Has anyone done calculations for takeoff distances for various density
altitudes, weights and winds for their sailplane-towplane combination? Every powered plane POH has a table but there are none in the glider books for obvious reasons (HP of towplane for one). The Arizona Soaring Assn flies out of some high (6600') and short (3900') runways (not concurrently) and in our typical conditions would like to fly with ballast but are revisting the idea that we should limit weights after some long takeoff rolls and/or slow climbs. We usually do not have good bail out options at most of our fields for rope breaks as an added issue. Casey Lenox Phoenix KC |
On Apr 7, 6:55 am, "Kilo Charlie" wrote:
Has anyone done calculations for takeoff distances for various density altitudes, weights and winds for their sailplane-towplane combination? Every powered plane POH has a table but there are none in the glider books for obvious reasons (HP of towplane for one). The Arizona Soaring Assn flies out of some high (6600') and short (3900') runways (not concurrently) and in our typical conditions would like to fly with ballast but are revisting the idea that we should limit weights after some long takeoff rolls and/or slow climbs. We usually do not have good bail out options at most of our fields for rope breaks as an added issue. Casey Lenox Phoenix KC I don't have any data, but you might consider collecting your own data using GPS data loggers. I am sure other clubs would be interested in the data. A ballasted single is going to weight about what a 2-place does, so if you can tow a 2-place you can (probably) tow a single, especially considering the (usually) better aerodynamics of the single. It would be interesting in comparing actual data to extrapolated estimates using POH data. Tom |
wrote in message oups.com... On Apr 7, 6:55 am, "Kilo Charlie" wrote: I don't have any data, but you might consider collecting your own data using GPS data loggers. I am sure other clubs would be interested in the data. A ballasted single is going to weight about what a 2-place does, so if you can tow a 2-place you can (probably) tow a single, especially considering the (usually) better aerodynamics of the single. It would be interesting in comparing actual data to extrapolated estimates using POH data. Tom Thanks Tom. I also wondered if I could go back and look at logs from various sites and try to recreate what the density altitude was and then somehow determine what my actual liftoff point was from the log. I would think that at least the climb rate could be determined. I am a bit surprised at the lack of opinions re this so far. It is data that we should be able to generate and definitely would be helpful to those of us flying out of hot high airports. Casey |
On Apr 11, 5:38 pm, "Kilo Charlie" wrote:
I am a bit surprised at the lack of opinions re this so far. It is data that we should be able to generate and definitely would be helpful to those of us flying out of hot high airports. If you had data you would need to careful in its interpretation. Glider launches usually take place when thermal activity has started. Wind shear and thermal downdrafts can be expected and, singly or in combination, and they can easily reduce climb rate to zero or make it negative. Let's say the data show you only need 1000 foot of the 5000ft runway and the predicted climb rate is 200fpm for the first 500ft, and the predicted thermal strength is 6kts, and the wind is gusty. Would you launch? I suspect the answer would be yes. We do it all the time and usually it works out ok. Since I know what prompted the question I'll comment that Williams has similar conditions to Flagstaff. That airport has a poor record for summer takeoff accidents and that's for airplanes without a glider in tow. Usually it works out ok though. Andy |
"Andy" wrote in message oups.com... On Apr 11, 5:38 pm, "Kilo Charlie" wrote: If you had data you would need to careful in its interpretation. Glider launches usually take place when thermal activity has started. Wind shear and thermal downdrafts can be expected and, singly or in combination, and they can easily reduce climb rate to zero or make it negative. Let's say the data show you only need 1000 foot of the 5000ft runway and the predicted climb rate is 200fpm for the first 500ft, and the predicted thermal strength is 6kts, and the wind is gusty. Would you launch? I suspect the answer would be yes. We do it all the time and usually it works out ok. Since I know what prompted the question I'll comment that Williams has similar conditions to Flagstaff. That airport has a poor record for summer takeoff accidents and that's for airplanes without a glider in tow. Usually it works out ok though. Andy So your response seems to be similar to some other local pilots Andy.....the data is not reliable. Would you then surmise that those Flagstaff accidents were by pilots that looked in their POH and found that it was incorrect? I think not. My opinion is that they felt that the data was bogus as well and went by the "feels right to me" approach ending in disaster. Casey |
In reading those types of accident reports, it seems that most of the pilots didn't think about there takeoff performance charts at all. They did not do a take off calculation. They just thought, "I've allways made it before." Nor did they think, "Hey, I'm halfway down the runway. I should be flying by now, better abort." For a glider takeoff. It would be interesting to have good data on expected takeoff rolls and climb rates. Each set of data would be specific to towplane-glider pairs. Takeoff surface and winds would have to be carefully recorded in addition to a GPS log with location and airspeeds. Any calculations would be suspect until experimentally verified. So skip the calculations and start recording data. Get a flight log of every takeoff. Try and quantify surface types, towplane ID and winds. Then plot the data and make your conclusions. And then use the data with a grain of salt. Todd Smith 3S |
And keep a note of how much fuel the tug has on board.
How heavy the glider pilot is. How clean the glider wings are. What time of day it was. Outside Air Temperature, pressure and moisture content. Local CAPE and Lifted Index. Length of rope (and its elasticity). Power setting of tug. What mood each of the pilots were in. Stick position on ground run. Local thermal and wave activity. All can have an effect on take-off distance and climb rate. There's so many variables that I'd be dubious of any metrics developed beyond the fact that high altitude, high temperature and heavy gliders do not make a good combination. Anybody who comes up with a set of explicit numbers and sticks to them is likely to discover how often theory doesn't work in practice! Happy soaring Gary Nuttall At 14:24 12 April 2007, Toad wrote: In reading those types of accident reports, it seems that most of the pilots didn't think about there takeoff performance charts at all. They did not do a take off calculation. They just thought, 'I've allways made it before.' Nor did they think, 'Hey, I'm halfway down the runway. I should be flying by now, better abort.' For a glider takeoff. It would be interesting to have good data on expected takeoff rolls and climb rates. Each set of data would be specific to towplane-glider pairs. Takeoff surface and winds would have to be carefully recorded in addition to a GPS log with location and airspeeds. Any calculations would be suspect until experimentally verified. So skip the calculations and start recording data. Get a flight log of every takeoff. Try and quantify surface types, towplane ID and winds. Then plot the data and make your conclusions. And then use the data with a grain of salt. Todd Smith 3S |
Ok, maybe a big block of salt :-)
In practice, my takeoff performance check is: If I'm not flying by X distance down the runway, pull the release and land straight ahead. Toad On Apr 13, 8:56 am, Gary Nuttall wrote: And keep a note of how much fuel the tug has on board. How heavy the glider pilot is. How clean the glider wings are. What time of day it was. Outside Air Temperature, pressure and moisture content. Local CAPE and Lifted Index. Length of rope (and its elasticity). Power setting of tug. What mood each of the pilots were in. Stick position on ground run. Local thermal and wave activity. All can have an effect on take-off distance and climb rate. There's so many variables that I'd be dubious of any metrics developed beyond the fact that high altitude, high temperature and heavy gliders do not make a good combination. Anybody who comes up with a set of explicit numbers and sticks to them is likely to discover how often theory doesn't work in practice! Happy soaring Gary Nuttall |
On Apr 13, 2:03 pm, "toad" wrote:
Ok, maybe a big block of salt :-) In practice, my takeoff performance check is: If I'm not flying by X distance down the runway, pull the release and land straight ahead. If you are not flying how come you need to land? ![]() |
"Gary Nuttall" wrote in message ... And keep a note of how much fuel the tug has on board. How heavy the glider pilot is. How clean the glider wings are. What time of day it was. Outside Air Temperature, pressure and moisture content. Local CAPE and Lifted Index. Length of rope (and its elasticity). Power setting of tug. What mood each of the pilots were in. Stick position on ground run. Local thermal and wave activity. All can have an effect on take-off distance and climb rate. There's so many variables that I'd be dubious of any metrics developed beyond the fact that high altitude, high temperature and heavy gliders do not make a good combination. Anybody who comes up with a set of explicit numbers and sticks to them is likely to discover how often theory doesn't work in practice! Happy soaring Gary Nuttall Continues to amaze me at how much disdain glider pilots have for quantitation. I suppose that may be what draws some of them into the soaring in the first place. I also enjoy that aspect but think that attitude has gotten many powered pilots into bad situations. To think that we are immune to it because we don't have engines is naive. Casey |
| Thread Tools | |
| Display Modes | |
| measuring arm distances | Heino & Deanne Weisberg | Home Built | 1 | October 21st 05 06:49 PM |
| Stuck at work--need takeoff/landing distances for a 172 please | Yossarian | Piloting | 12 | July 14th 05 02:12 PM |
| Edge distances in steel | Ed Wischmeyer | Home Built | 3 | August 24th 04 11:53 PM |
| Are sectional paths correct across "long" distances? | vincent p. norris | General Aviation | 32 | March 25th 04 03:32 PM |
| Are sectional paths correct across "long" distances? | vincent p. norris | Piloting | 36 | March 25th 04 03:32 PM |
