Big Bertha Thing positron
Old March 28th 07, 01:41 PM posted to swnet.sci.astro,rec.aviation.owning
Tony Lance[_6_]
Default Big Bertha Thing positron
Cosmic Ray Series
Possible Real World System Constructs
http://web.onetel.com/~tonylance/positron.html
Access page JPG 56K Image
Astrophysics net ring Access site
Newsgroup Reviews including talk.politics.guns
Round photographic plates.
Caption;-
Another pair of tracks, arising simultaneously,
from a common point. The two particles responsible,
for these tracks, produce equal specific ionizations.
The one leaving the track of greater curvature is an electron
of 27 MeV energy. The one leaving the track of smaller curvature
was apparently left, by a particle not then known to exist,
a particle identical with the electron,
except that it carries a positive charge. It is a 450 MeV positron.
From a book by
J.D.Stranathan Ph.D.,
Professor of Physics and Chairman of
Department, University of Kansas.
The "Particles" of Modern Physics.
(C) Copyright The Blakston Co. 1942
Big Bertha Thing forward
Friends and family postings are included in the category,
forwarded by you from the internet, to the internet,
First Class users or conferences.
The same terms and conditions apply.
There is no student or accademic only exclusion clause,
written or implied in them. You are personaly responsible for them.
On the question of from address, a new mail item,
in reply with quote format, either from you or the conference moderator
will do. For the subject line use Fwd: prefix.
Occams' Razor says the simplest explanation is usually right.
(C) Copyright Tony Lance 1997.
To comply with my copyright,
please distribute complete copies, free of charge.
Tony Lance
Big Bertha Thing fusion
What is the cake-mix recipe for a fusion reactor?
1. There is no such thing as a self-sustaining fusion reactor.
2. There is no such thing as cold fusion.
3. That leaves high energy particle physics.
4. With the puffing billy principle of steam engine fame.
5. Take the two-ring medical electron cyclotron as the prototype.
6. Add another ring to it.
7. Dismantle the first two rings.
8. Update it to use a ball-bearing instead of an electron.
9. Add a steam iron.
10. Add an electrostatic charge generator.
11. Add a space satellite ion thruster.
12. Prove the existence of a magnetic field, which is weak at newtonian speeds
and strong at Einsteinian speeds.
13. This was proved by the costermonger in Big Bertha Thing spider.(see below)
14. It is directly proportional to momentum. (Memomagnetism)
15. It was missed, by science in Big Bertha Thing coil.(see below)
16. It was missed, by science in Einstein-Haas.
17. It was proved, by the two-ring medical cyclotron, with two different
electron masses. (Error Margin doubles to 4.4d-08 MeV)
18. Add electrostatic charge to ball-bearing.
19. Accelerate in first ring.
20. Kill charge with ion thruster and move to second ring.
21. Accelerate in second ring.
22. Move to third ring for minor speed adjustments, at near light speed.
23. Add a puff of steam.
24. Put plasma through heat exchangers.
25. Dismantle first two rings.
Big Bertha Thing transit
1. Take two fusion reactors.
2. Add two degauss cages.
3. Add length of High Tension cable.
4. Remove puff technology.
5. Replace mass transit system.
6. The experimental evidence is theological.
7. Bi-location is another one that the theologians got wrong.
8. Teleportation requires a saint, a sick person or both. (non-bio substitute)
9. Each acts as a capacitor, which builds up a charge.
10. Every energy saving light bulb has one.
11. It requires two doors.
12. It does not need a computer, which did not exist for many instances.
Big Bertha Thing orbiter
1. Take three fusion reactors.
2. Remove puff technology.
3. Fix reactors at right angles to each other.
4. Attach to nuclear submarine.
5. Remove propellers.
6. Add space sattelite ion thrusters.
7. Position at trailing point, where Earth travels arround the sun.
8. Take off for Earth orbit.
9. Move round Earth orbit to opposite point.
10. Make landing from Earth orbit.
Big Bertha Thing hyperspace
1. Take four or eight fusion reactors.
2. Arrange like juke-box carrousel.
3. Point at nearest star, off by a degree...
Cosmic Ray Series
http://web.onetel.com/~tonylance/spider.html
Access page JPG 11K Image
Newsgroup Reviews including uk.rec.cycling
Drawing of a clockwork spider wheel and hairpin.
Extract from Introductory Chapter;-
The "Spider tops," which are frequently sold in the streets of London,
consist of a heavy little disc mounted on a spindle (Fig. XIV.).
When the disc has been set spinning a small curved piece of
metal is placed to touch the toe, and at once begins to slide round it,
first the side (a) in the figure, and then the side (b),
the motion continuing backwards and forwards till the top comes to rest.
The fact is that the toe is magnetic, and this being the case it is easy
to see that the rolling of the toe on the side of the metal produces
the motion.
From the book
An Elementary Treatment of the Theory of
Spinning Tops and Gyroscopic Motion.
By Harold Crabtree M.A.
Formerly Scholar of Pembroke College, Cambridge
Assistant Master at Charterhouse
Longmans, Green and Co. 1923
First Edition 1909
Second Edition 1914
New Impression 1923
(C) Copyright Tony Lance 1998
Distribute complete and free of charge to comply.
Big Bertha Thing fact
Anything but a fact, changes the face of twentieth century science.
1. No iron moons and planetary cores.
2. No red shift measure of speed.
3. No Patrick Moore star at 95% the speed of light.
4. Muons arrive on earth.
5. Relativity is like an imaginary number; useful but not real.
6. Einstein-Haas gives a field strength 1/10000th the electric field.
7. Wave particle duality is a field effect.
8. Schroedinger is an approximation.
Who has the wit to check the fact?
Cosmic Ray Series
http://web.onetel.com/~tonylance/coil.html
Access page JPG 9K Image
Astrophysics net ring access site
Newsgroup Reviews including alt.politics
Two drawings of a Gyroscopic Top complete with coil.
it is easy to see that the rolling of the toe on the side
of the metal produces the motion. But Figs. XV. (a) and (b)
illustrate a top, whose spindle behaves in exactly the same
manner as the toe of the spider top, and yet is in no way magnetic.
The action is purely mechanical, as we shall explain in later pages.
It is an attractive top to watch, especially as it rushes round
the corner when it comes to the end of the coil.
From the book
First Edition 1909
Second Edition 1914
New Impression 1923
Big Bertha Thing fiction
9. Gyroscopic Top motion along coil masks a weaker field effect.
The Japanese antigravity experiment only worked one way.
With the object spinning one way OK, but the other way failed.
Anything but a fact...
10. One way gravity reduced and other way gravity increased,
so is bi-polar field efftect.
11. No antigravity, which is not bi-polar, so contradicts
bi-polar field effect.
Wave Particle Duality Paradox two slit interference patterns
can be disrupted by;-
1. Passive sensor near 2nd slit.
2. Turning room light on.
12. LCD digital watch, without backlight, near 2nd slit.
13. Thicker wall between slits.
Redshift is both speedometer and tape measure.
According to redshift speedo, the universe has a go faster
stripe painted on the outside.
14. No Big Bang, which needs go faster stripe on the inside
or antigravity.
15. No redshift speedo due to Steady State, which needs
neither to have go faster stripe.
Wave Particle Duality needs 1 slit and 2 slit experiments
to give different results from same effect. Make the walls
inside and outside the slits the same size and centre of
gravity.
16. Centre of gravity is at slit in one, but not the other.
17. Equal forces act on the slit in one, but not the other.
18. Wave Particle Duality as a field effect gives different
Big Bertha Thing tactics Tony Lance Owning 1 February 5th 07 07:28 PM
Big Bertha Thing blogs Tony Lance Piloting 3 February 12th 06 08:23 PM
Big Bertha Thing blogs Tony Lance Owning 0 January 15th 06 02:08 PM
Big Bertha Thing blogs Tony Lance Piloting 0 December 29th 05 05:18 PM
Big Bertha Thing blogs Tony Lance Piloting 0 July 2nd 03 11:58 PM
