Autopilots and coupled approaches
Old April 1st 07, 02:15 PM posted to rec.aviation.piloting
BDS
Default Autopilots and coupled approaches
I have a KFC-200 autopilot in the aircraft I fly and I have always been able
to fly a better approach by hand than the autopilot does. Just the other
day while out doing practice approaches to a runway with a 12 kt crosswind
on the surface and a pretty good wind gradient and turbulence from the FAF
down to DH I decided to try a coupled approach to see how it would go - the
autopilot did a lousy job compared to what could be done manually.
This is also true of the flight director. In other words, I can shoot a
more precise approach using the instruments as opposed to following the
flight director.
How does this compare with others' experiences using the autopilot or FD to
perform a precision approach?
BDS
Old April 1st 07, 02:27 PM posted to rec.aviation.piloting
Peter Clark
flight director.
My S-Tec 55X's and KAP140s fly dead-on when properly set up. I'd have
an avionics shop check the rigging on your control lines for proper
tension, and also the tension on the servo clutches and startup
voltages. I had a problem with pitch porpoise in a 55X which turned
out to be rigging being about 60% of rated tension, cleared right up
after they adjusted the cable tensions and checked the clutch torque.
Old April 1st 07, 02:50 PM posted to rec.aviation.piloting
Viperdoc[_4_]
I have a KFC-200 with FD as well. When it's gusty it does seem a little slow
on the response, and hunts a little. With smooth or constant winds it tracks
a glideslope like it's on rails.
It used to hunt a little in pitch, and I needed the cables tightened a
little, which seemed to help.
GPS approaches (LNAV/VNAV and LPV) are even smoother, but I've had some
issues capturing the GS with the KFC-200
Old April 1st 07, 04:06 PM posted to rec.aviation.piloting
BDS
Ours used to hunt in pitch as well but we had some work done on taking slack
out of the cables and it fixed that problem. Over the years I've had a
couple of in-flight failures of components in the system - specifically the
pitch servo and the pressure sensor, so the system has been looked at and
adjusted more than once, the most recent was in the last 2 years when the
pressure sensor failed.
Presently ours does not track the localizer very well but it does pretty
well with the GS. In the last 12 years or so I have used it almost
exclusively for enroute ops in heading and alt hold mode, and never for
approaches, but if it could be tweaked to handle the approaches better it
would be nice to have as a backup in some situations.
Probably time to have the entire system gone over.
BDS
Old April 1st 07, 04:13 PM posted to rec.aviation.piloting
TheSmokingGnu
Original or Extra Crispy?
ducks It's early in the morning!
:P
TheSmokingGnu
Old April 2nd 07, 05:20 PM posted to rec.aviation.piloting
Kingfish
On Apr 1, 11:13 am, TheSmokingGnu
:P
TheSmokingGnu
I like my duck extra crispy, thank you.
Seriously, that post reeked of Mont-posting under a nom de Usenet-black
When do you use autopilots? Mxsmanic Piloting 52 October 30th 06 02:23 PM
Piper Altimatic II autopilots - anyone? nobody Owning 12 February 8th 06 03:38 PM
DGs and Autopilots Andrew Gideon Owning 11 April 14th 05 06:04 PM
DGs and Autopilots Andrew Gideon Products 11 April 14th 05 06:04 PM
Coupled approach? Roy Smith Instrument Flight Rules 22 September 29th 04 09:46 PM
