Passed Instrument Checkride!
Old March 20th 07, 09:15 PM posted to rec.aviation.ifr
kevmor
Default Passed Instrument Checkride!
I passed my instrument checkride last Tuesday. I waited 2 months to
try and do the checkride from when my CFII told me to schedule it.
Problems with my examiner's medical, scheduling with another examiner,
then going back to the first one, and weather delayed it.
Here is how my IFR checkride went from what I can remember.
We went into one of the conference rooms and he asked to see all my
paperwork: pilot certificate, medical, application, picture ID, and
logbook endorsement. He started asking a few questions and my
answers:
What is required to be current for IFR?
Everything for VFR, plus 6 approaches, holding procedures and
intercepting/tracking courses
(He was looking for more...)
I said you have 6 months to meet this then if you don't, you have
another six months. After that you'll need an IPC.
Who can give an IPC?
A CFII, examiners, FAA...
What instruments are required for IFR? (GRABCARD)
How do you check the VOR?
VOT +/- 4 deg., Air checkpoint +/- 6 deg., Ground checkpoint +/- 4
deg. (dual VOR, but I didn't get to that) I started to explain where
to find these (AF/D), but he went on to the next question:
Using a VOT, must you be in a certain location on the airport?
No, as long as you can receive the frequency.
Does it matter which way your airplane is facing?
No (I hope nobody would get that wrong!)
What should the VOR indicate?
360 deg. with a FROM when needle is centered, 180 TO.
If the needle is centered and it reads 356 FROM, is that legal?
Yes
Would you apply this error to navigation?
No, this is a tolerance and you shouldn't adjust your courses because
of the error.
He then explained if your VOR was 4 degrees off and you applied that
to tracking a course outbound, how you could get very far off course
the further you got away from the VOR. He said it may be 4 degrees
off on one radial but not on the other. I related this to flying
different headings with a compass using a compass card, and you
shouldn't do this with the VOR errors.
Was my aircraft certified for known icing?
No
How could I determine freezing levels?
I said a freezing levels chart, winds aloft...
He asked how from the winds aloft? (He sort of acted like I gave a
wrong answer at first)
I said from the temperatures you could determine the freezing
altitude
(He was still looking for something else...)
I said a very crude way would be to use the average lapse rate from
the temperature at the ground...
He confirmed it would be very crude, and said not to overcomplicate
this.
I got it right with just saying call the FSS and get the freezing
levels at the airports on the route.
Could I fly if the freezing level was 4,000, the cloud bases at 3,000,
and an MEA in the clouds, legally?
Legally, yes
He asked what was the major problem with ice?
I said the accumulation of the added weight.
I sort of hesitated on the known icing questions, and he stated that
there is no clear definition of known icing in the regulations. He
said he wanted to ask these questions as there has been those legal
rulings on pilots flying into known icing and whether "conditions
favorable to icing" was "known icing" or not.
The general consensus was (legally) the FAA may question if you fly
your non-icing-certified aircraft in "icing conditions", but it is
legal as long as it is not "known icing" such as an actual PIREP.
He said he flies in an icing certified airplane with his son, which
is equipped with deicing equipment, and it melts it off as fast as it
accumulates. He said the icing area is about 10 degrees either side
of freezing temperatures, and a lot of people don't know that you can
climb above it into below freezing temperatures where it will bounce
off the airplane, which isn't a problem.
He then asked for me to get out my enroute chart to ask a few
questions. What does the V mean on victor airways?
I couldn't figure out what he wanted, I said it was just an airway.
After a while I finally got it, it would be J on a high enroute chart.
How high is this chart good for?
18,000 ft.
What is the change over point (pointing to a straight course, no COP
marked)?
The halfway point.
Is it regulatory that you change it there?
Yes
He then explained how you could still have a centered needle past the
halfway point but be drifting to the side because maybe your VOR was a
few degrees off. Where is the COP on this course (pointing to one
marked with DME)?
The mark.
He then explained how this is because one of the VORs doesn't have as
strong a signal. Then he very thoroughly gave me a scenario of flying
out from KRBL (I think), with a MCA fix a few miles after takeoff. He
asked if I lost radios just before reaching it and I was assigned
3,000, expect 9,000, what should I climb to?
The highest of assigned/expected/minimum altitude, so 9,000.
What if I was 3,000 upon reaching the MCA fix (with a MCA of 5,000)?
Hold at the fix while in a climb to the MCA.
Continuing on, if I arrived at a fix from which an approach begins (he
pointed to an airport near the coast), what would I do if I arrived
early?
Hold at the fix until EFC or ETA expires.
If I arrived late?
Begin approach immediately.
If there are VOR, NDB, GPS, ILS approaches...which one?
Any approach.
He then asked to look at the SMF ILS 16R approach. What are the
minimums?
1800 RVR visibility, 226 decision height.
What is MDA?
Minimum Decent Altitude
When you get to DH, what do you do?
That is when you make the decision to go missed or continue.
What if you are on the ILS and ATC calls you and says, "the RVR just
went to 900, what are your intentions?" Must you go missed
immediately, continue the approach, or?
I knew you couldn't descend from the DH if it's below minimums, but I
didn't know about before that.
He asked me to sort of guess.
I said because I haven't read anything you couldn't continue to the
DH, I said you can.
He said that was correct, he said part 135 and others must go missed
immediately, but part 91 can descend to the DH. If I descend to DH
and it's 900 RVR, can I land?
No, it's below minimums.
He explained how someone had gone below the DH in this scenario and
went off the runway on landing because the visibility was too poor.
They lost their flying job and had their license suspended. Somehow
we got to talking about being cleared to land, as they can't clear you
to land with the Wx below minimums. He said the tower responded with
"Roger" when the pilot contacted him, never clearing him to land.
Can you go below DH?
Yes, by 50 ft.
He then explained how a jet is unable to go from a descent in the
landing configuration, start retracting the flaps, gear, and starting
a climb without going below the DH. What about MDA?
You can't descend below MDA at all, and you are level so there's no
reason to go below it.
He then said he had one more question he forgot to ask, he went to a
white board and drew a runway, was very clear on the altitude I was at
(circling altitude) and where the airplane he was drawing was circling
around to land on the opposite end. As he drew the line he said to
tell him when I could descend to land from circling minimums. I told
him when he just started to turn in on final. He said this was a
little late, but was fine. He said many people thought they could
descend on downwind or base, etc.
Flying portion:
He gave me a clearance while still on the ground. Cleared to
Stockton, SAC V585 ECA Direct, 4,500, 1200. I asked him if he could
tell me in advance before I request the approaches (so I'll know what
to ask for when they ask for what's next). He said we'll do the SAC
ILS with vectors, VOR own nav, then LOC own nav. He told me ahead of
time to be sure to make all reports (entering hold, etc.) if ATC loses
radar, which he'll be simulating. He played ATC for the cross country
portion.
I setup all the radios, etc and did the instrument check, departed MHR
and identified the SAC VOR. As we're getting fairly close to it, he
says ATC has lost radar and report reaching 4,500 and the SAC VOR. I
report both fine, and track onto V585.
He says he has holding instructions when I'm ready to copy. He says
hold at WAGER as published, maintain 4,500 (and says normally you'd
get an EFC). I was correcting to the right and the entry was on the
borderline of being parallel, but I didn't want to do a parallel...I
said I'd be doing a teardrop and he says that's what he'd do as it's
the least maneuvering, etc.
I was finishing the first lap in the hold when he asked how I'd
determine the leg timing. I reached 1 minute right then and said it's
right on so I wouldn't need to adjust the outbound leg. He then said
he has an amended clearance when I'm ready to copy. I was in the turn
to go outbound in the hold so I told him to standby (I wanted to get
setup on the outbound heading). I got a clearance to Linden VOR,
V113, Manteca, direct. I started heading towards Linden and
identified it when he said we're done with this and he'll give me
vectors now.
He gave me a vector and told me to just hold this for a minute. He
then pulled the power to idle and said I was in full IMC, what would I
do? I said I'd troubleshoot the failure, announce it on the radio,
squawk 7700... He said Ok, you've already done that. (Meanwhile I've
got it trimmed at 65 knots, best glide). I said I should know my
approximate location and the terrain around me for the safest
landing. He said he's looking for something simple... I then said as I
started getting lower, I'd slow down and lower the flaps all the way
for the slowest landing speed. He then suggested to be as close to
stall as reasonably possible.
I held another heading and he said to slow down to 80 kts maintaining
altitude. Then turn to another heading. Then speed back up, then
descend at 80 kts 200 ft and level off at 80 kts. Then two unusual
attitudes then off to do the 3 approaches at SAC.
I contact NorCal approach and tell him I'm 15 miles SE of SAC VOR and
the approaches. My examiner wanted to tell ATC it's for a checkride
(to do full approaches at busy SAC), but his mic was garbled and the
controller said I was clear but my examiner wasn't. I got vectors for
the ILS and it went fine, but the examiner kept placing my enroute
chart on the windshield to make sure I wouldn't look out. One time
getting close to DH the chart fell on the controls...does this count as
one of the distractions?
I was getting setup for the VOR approach when the examiner wanted to
ask ATC what altitude we were reporting (I had mentioned it was
slightly off during preflight)... ATC couldn't understand him good
enough, so I said I'd ask. (Does this count also for
distractions? Luckily I decided what holding entry I'd do before
we took off to use at the IAF if I was coming from the west side of
the airport, as I only had a few seconds left now to get it figured
out.
We went around again for the LOC approach. When we got on the ground
back at Mather, he said I flew the airplane very smoothly (even though
I was nervous, it actually wasn't my best!). He said my first two
approaches were perfect. I think the second one I was starting to get
tired and got off on the LOC close to the limits right before the
missed approach. I think because I did very well on the rest he was
more lenient on the last approach. He also said my DG was getting off
very quickly (I was resetting it every 5 minutes or so). So no
partial panel, and a total of 1.6 flying time.
Old March 20th 07, 09:19 PM posted to rec.aviation.ifr
kevmor
One more thing (it's all coming back now) that I thought was
interesting. He said how is the static system hooked up? I said each
instrument is hooked to the other, then to the static port. He said
why do you think it's this way? I had actually never thought about
it, but said probably so if you loose one you'll notice on all of
them. He said if they each had their one static source in different
locations, your altimeter might say your in a climb while your VS says
your descending, etc.
answers:
Yes
of the error.
No
altitude
this.
Legally, yes
18,000 ft.
marked)?
The halfway point.
Yes
marked with DME)?
The mark.
early?
If I arrived late?
Any approach.
minimums?
What is MDA?
DH, I said you can.
Yes, by 50 ft.
Flying portion:
portion.
vectors now.
out.
Old March 20th 07, 10:04 PM posted to rec.aviation.ifr
Mark Hansen
[ snip ]
Great story, Kevin. We should get together one of these days and swap
checkride war stories!
Mark Hansen, PP-ASEL, Instrument Airplane
Cal Aggie Flying Farmers
Sacramento, CA
Old March 20th 07, 11:57 PM posted to rec.aviation.ifr
Jim Macklin
DH, you make a decision AT DH while in a descent on GS, so
if you decide to go-around you will be below DH before the
airplane starts back up. It isn't 50 feet, you just have to
decide and either continue or discontinue the approach.
You can use the approach light rabbit to continue below DH,
but only to 100 feet unless you get more of the required
visual cues.
Ice is aerodynamic spoiler, not weight.
VOR check, to check properly, swing the OBS and make sure
you get the proper deflection, 10 ° should be full scale
80° and the TO/FROM flag should be switching, if it doesn't
your VOR has low sensitivity and may not should course
deviation at 25-50 miles, the needle will just center while
you drift off course...
Other than that, congratulations.
James H. Macklin
ATP,CFI,A&P
some support
http://www.usdoj.gov/olc/secondamendment2.pdf
US Court on DC gun law...
http://pacer.cadc.uscourts.gov/docs/...3/04-7041a.pdf
"kevmor" wrote in message
ps.com...
months to
schedule it.
another examiner,
remember.
see all my
picture ID, and
and my
| answers:
and
you have
checkpoint +/- 4
explain where
airport?
legal?
| Yes
courses because
| of the error.
applied that
off course
4 degrees
flying
and you
| No
I gave a
freezing
| altitude
rate from
overcomplicate
| this.
freezing
bases at 3,000,
| Legally, yes
stated that
regulations. He
those legal
"conditions
if you fly
but it is
PIREP.
son, which
fast as it
either side
that you can
will bounce
few
an airway.
enroute chart.
| 18,000 ft.
course, no COP
| marked)?
| The halfway point.
| Yes
needle past the
your VOR was a
(pointing to one
| marked with DME)?
| The mark.
doesn't have as
scenario of flying
takeoff. He
assigned
9,000.
of 5,000)?
approach begins (he
I arrived
| early?
| If I arrived late?
| Any approach.
are the
| minimums?
| What is MDA?
continue.
"the RVR just
missed
minimums, but I
continue to the
| DH, I said you can.
go missed
descend to DH
scenario and
too poor.
suspended. Somehow
can't clear you
responded with
to land.
| Yes, by 50 ft.
in the
and starting
there's no
went to a
altitude I was at
was circling
he said to
minimums. I told
this was a
they could
| Flying portion:
to
if he could
I'll know what
do the SAC
me ahead of
if ATC loses
cross country
| portion.
departed MHR
to it, he
SAC VOR. I
copy. He says
normally you'd
was on the
parallel...I
do as it's
how I'd
and said it's
in the turn
wanted to get
Linden VOR,
and
give me
| vectors now.
minute. He
what would I
the radio,
(Meanwhile I've
know my
safest
then said as I
all the way
close to
maintaining
up, then
two unusual
SAC VOR and
checkride
garbled and the
vectors for
enroute
One time
this count as
wanted to
it was
him good
do before
west side of
it figured
| out.
the ground
(even though
first two
starting to get
before the
rest he was
getting off
So no
Old March 21st 07, 01:36 AM posted to rec.aviation.ifr
Jim Macklin
"Jim Macklin" wrote
in message ...
to
DH,
| visual cues.
doesn't
| your VOR has low sensitivity and may not show course
while
| James H. Macklin
| ATP,CFI,A&P
| some support
duties.
ps.com...
| months to
| schedule it.
| another examiner,
| remember.
| see all my
| picture ID, and
| and my
|| answers:
| and
| you have
| checkpoint +/- 4
| explain where
question:
| airport?
| legal?
|| Yes
| courses because
|| of the error.
| applied that
| off course
| 4 degrees
to
| flying
| and you
|| No
| I gave a
| freezing
|| altitude
| rate from
| overcomplicate
|| this.
| freezing
| bases at 3,000,
|| Legally, yes
| stated that
| regulations. He
| those legal
| "conditions
| if you fly
| but it is
actual
| PIREP.
| son, which
as
| fast as it
| either side
| that you can
| will bounce
| few
| an airway.
| enroute chart.
|| 18,000 ft.
| course, no COP
|| marked)?
|| The halfway point.
|| Yes
| needle past the
| your VOR was a
| (pointing to one
|| marked with DME)?
|| The mark.
| doesn't have as
| scenario of flying
| takeoff. He
| assigned
| 9,000.
| of 5,000)?
| approach begins (he
| I arrived
|| early?
|| If I arrived late?
|| Any approach.
| are the
|| minimums?
|| What is MDA?
| continue.
| "the RVR just
| missed
| minimums, but I
| continue to the
|| DH, I said you can.
must
| go missed
| descend to DH
| scenario and
| too poor.
| suspended. Somehow
| can't clear you
| responded with
| to land.
|| Yes, by 50 ft.
descent
| in the
| and starting
| there's no
he
| went to a
| altitude I was at
| was circling
| he said to
| minimums. I told
| this was a
| they could
|| Flying portion:
Cleared
| to
| if he could
| I'll know what
| do the SAC
| me ahead of
| if ATC loses
| cross country
|| portion.
| departed MHR
close
| to it, he
| SAC VOR. I
| copy. He says
| normally you'd
| was on the
| parallel...I
| do as it's
| how I'd
| and said it's
was
| in the turn
| wanted to get
| Linden VOR,
| and
| give me
|| vectors now.
| minute. He
| what would I
| the radio,
| (Meanwhile I've
should
| know my
| safest
| then said as I
| all the way
as
| close to
| maintaining
| up, then
| two unusual
| SAC VOR and
a
| checkride
| garbled and the
got
| vectors for
my
| enroute
| One time
| this count as
examiner
| wanted to
| it was
| him good
I'd
| do before
| west side of
| it figured
|| out.
on
| the ground
| (even though
| first two
| starting to get
| before the
| rest he was
was
| getting off
| So no
Old March 21st 07, 01:37 AM posted to rec.aviation.ifr
kevmor
Oh ok, 50 ft. isn't a set allowable limit? I don't remember reading
50, but my CFI told me that and the examiner didn't correct me on it.
Thanks for your input!
-Kevin
On Mar 20, 4:57 pm, "Jim Macklin"
visual cues.
James H. Macklin
ATP,CFI,A&P
some supporthttp://www.usdoj.gov/olc/secondamendment2.pdf
Seehttp://www.fija.org/more about your rights and duties.
US Court on DC gun law...http://pacer.cadc.uscourts.gov/docs/...3/04-7041a.pdf
ps.com...
months to
schedule it.
another examiner,
remember.
see all my
picture ID, and
and my
| answers:
and
you have
checkpoint +/- 4
explain where
airport?
legal?
| Yes
courses because
| of the error.
applied that
off course
4 degrees
flying
and you
| No
I gave a
freezing
| altitude
rate from
overcomplicate
| this.
freezing
bases at 3,000,
| Legally, yes
stated that
regulations. He
those legal
"conditions
if you fly
but it is
PIREP.
son, which
fast as it
either side
that you can
will bounce
few
an airway.
enroute chart.
| 18,000 ft.
course, no COP
| marked)?
| The halfway point.
| Yes
needle past the
your VOR was a
(pointing to one
| marked with DME)?
| The mark.
doesn't have as
scenario of flying
takeoff. He
assigned
9,000.
of 5,000)?
approach begins (he
I arrived
| early?
| If I arrived late?
| Any approach.
are the
| minimums?
| What is MDA?
continue.
"the RVR just
missed
minimums, but I
continue to the
| DH, I said you can.
go missed
descend to DH
scenario and
too poor.
suspended. Somehow
can't clear you
responded with
to land.
| Yes, by 50 ft.
in the
and starting
there's no
went to a
altitude I was at
was circling
he said to
minimums. I told
this was a
they could
| Flying portion:
to
if he could
I'll know what
do the SAC
me ahead of
if ATC loses
cross country
| portion.
departed MHR
to it, he
SAC VOR. I
copy. He says
normally you'd
was on the
parallel...I
| said I'd be ...
read more »
Old March 21st 07, 03:48 AM posted to rec.aviation.ifr
Jim Macklin
No problem, nobody has every done a "perfect" check-ride and
that includes me.
Fly as often as you can.
reading
me on it.
-Kevin
to
DH,
visual cues.
doesn't
while
James H. Macklin
ATP,CFI,A&P
US Court on DC gun
ps.com...
2
months to
schedule it.
another examiner,
it.
remember.
see all my
picture ID, and
and my
| answers:
procedures
and
you have
checkpoint +/- 4
explain where
question:
airport?
legal?
| Yes
courses because
| of the error.
applied that
far
off course
be
4 degrees
to
flying
and you
| No
like
I gave a
freezing
| altitude
lapse
rate from
overcomplicate
| this.
freezing
bases at 3,000,
| Legally, yes
stated that
regulations. He
those legal
"conditions
if you fly
but it is
actual
PIREP.
son, which
as
fast as it
either side
that you can
will bounce
a
few
an airway.
enroute chart.
| 18,000 ft.
course, no COP
| marked)?
| The halfway point.
| Yes
needle past the
your VOR was a
(pointing to one
| marked with DME)?
| The mark.
doesn't have as
scenario of flying
after
takeoff. He
assigned
9,000.
MCA
of 5,000)?
approach begins (he
if
I arrived
| early?
| If I arrived late?
| Any approach.
are the
| minimums?
| What is MDA?
continue.
"the RVR just
missed
minimums, but I
continue to the
| DH, I said you can.
must
go missed
descend to DH
scenario and
was
too poor.
suspended. Somehow
can't clear you
responded with
to land.
| Yes, by 50 ft.
descent
in the
and starting
there's no
he
went to a
altitude I was at
drawing
was circling
he said to
minimums. I told
this was a
they could
| Flying portion:
Cleared
to
if he could
I'll know what
we'll
do the SAC
told
me ahead of
etc.)
if ATC loses
cross country
| portion.
check,
departed MHR
close
to it, he
SAC VOR. I
copy. He says
normally you'd
entry
was on the
parallel...I
| said I'd be ...
read more »
Old March 21st 07, 01:40 PM posted to rec.aviation.ifr
Gregory Kryspin
Nice going Kevin...sounds like you had a good workout on the ride. Now stay
proficient!
Greg
Norwalk, CT
"Jim Macklin" wrote in message
that includes me.
reading
me on it.
-Kevin
to
DH,
visual cues.
doesn't
while
James H. Macklin
ATP,CFI,A&P
US Court on DC gun
ps.com...
2
months to
schedule it.
another examiner,
it.
remember.
see all my
picture ID, and
and my
| answers:
procedures
and
you have
checkpoint +/- 4
explain where
question:
airport?
legal?
| Yes
courses because
| of the error.
applied that
far
off course
be
4 degrees
to
flying
and you
| No
like
I gave a
freezing
| altitude
lapse
rate from
overcomplicate
| this.
freezing
bases at 3,000,
| Legally, yes
stated that
regulations. He
those legal
"conditions
if you fly
but it is
actual
PIREP.
son, which
as
fast as it
either side
that you can
will bounce
a
few
an airway.
enroute chart.
| 18,000 ft.
course, no COP
| marked)?
| The halfway point.
| Yes
needle past the
your VOR was a
(pointing to one
| marked with DME)?
| The mark.
doesn't have as
scenario of flying
after
takeoff. He
assigned
9,000.
MCA
of 5,000)?
approach begins (he
if
I arrived
| early?
| If I arrived late?
| Any approach.
are the
| minimums?
| What is MDA?
continue.
"the RVR just
missed
minimums, but I
continue to the
| DH, I said you can.
must
go missed
descend to DH
scenario and
was
too poor.
suspended. Somehow
can't clear you
responded with
to land.
| Yes, by 50 ft.
descent
in the
and starting
there's no
he
went to a
altitude I was at
drawing
was circling
he said to
minimums. I told
this was a
they could
| Flying portion:
Cleared
to
if he could
I'll know what
we'll
do the SAC
told
me ahead of
etc.)
if ATC loses
cross country
| portion.
check,
departed MHR
close
to it, he
SAC VOR. I
copy. He says
normally you'd
entry
was on the
parallel...I
| said I'd be ...
read more »
Old March 21st 07, 03:54 PM posted to rec.aviation.ifr
On Mar 20, 3:57 pm, "Jim Macklin"
visual cues.
Nitpicking here, 91.175(c)(3) does not mention the "rabbit" aka RAIL
or Sequenced Flashers as an acceptable visual reference. You can
descend to 100' using the *approach lights* as a reference. Below 100'
you need either the red side or terminating bars of the approach
lights (if the approach lights have them!) or one of the other
acceptable references, to continue your descent.
91.175(c) was changed to make "the runway environment" explicit.
RAILs or SFs are not on the list.
James H. Macklin
ATP,CFI,A&P
Old March 21st 07, 05:57 PM posted to rec.aviation.ifr
Barry
Default Continuing below DH
descend to 100' using the *approach lights* as a reference...
I disagree, 91.175 (c)(3)(i) says "the approach light system" which certainly
includes the sequenced flashers - see the AIM 2-1-1 which states "Some systems
include sequenced flashing lights".
One important point that people often miss is that in addition to seeing the
lights, the pilot must have the required flight visibility in order to
continue the descent below DH. Since 100 feet above TDZE on glideslope is
only about 1000 feet from the threshold, if you can't see the runway well
before then, you probably don't have landing minimums, and are not authorized
to go below DH.
IFR checkride: passed [email protected] Instrument Flight Rules 8 July 6th 05 10:14 PM
Instrument Checkride passed (Long) Paul Folbrecht Instrument Flight Rules 10 February 11th 05 02:41 AM
Instrument Rating Checkride PASSED (Very Long) Alan Pendley Instrument Flight Rules 24 December 16th 04 02:16 PM
IFR checkride in IMC: PASSED! gatt Instrument Flight Rules 25 November 3rd 04 12:24 AM
IFR checkride in IMC: PASSED! gatt Piloting 44 October 21st 04 06:02 PM
