LS-4 Landing Gear question
Old April 6th 07, 04:40 PM posted to rec.aviation.soaring
Default LS-4 Landing Gear question
From the LS-4 maintenance manual:
"Inspect landing gear system for preset load at folding struts of 12 -
15 kg (5.44 - 6.80 lbs)."
The error is repeated by the drawing of the the gear mechanism.
(where, incidentally, the pivot for the gear leg is drawn on the wrong
side).
Either the values are correct and the units of measure misapplied
(5.44 kg is 12 lbs), or the 12kg is correct, and they mis-converted to
pounds.
TIA
Old April 10th 07, 07:42 AM posted to rec.aviation.soaring
side).
pounds.
They mis-converted to pounds force. I have a '4a manual where they
'fixed' the problem by eliminating that section altogether.
-Dave
Thanks Dave,
In that case, I need to replace the strut. The breakover tension is
consistantly under 10Kg.
Old April 12th 07, 08:03 PM posted to rec.aviation.soaring
side).
pounds.
-Dave
Thanks Dave,
Yep, sounds like it's time. Mine runs more like 40 pounds with a good strut.
Speaking of misconversions, I notice Eastern Sailplane has one-click shopping
for an ASH-26E at $115,700, or 142,000 euros. Seems like the first option
is a better deal :-)
Dave- Hide quoted text -
- Show quoted text -
....um, yeah. I'll take two.
Experimental Landing Gear Design Question Dick Home Built 5 October 15th 06 07:37 PM
A Jet Blue Aircraft Landing with Sideway Landing-Gear Lufthansi Piloting 18 July 19th 06 06:13 AM
A Jet Blue Aircraft Landing with Sideway Landing-Gear Hansi Instrument Flight Rules 1 July 17th 06 05:01 AM
Landing gear - stupid question... Capt. Geoffrey Thorpe Soaring 9 December 3rd 05 11:31 AM
Bonanza Model 35 Landing Gear Question Eric Ulmer Owning 1 November 8th 03 02:58 PM
