dozen needles might leave you sleeping on the ground, which is why I advised him to use bamboo. The bamboo needles were about twelve inches long with a diameter of 3.7mm (about 0.145"). It took several messages to work-out their fabrication and additional exchanges to discuss the size of the hole. (Being a grass rather than a wood, bamboo has a perfectly linear grain, meaning it splits evenly.) After doing one-half of the elevator, which needed only a short needle but it was something he could do without assistance, Ali saw that the size of the hole was of no consequence since it was completely covered by the finishing tapes. Patel's problem was similar in that he could not find 'suitable string.' ('Thread' lead to some confusion, as did 'cord' but 'string' served well enough.) But he did have access to 100% polyester 'string' having a strength of 'approximately 3 kilograms in five trials' and wondered if he could spin several strands together, which lead to another affirmative from me and an interesting exchange in the principle of rope-making, since you can't simply spin the strands together. Fortunately, Patel grasped the principle at once since he also has a strong interest in Robotics (or at least, in small gear trains) and owns a hand-powered drill of which he is justifiably proud, along with a real carpenter's brace. The result was an unlimited supply of rib-lacing cord having a breaking strain of about 20 kilograms, more than enough to satisfy the strictest of CAA inspectors. American homebuilders have it pretty easy, being able to buy suitable needles and string :-) But if you'd care to see how others have done it, a shish-kabob skewer makes a good rib stitching needle. Simply sand the dull end to a thickness of about 1/16th of an inch and use a small drill bit to connect a series of holes to form the eye. Sanding and a bit of varnish will make it smooth enough for several wings- worth of rib-stitches. Sharpen a nail or wire to make the initial hole in the doped fabric; bamboo must be re-sharpened too frequently to make it practical for punching its own holes. Don't worry about the size of the hole, it will vanish when you apply the finishing tapes. And it doesn't absolutely HAVE to be a Seine Knot. A plain old- fashioned Square Knot does just fine, assuming you're willing to tie- off each stitch. Just to add to the difficulties, some of the messages I receive mean traveling several miles then paying a relatively hefty fee to gain access to the Internet, plus knowing a foreign language. But it all goes to show that man really CAN fly... with a bit of help from his friends. -R.S.Hoover PS -- A regular 10" upholstery needle has a diameter of 0.0975" And yes, it can make its own hole :-) PPS -- You can whip two strands of thread together without causing any problems. But if you want more, it's best to spin them together in the manner used to make a rope. You can find examples of how to do this on the Internet. - |
![]() wrote in message oups.com... It's a 'Cushion Needle,' okay? Yeah, you can call it a 'Rib Stitching Needle' if you want to. But expect the price to double (or more). Sometimes it's called a 'Quilting Needle,' 'Button Needle' or just the generic 'Long Upholstery Needle' but whatever it's called, you need at least one and more is generally better. Usta cost about fifty cents for a 10-inch upholstery needle (about 1955). Over the years I accumulated quite a few of them, sharp end stuck in a cork. My dad had about a dozen of them in a piece of tubing in one of his tool boxes when he passed away and they fell to me, my younger brother being strictly a rotary-wing sorta guy. Although when he died a few years later I found an assortment of needles in his kit, including a couple of long ones. Some guys who write to me about Flying on the Cheap can't get real steel needles. Sometimes it's because they simply aren't available and sometimes it's because they're too expensive. Sounds silly but it's true since a lotta guys who write to me do so from foreign countries. They've got the same yen to fly as anybody else but Lord, the troubles they run into. Ali went so far as to heat a bed spring, straighten it out and forge an eye on one end. After doing so he asked if a needle having a diameter of 1.5mm and a length of 23cm would be suitable, to which I replied: "Oh my yes!" although forging a dozen needles might leave you sleeping on the ground, which is why I advised him to use bamboo. The bamboo needles were about twelve inches long with a diameter of 3.7mm (about 0.145"). It took several messages to work-out their fabrication and additional exchanges to discuss the size of the hole. (Being a grass rather than a wood, bamboo has a perfectly linear grain, meaning it splits evenly.) After doing one-half of the elevator, which needed only a short needle but it was something he could do without assistance, Ali saw that the size of the hole was of no consequence since it was completely covered by the finishing tapes. Patel's problem was similar in that he could not find 'suitable string.' ('Thread' lead to some confusion, as did 'cord' but 'string' served well enough.) But he did have access to 100% polyester 'string' having a strength of 'approximately 3 kilograms in five trials' and wondered if he could spin several strands together, which lead to another affirmative from me and an interesting exchange in the principle of rope-making, since you can't simply spin the strands together. Fortunately, Patel grasped the principle at once since he also has a strong interest in Robotics (or at least, in small gear trains) and owns a hand-powered drill of which he is justifiably proud, along with a real carpenter's brace. The result was an unlimited supply of rib-lacing cord having a breaking strain of about 20 kilograms, more than enough to satisfy the strictest of CAA inspectors. American homebuilders have it pretty easy, being able to buy suitable needles and string :-) But if you'd care to see how others have done it, a shish-kabob skewer makes a good rib stitching needle. Simply sand the dull end to a thickness of about 1/16th of an inch and use a small drill bit to connect a series of holes to form the eye. Sanding and a bit of varnish will make it smooth enough for several wings- worth of rib-stitches. Sharpen a nail or wire to make the initial hole in the doped fabric; bamboo must be re-sharpened too frequently to make it practical for punching its own holes. Don't worry about the size of the hole, it will vanish when you apply the finishing tapes. And it doesn't absolutely HAVE to be a Seine Knot. A plain old- fashioned Square Knot does just fine, assuming you're willing to tie- off each stitch. Just to add to the difficulties, some of the messages I receive mean traveling several miles then paying a relatively hefty fee to gain access to the Internet, plus knowing a foreign language. But it all goes to show that man really CAN fly... with a bit of help from his friends. -R.S.Hoover PS -- A regular 10" upholstery needle has a diameter of 0.0975" And yes, it can make its own hole :-) PPS -- You can whip two strands of thread together without causing any problems. But if you want more, it's best to spin them together in the manner used to make a rope. You can find examples of how to do this on the Internet. Stimulating and nostalgic, Veeduber. I like that flat thread from Stits, with the wax on it. Gosh, that stuff was easy to work with and looked good under the tapes. Getting ready to do some more rib-stitching, with gusto. PA-18, 1953 vintage. |
On Mar 19, 5:53 pm, " jls" wrote:
I like that flat thread from Stits, with the wax on it. --------------------------------------------------------------------- It's actually 'lacing tape,' originally used for lacing together looms of wiring. We usta call it 'Collins 12-cord' after the Collins Radio Company, who would sell us rolls of it. Do a Google for 'dacron lacing tape,' you'll run into it. You want the white stuff with the 50- pound rating; usta come in 500 yd spools, pre-waxed & mildew-proofed and was delightfully inexpensive. Trouble is, it isn't STC'd for ALL fabric-covered aircraft... unless it is part of an STC'd package from one of the covering suppliers, who very kindly re-spool you a quarter of a spool for about ten times the price... like what happens when an upholstery needle gets turned into a rib-stitchin needle :-) -R.S.Hoover |
![]() wrote in message ups.com... : On Mar 19, 5:53 pm, " jls" wrote: : I like that flat thread from : Stits, with the wax on it. : --------------------------------------------------------------------- : : It's actually 'lacing tape,' originally used for lacing together looms : of wiring. We usta call it 'Collins 12-cord' after the Collins Radio : Company, who would sell us rolls of it. Do a Google for 'dacron : lacing tape,' you'll run into it. You want the white stuff with the 50- : pound rating; usta come in 500 yd spools, pre-waxed & mildew-proofed : and was delightfully inexpensive. Trouble is, it isn't STC'd for ALL : fabric-covered aircraft... unless it is part of an STC'd package from : one of the covering suppliers, who very kindly re-spool you a quarter : of a spool for about ten times the price... like what happens when an : upholstery needle gets turned into a rib-stitchin needle :-) : : -R.S.Hoover : As always, good stuff...Thanks! Dan D. |
![]() "Blueskies" wrote in message ... wrote in message ups.com... : On Mar 19, 5:53 pm, " jls" wrote: : I like that flat thread from : Stits, with the wax on it. : -------------------------------------------------------------------- - : : It's actually 'lacing tape,' originally used for lacing together looms : of wiring. We usta call it 'Collins 12-cord' after the Collins Radio : Company, who would sell us rolls of it. Do a Google for 'dacron : lacing tape,' you'll run into it. You want the white stuff with the 50- : pound rating; usta come in 500 yd spools, pre-waxed & mildew-proofed : and was delightfully inexpensive. Trouble is, it isn't STC'd for ALL : fabric-covered aircraft... unless it is part of an STC'd package from : one of the covering suppliers, who very kindly re-spool you a quarter : of a spool for about ten times the price... like what happens when an : upholstery needle gets turned into a rib-stitchin needle :-) : : -R.S.Hoover : As always, good stuff...Thanks! Dan D. Yes, Veeduber, yer legendary. Keep it coming and thanks for it. |
Alpha Wire and Cable still makes it, google on Alpha LC 136. About $50 for
a 500 yard spool of the white 50# stuff. A lot of the mail order electronics companies carry Alpha. Jim : It's actually 'lacing tape,' originally used for lacing together looms : of wiring. We usta call it 'Collins 12-cord' after the Collins Radio : Company, who would sell us rolls of it. Do a Google for 'dacron : lacing tape,' you'll run into it. You want the white stuff with the 50- : pound rating; usta come in 500 yd spools, pre-waxed & mildew-proofed : and was delightfully inexpensive. Trouble is, it isn't STC'd for ALL : fabric-covered aircraft... unless it is part of an STC'd package from : one of the covering suppliers, who very kindly re-spool you a quarter : of a spool for about ten times the price... like what happens when an : upholstery needle gets turned into a rib-stitchin needle :-) : : -R.S.Hoover |
Ridge Sewing has a new website | Chris | Soaring | 0 | December 1st 06 05:11 AM |
Sewing Up Your Own Sunshield and Propeller Covers | jls | Home Built | 5 | March 10th 04 03:45 PM |
Sewing Needle Suitable for Hand-Stitching Heavy Stuff Like Canvas and Carpet | ThJester99 | Home Built | 4 | August 6th 03 07:26 PM |
Sewing Needle Suitable for Hand-Stitching Heavy Stuff Like Canvas and Carpet | Larry Smith | Home Built | 0 | August 4th 03 01:31 PM |
Sewing Needle Suitable for Hand-Stitching Heavy Stuff Like Canvasand Carpet | Shelly | Home Built | 0 | August 2nd 03 05:42 PM |
